Question about Denon CDR-W1500 2-Disc CD Recorder
DENON CDR-W1500 DISPLAY READS "DIG. UNLOCK" WHEN IN OPTICAL INPUT
When selecting the input to be in "OPT" optical recording. The display reads "DIA. UNLOCK" and the "D" is always flashing. The manual said to check all connections for the optical inputs and they are good. The optical cable is known good because I tried it on another digiatl recorder unit and it works. I can record in analog mode ok. The record display does not recieve any signal on the display when tring to record using the optical inputs.
  • 120 Answers
SOURCE: denon 3801.cant display setup on tv
Hello gerrydav, What might be happenening is the refresh rate for your blu-ray is offsync for your preferred display. You should be able to change it by plugging it into another TV and playing around with the settings. If you have further problems please feel free to post again.
Please post what you do and how you did it. I look forward to your posts.
Posted on Nov 11, 2008
  • 11 Answers
SOURCE: No system configration display on AVR3300 since moving.
Make sure the two switches on the remote are all of the way to left most position before you try using the SYSTEM SETUP button - if the AVR is going into SETUP, the LCD display should be saying "SYSTEM SETUP". (I think that model does - most do).  also make sure that the Composite or S-Video on the TV's input 1 work from something else like a VCR, DVD player, ETC. rule out the TV and the cable first.
Posted on Apr 02, 2009
smarthome2
  • 1114 Answers
SOURCE: Can't record out from a digital input
It only passes the signal it see's. Digital for Digital and Analog for Analog. Try running a Standard analog RCA from your Cable box to the receiver then try and record. Hope this helps. If you still have an issue, post a comment and I can help you further.
Posted on Sep 21, 2009
SOURCE: Denon CDR-W1500 not recording
I had the exact problem and could not get any of the CR-Rs that I had to work. I looked up the code in the user's manual where it said the error means it's not a recordable audio CD and to refer to page 6. I looked at the front of the manual and saw that it mentions that the CD-Rs must be audio CD-R discs. I did some research online and found that there are in fact differences between CD-Rs that are just marked that and those marked as Audio or Music CD-Rs. I bought a set of CD-Rs that clearly had marked "Compact Disc Digital Audio Recordable" on the package. When I inserted this disc, I had no problems getting the recording to work. So, make sure the discs you use are clearly marked "Audio" or "Music". A computer burner won't know the difference, but your Denon recorder will.
Posted on May 14, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have the Denon CDR-W1500 recorder and the
Your original post said it was blank discs that didn't work.
Now it's ALL discs including pre-recorderd ones. THAT changes things considerably.
Is it audibly rotating the disc once it's loaded?
Posted on May 21, 2010
Din unlock c71
the input source you have selected is not working. If digital it might be a copy guarded source which the deck cannot read...
If you get fancier and are trying to record the optical output from a newer device like a 5.1 or 7.1 receiver although the signal will go through the MD deck cannot decode the advanced optical signal. There are adaptor boxes on eBay which decode 5.1 & 7.1 optical signals to an optical signal the older MD can read and record from.
Try selecting another source like analog RCA. The digital stuff I mentioned applies to digital RCA and Optical Cables like toslink.
Feb 08, 2014 | Sony MDS-JE520 Mini Disc Player
Tip
How to configure 'Video 1' input to use Digital Optical connection
Connect the optical cable to the DIGITAL OPT(ical) IN connection.
Press the purple 'VIDEO' button on the remote until 'VIDEO 1' appears on the display.
Press the SYSTEM MENU button (to the right of the DVD play, pause, stop buttons).
'VIDEO1 INPUT' flashes on display.
Press ENTER
'INPUT ANALOG?' (the default) flashes on display.
Press right arrow (to right of ENTER)
'INPUT OPTICAL?' flashes on display.
Press ENTER
'INPUT OPTICAL' displays briefly, then
'VIDEO1 OPT' displays.
You are done. Selecting VIDEO 1 in future displays 'VIDEO1 OPT' instead of 'VIDEO 1'.
on Mar 02, 2014 | Pioneer NS-DV88 System
I cant get the surround sound to work after connecting the Samsung BluRay Player to my Onkyo reciever using a optical digital connection or directly with the HDMI cable ?
Hi
You will have to assign the optical input to the input you are using, so for instance if you have plugged the optical cable into opt 1 on the onkyo reciever and wish to use the DVD input on the onkyo reciever, you need to go into the set of the onkyo to digital assignments or in/out assignments, dependent on the model, and select OPT1 for the DVD input. You can find out how to exactly do this in the onkyo's manual under 'digital assignments' or 'input assignments'.
Regards
TechSupp12
Dec 12, 2010 | Samsung BDC6500 BluRay Player
The SIGNAL: ANALOG won't disappear even though I've gone through the menu and selected my input OPT: CD/DVD/TV whatever it may be. How do I get my optical input recognized by the receiver? Is it broken?
It will change automatically once it detects a suitable digital signal.
So yes it could actually be faulty but more likely you aren't sending a suitable format digital signal from the source. check the digital audio output settings on whatever device you are using
old dvd players will output PCM 2 channel digital or bitstream multichannel (dolby dig or DTS) which your unit can handle whilst new blurays will have some very hi bit rates -eg192khz 24bit. You may need to lower the output in the menus to get the Pioneer to accept them.
It is always possible the optic has got kinked or fractured, which causes light scattering/corruption and will cause the same symptom
Sep 04, 2010 | Pioneer VSX-D411 Receiver
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Onkyo TX-DS939 optical selection problem help!
That coaxial, opt-1 and opt-2 are available only if they are not selected to some other channel. So you have to check if opt-2 is selected to Video-1,2,3,4,5,6,7,CD or DAT. Change that to Analog and then opt-2 is free to another device.
Mar 24, 2008 | Onkyo TX-DS939 Receiver
RCA PROFESSIONAL SERIES STAV 3880 Digital Optic input
Read the owners manual for setting up opt 1 and opt 2.
Feb 12, 2008 | Audio Players & Recorders
KS3102 Digital Optical Input Problem
What I did was turn on the system, don't put in any dvd in, or select an output 1 or 2. Press Menu on the remote, the display on the system display, not on tv should show Speaker, and other options. Select Input, select the one you want to use as the Optical Sound by press enter, then it will ask you on the system display input or optical sound input. Select optical input and press enter it will then say saved. You can then hit exit til goes back to where the display is back on main screen, or just wait til it exit by itself.
Jan 30, 2008 | Koss KS3102 System
No digital to reciever??
This tv will only output the sound from a digital tv channel through the optical output when using the tv's digital tuner. So if you are connecting a DVD etc it will not output through the optical output on the tv. ONLY digital chanels through the tv's tuner will give you sound. Refer to the tv's owners manual for more info.
Dec 27, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Error message
Din unlock means 'digital input is unlocked' meaning it is not receiving a signal on the **digita**l input you have selected. ( eg optical or single co-axial digital from another cd player etc) Check your connections and re-select the source using the front panel until you select the one you want. What are you recording from?
Apr 16, 2007 | Teac CD-RW880 CD Player / Recorder
Denon CDR-W1500 2-Disc CD Recorder Logo
103 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
