Mit WD-52527 Flashing Green Timer Light
I too am having the dreaded flashing green led problem. A service technician stated that I needed to replace the DM assembly, but i would first like to try replacing the capacitors myself. Can you assist me as to which caps need replacing and if there is any recommeded changes to the values of these caps.
  • judegibby Nov 24, 2008
    WD-52527 Prjection set with flashing LED. Removed the DM board and noticed that there was 12 capacitors replaced beforeon this board. Very upsetting since I bought the set new and it has never been serviced before. All of the caps appear to look normal. I went ahead and replaced all 12 again but still have the same problem. Any thoughts???
  • 4,806 Answers
If you have changed all 12 caps and you still encounter the same problem then it has to be the DM assembly amongst other problems which i doubt you are aware of, unless the circuit board itself has burnt that the capacitors were replaced on, have you had a good look at this circuit board?
If all seems fine then i recommend you call a service engineer to look for other possible problems
hope this helps
regards
Posted on Nov 24, 2008
    Novelist:
  • 98 Answers
It sounds to me like your local electronics store got one over on you. I would consider bringing this issue to management's attention and if you get nowhere with them, I'd report them to the manufacturer. Given the fact that it looks like you have a 52", I'd even consider filing suit against them. After all, I'm sure that your TV wasn't cheap. If you can prove that they wronged you, you could be entitled to up to 3 times what the TV is worth. Just when I think that I've heard it all... Really sorry to hear about your misfortune. Hopefully this info proves to be useful.Try to have yourself a nice evening!
James
    Sergeant:
  • 276 Answers
I think going with the technicians advise is much advisable.as he is right .the unit may by chance work if u change the capacitor or any other electrical component but will not work for long period as the assembly needs replacement. the engineer is right.carry forward.
  • 734 Answers
Follow the guideline from link---
http://www.hdtvoice.com/voice/archive/index.php/t-20219.html
Posted on Nov 19, 2008
  • futureloginn
    futureloginn Nov 20, 2008
    follow the above links for flashing green light problem---
    Refer to Page 11 of this Owner's Guide (.PDF) http://www.mitsubishi-tv.com/img/220523#...'s%20guide%22) for indicator light displays.
    Click here http://www.google.com/search?q=cache:Z1F...'s+guide&hl=en&gl=us&ct=clnk&cd=21) for HTML.
  • futureloginn
    try that--
    Re: Mitsubishi WD-52525 Blinking Status Light:
    Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
    The Power light will start to flash in a two digit sequence.
    For example, 3 flashes, then 7 flashes = 37.
    Here are the error codes, and the corresponding problem:
    12 = No error detected, check power supply.
    32 = Lamp Cover is open.
    33 = Air filter cover is open.
    34 = Lamp abnormality
    36 = Light Engine (DMD or Lamp Fan stopped)
    37 = Exhaust or Lamp Ballast Fan stopped
    38 = Lamp Temperature High
    39 = DMD Temperature High
    41 = Short is detected
    44 = DVI cable between FMT and Engine disconnected
    Master:
    Sergeant:
  • 449 Answers
Hi!!
try to locate the capacitor was blown
and replaced it use a tester!!
  • 19,396 Answers
Can you see if the capacitor have blown?
If the TV had not been tested personally are not necessarily the caps, what is the problem in detail?
  • Ginko
    Ginko Nov 19, 2008
    No answer, there are 7 C9 capacitors that must be tested.
    They are all 680uf 25V, you can replace them with 50V, but this can endanger more parts in case there is the same problem again. Better to stick with factory specs.
    If you give me more details I can tell you with more precision what to do.
I hav a mit 65 in tv model number wd 60737 it comes on with the words welcome mit and green light blinks and then shuts off.
Does the led light flashes green continually?
Check if you can access the operational error code. The TV must be in shutdown and then press the front panel "activity" and "channel down" at the same time and hold them for 5 secs.
Led light will flash 2 digit code separated by a pause.
23 - 2 blinks pause 3 blinks
Let me know the result...
Nov 16, 2011 | Mitsubishi Televison & Video
WD-62525 green timer light keeps blinking after lamp replacement
Did you let the green light flash for about 70 seconds? It goes thru a self check when plugged in and takes a little time
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Mitsubishi wd-52628 flashing green timer light
If the power/timer led is the one blinking constantly
the most likely problem is two 3300 mfd caps and 1 to 8 1000mfd caps on the power board.
could be the DM board or caps on it as well.
Jun 17, 2008 | Mitsubishi WD-52628 52" Projection HDTV
WD 52525 52" 2 1/2 yrs Problem with EPROM
the flashing is a code can you tell me how many times it flashes?
Dec 18, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
278 people viewed this question
Top Televison & Video Experts
