Question about Canon imageRUNNER C3200 Copier
Error code e000001 0004
Don't know what this error code is.
  • daebae Nov 03, 2007
    i get the same error code...any more detail solution to this problem...much appreciated,,
The upperroller has detected high temp check heater unit connections
Posted on Feb 27, 2007
4 Suggested Answers
PATHAMPAD
  • 25 Answers
SOURCE: Error Code E000001-0004
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
Posted on Feb 13, 2010
  • 149 Answers
SOURCE: What is error code E000001-0004 and E000001-0010 f...
there is a good possibility that the main thermistor and the sub thermistor has gone bad or is dirty. also it might need adjusted to be better placed next to the upper fixing roller
Posted on Jun 11, 2010
  • 4 Answers
This error code is a sensor in the side where paper jams usually occur open the door and look for a small sensor in black plastic, it will probably be not located properly these are known for dislodeging, Canon engineers simply glue them back in, switch off the power beofre doing this and when you switch back on it should load ok.
Posted on Apr 20, 2010
Canon ir c3220 color copier error E000020-01b0. What means? How solve that error?
Canon Error Code E000020 01b0
Although the yellow drum is indicated, in the link above, please note it may not be the yellow drum if instead it is the:"laser shutter or the plastic actuator on the right side of the front door."
Jan 24, 2018 | Office Equipment & Supplies
Getting error 50.90 fuser error, how do I change the fuse?
I checked 5 different printers and couldn't find a 50.90 error code. Since you keep the printer model a secret I haven't got the foggiest idea as to what the error code means, except that it is a fuser error of some kind. And getting back to your question, If I don't know what kind of printer you have I can't tell you how to change the fuse(r).
Sep 01, 2011 | Office Equipment & Supplies
My phone is restricted. . .i need to enter a restriction code but i don't know the code. . .i don't even know how it was restricted. . .please help me. . .
If your mobile phone displays Phone Restricted with an Undo option and selecting Undo results in an Enter Restriction Code error, your mobile phone is Network Locked. This means your mobile phone has been restricted for use on one specific network and a Restriction Code or Unlock Code must be entered before the phone can be used with alternative networks.You can get the Restriction Code at here
Onlinegsmunlock and Unlock it from Network Lock,Then Nokia Mobile Mostly asks for restriction code!Your Phone Brand,model,Network,Country it locked you need to specify it...
Jul 25, 2011 | Cell Phones
I would like to know the meaning of error code :051312-1 thanks
I don't know the meaning of the code directly, but I got around it by setting up MAC filtering on my router (you go into your router's settings, get your DSi's MAC address, which you can get if you go into the system information, and add it to your router.
Don't know if it'll work, but it helped me.
Jul 15, 2011 | Nintendo Video Game Consoles & Games
I get a p0402 error code on my 2001 ford ranger , what do i have to do to fix this error
The code most likely means one or more of the following:
-The DPFE (differential pressure) sensor is faulty and needs replaced
-There is a blockage in the EGR (most likely carbon buildup)
-The EGR valve is faulty
-The EGR may not be opening due to a lack of vacuum
Jun 13, 2011 | Ford Ranger Cars & Trucks
Hello i'm french, i have an oki c 8800 with : service call 173 fatal error. i don't understand what is this error and i want to know how to repare
Error code: 173
This error code means that the fuser temperature is low. You need to replace either the fuser or the thermistor inside the fuser.
May 27, 2011 | OKI C8800dn Led Printer
I need to know what Error code 1 is..
Normally chain saws don't have error codes...
Apr 13, 2011 | Garden
Cannon mp150 printer error
sorry, i don`t actually know but i think you should just use genuine catridges
May 16, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Pitney bowes model c400 copier error 0070??
Sincerely,I don`t know this model,but the error codes is similary to the Agfa,Minolta,Konica copiers.This code is the toner agitator motor malfunction code.The developer station is blocated under minimal level of toner ratio.In this case forced toner supply.Opem amd close the front door to reset.
Aug 19, 2009 | Pitney Bowes Office Equipment & Supplies
BUS-E04 KENWORD ERROR
It is letting you know there is an error with the audio system. Error code #4.
I don't remember what that code is exactly, but I thought those codes were for the CD Changers. Do you have one?
Bret
RepairPal.com
Nov 20, 2008 | 1996 Volvo 960
Canon imageRUNNER C3200 Copier Logo
968 people viewed this question
Clive
Clive
old marine
old marine
