Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
My black ink cartridge
My black ink is still not working even though I put in a new cartridge. What is wrong and what do I need to do? I see from the blog that this is a common proble. HELP
  • sizzle24 Feb 11, 2009
    my black cartridge is not working and it's new sizzle24@sbcglobalnet
    President:
  • 1,257 Answers
Follow the articles
1 Make sure the printer is on.
2 Lift the scanner unit until the scanner support keeps it open.
The print cartridge carrier moves and stops at the loading position.
3 Squeeze the tabs on the cartridge lids, and then lift the lids.
4 Remove the old cartridges.
5 Remove the stickers and transparent tape from the bottom of the cartridges.
6 Insert the new cartridge. Make sure the color print cartridge is
secure in the left carrier and then snap the lid closed.
If you are installing a black print cartridge, make sure that it is
secure in the right carrier, and then snap the lid closed.
7 Lift the scanner unit and push the scanner support back while
lowering the scanner unit until it is completely closed.
clean the black cartridge maybe dry up and fix it firmly. touching to the holder.
verify that the new black cartridge is not empty. else clean the pin touching to the holder.
http://www.google.co.in/url?sa=t&source=web&ct=res&cd=10&url=http%3A%2F%2Fsolutions.brother.com%2FLibrary%2Fpdf%2Fpdf-2700%2Fhl2700_tn_eng.pdf&ei=qWklSYulF5GYsAPRnYSADw&usg=AFQjCNFv49E3vrfRxw1WECg1Kc9GWgP-pw&sig2=NW91eX3PHasbq7WcNwPCVQ
http://www.ccs-digital.com/cartridgeproblem.asp
Posted on Nov 20, 2008
My printer will not print black ink, says I need to remove tape from cartridge? the ink is partly gone and has been working and is not empty.it will be a cppier and do it but not from computer.
Mine did same ....turned out I was out of ink.....even though the estimated levels say I had a full black and near empty color ...went to store picked up a color cartridge ..put it in and it still gave me the same err message [allignment prob please remove tape] thats when I tried to clean cartridges and there wasnt any black ...soI went out & got a black also ...put it in and wala Im back in buisness...accept for the wrong messages or is it a software prob?
Sep 14, 2010 | Dell V305w All-In-One R840635AU InkJet...
The black ink wont work, even though i have put in a brand new cartridge. the tri color works fine, but the black ink must have something funky going on
Try the following things:
  1. remove the cartridge make sure that you have removed any tape or guards that came with the cartridge to keep the ink from leaking
  2. try gently squeezing the cartridge. if you can get a drop to come out of the cartridge.
  3. if you cannot get a drop out, put the head of the cartridge on a piece of a dampened napkin or paper towel. You should see some black bleeding out of the head. Sometimes, it can take awhile for the ink to loosen up.
  4. reinstall the cartridge and run the head cleaning program for your printer if you have one
May 27, 2010 | Canon PIXMA iP90 Mobile Printer
Black ink won't print even though the cartridge is
It could be you just have a bad cartridge, If it's new, take it back and get a new one to make sure it's not the cartridge. If you get the new one and it still doesn't print black, then you have a bad print head. Meaning it would need to go to a service dealer to replace or repair the print head.
Thanks Mark
May 14, 2010 | Brother DCP585cw AllInOne InkJet Printer
Black Ink Cartridge not being recognised
Did you make sure to pull the plastic strip off the cartridge?
Feb 15, 2010 | Dell Photo 964 All-In-One InkJet Printer
It will not print in black ink even though I put a new black ink cartridge into the machine
Hello sir, good day, If you cannot print black ink on paper even with new cartridge on the machine, the cradle is dirty, the thing that holds your ink cartridge.
The ink flow is from the cartridge to the cradle then to paper, check the cradle, for proper cleaning.
Nov 13, 2009 | Computers & Internet
I put a new black ink cartridge in the printer. When attempting to print, no black ink is being used, just color ink, even though the little level indicator on the printer window the appeared when one...
goto maintenance, on the panel of your printer..choose clean printhead..or wipe your black cartridge with a wet cloth..maybe your cartridge suffered clog that covered the nozzles ..
May 13, 2009 | Dell 926 All-In-One InkJet Printer
Epson 830u Printer Red light stays on even with new ink
I realised that I had to replace both the ink cartridges even though I only wanted to replace the black for it to work. Once I replaced both the black and colour cartridge the red light went off. Thanks
Feb 11, 2009 | Epson Stylus 830U InkJet Photo Printer
Replaced black ink cartridge and it says its low
Some newer printers, such as Lexmark, will have a place in the properties app that allow you to "tell" the printer the cartridge is new. Check yours and see, it fixed mine.
Jan 04, 2009 | Dell 922 All-In-One InkJet Printer
Cannot get yellow to print
I had the same problem with the yellow cartridge. Yellow quit printing, put in a new yellow and still would not print yellow. I had a help file, don't know where I got it, but it suggested replacing the black ink cartridge also, even though the black wasn't low yet. Replaced the black, ran a few nozzle cleans and everything worked fine. Don't know why. Try it
Mar 03, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
87 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
