Question about Intertherm Heating & Cooling
AC, but no heat
I have an intertherm unit for my mobile home and the heat went out on us. The ac seems to work fine, but no heat. I can switch the thermostat for the heater from the auto to on position, and it does blow air, but the air is luke warm. When I turn the heat on with the switch in auto position, nothing happens except a clicking noise and no air comes out, hot or not.
  • 4 more comments
  • chadwick0211 Nov 19, 2008
    I'm very sorry, I should have mentioned it's an electric ac/heater unit. I believe it's a Nordyne E2EB-015HA. Would the above advice you have given apply to an electrical unit as well.. Thank you so much for your help!! It is so appreciated!!
  • chadwick0211 Nov 20, 2008
    It almost sounds like the clicking is coming from the blower..
    I just tried turning the fan on for the unit, and the blower is working though, the fins on the inside are spinning well.
    OK, I found it it is the sequencer. I ended up calling around town here and I found one, the problem now is, the guy on the phone told me to bring the sequencer down so he can identify the type of sequencer, and give me type of sequencer I need. I did that thinking I was going to have some kind of wiring schematic to help me with the new sequencer. Nope.. No such luck. Now i'm stuck with a new sequencer with no idea which wire goes where.. I'm so stuck on this thing I dont know what to do.. I have wires looking me in the face and laughing, I have no clue what to do. Any help?
  • chadwick0211 Nov 21, 2008
    Thank you, that would be so helpful !!!!
    If your having problems posting it, you could send it to:
    Chadwick0211@Comcast.net
    Scholar:
  • 66 Answers
The clicking noise appears to be the igniter. Since it is not getting gas for some reason it will not operate and will shut down. This could be due to the burners being dirty or it could be a bad gas valve or it could be in the electronic mudule. Make sure there is gas coming into the home to the gas valve.Since you hear the igniter operating , for the time being we will assume it is ok. Clean the burners with a wire brush. Make sure they are clean. When reinstalling the burner. Make sure the igniter is directly over one of the burners in the path that the gas will take. This is important. Before attempting any repairs make sure you understand what to do and what not to do. Gas furnaces can be vary dangerous. If this is something you are not absolutely sure you can do. Get a qualified service man to repair and service the unit.You can get a qualified service man right here on this site for your area. I hope I have been of some help to you.
Posted on Nov 19, 2008
  • 1 more comment
  • Charles Caldwell Nov 20, 2008
    Where is this clicking noise comming from? Try to find where and let me know. I will help as much as I can.
  • Charles Caldwell Nov 21, 2008
    I`m going give you the schematic and manual for the E2 series. It covers several, you`ll have to find yours in the manual. The manual shows a schematic of your unit with the correct wire setup. I hope this will help you.
    http://homeappliance.manualsonline.com/ Unfortunately I was unable to post the part of the manual you needed. But you can go to this site and view the manual youself. You will have to become a member but it`s free. The manual is under nordyne then air conditioning. You will have to scroll down the page abd find your system. The manual will explian what a sequencer does and will also have a schematic that shows you where each wire will attach to the sequencer. It is in a pdf file. I hope this will help you.
I have a Intertherm heating and airconditioner unit and the ac works but when I go to turn on heat I get a humming noise only 2009 or 2010 Mobile home unit
turn power off and put red wire in with white wire at tstat and turn power on. if heat works it's possibly a configuration issue or a tstat issue. keep us posted.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Nov 03, 2017 | Intertherm Heating & Cooling
Intertherm heating unit shakes and making sounds
you either have dirt on blower wheel or it went out of balance. have had some that center hub comes loose. if its not dirt on fins wheel is bad
Feb 13, 2012 | Intertherm Heating & Cooling
Have an Intertherm thermostate in mobile home controlling gas hearing and elec ac. Blue wire to thermostat connects to the "A" terminal on the thermostat...Blue wire goes to a terminal on the...
If there are only two wires going to the thermostat? Then you will not be able to use a Digital Programable stat. Intertherm and Coleman furnaces do the switching different than regular furnaces. They use the switching from heat to AC at the furnace with the rocker switch. They use the thermostat to either break the connection or make the connection. They use a heating only thermostat.... Hope this helps
Jan 02, 2011 | Intertherm P3RA-048K Air Conditioner
I have a Intertherm outside AC & it was put in when the mobile home was built(1982) and I do not know what it is, I only can find the name of the manufacture, where would I find the model, & other...
mobile homes have split units, I would check the unit inside to see if it has any information. I would check all breakers inside and out, and thermostat. Hopefully it will be something simple. Good Luck Tim
Aug 09, 2010 | Intertherm P3RA-036K Air Conditioner
Intertherm ac/heater in a mobile home shuts off and won't come back on for quite a while. Then it runs fine for days, weeks, sometimes months. HELP
I am assuming it's an electric unit (most are). Sounds like there is a low voltage short somewhere. This could also be a thermostat problem as well. If it were a relay switch, it would not work at all because when they go bad, thats it they dont work anymore. There isn't an inbetween. I'm leaning more towards a low voltage short. Make sure that your low voltage wiring is tight and not loose. Be careful not to work on the unit with power to it.
Mar 14, 2009 | Heating & Cooling
Wiring diagram for intertherm ac heating unit
Your best bet is to contact Intertherm and see if you can get the Installation/ owners guide.
Dec 21, 2008 | Heating & Cooling
Heating problems
It sounds like the unit is going into a defrost cycle, which is normal for heat pumps and means all is working ok when it gets around 35 or colder they start to do this more often when the red light goes back off , the outdoor fan should come back on. You may also notice steam (may look like smoke) coming from outdoor unit. Is that what happens??
Jan 15, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
272 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Bill Long
john h
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
