Question about Sony HMD A400/L (Blue, Silver) 19 in.CRT Conventional Monitor
When working on something , monitor goes into standby mode ?
I have a sony HMD-A400 CRT Monitor , It will shut down and go in to standby mode when ever it pleases, I sent it to sony a year ago and they said it was a cooked wire, they fixed it at no charge and sent it back to me.
also from a cold boot the monitor turns red, gold, green, and when
the picture come up it looks blurry and not so clear but it work fine after that, this stuff started about a year after I bought it, I would love to get it fix someway, or is it on it's way out, this thing cost alot of money and sony won't do any thing but charge me a lot of money to get it fixed, they said to trash it, I think sony is crazy, because I didn't play football with it, it's a computer !! can any one help, I really like this monitor a lot and want to keep it, I have another HMD 17'' that works
great and is older than the 19'' which was the new add on to my system. Please help, everybody runs when I say can you FIX this
  • 624 Answers
SOURCE: Sony SDM-HS74P/S 17 - Monitor won't stay on the right picture
When the screen turns black again take a flashlight and shine it in the bottom left hand corner where the Windows Start button is located. If you can see a faint image then your back light is failing. If that?s not the case the next step would be to attach another monitor to your computer to see if the problem disappears. If it does that points to the monitor, if it doesn?t then we need to take a look at the computer itself. Let us know what you find out and please don?t forget to rate this posting.
Posted on Mar 16, 2007
  • 624 Answers
SOURCE: Sony SDM-HS74P/S 17 Monitor won't stay on the right picture.
This is a duplicate post, click the following link to read the active posting:
SOURCE: Sony SDM-HS74P 17" Monitor goes black after turning on
Most likely you inverterboard went bad on the monitor.
Posted on Nov 11, 2007
SOURCE: Sony SDM-HS73 Not Staying On
The problem is with power inverter, usually the capacitors go bad and need to changed, they might be bulged and or leaking. Very cheap fix, less than a buck apiece and an hour with a solder iron. Google it to find more info.
Posted on Feb 20, 2008
  • 19 Answers
SOURCE: Sony 24'' CRT widescreen GDM-FW900 blurry after initial on
CRT shorts are common with this model and focus problems are a major symptom. however, the loud 'pop' you described leads me to believe that the flyback transformer may have a problem in the focus divider portion. replace the flyback, if that fails then the CRT is most certainly the problem
Posted on Dec 10, 2008
My Sony HMD A200/L 17 In.CRT Conventional Monitor is completely black.
the clicking sound inside the monitor says that there is a signal coming from the computer. but if the computer video card is bard you never get picture. Yes this is fixable , sometimes some capacitors busted inside your desktop and have to be replaced or the video card is bad. depending of your computer tech experience , replacing capacitors is easy for experienced tech as me. if the video card is died there is a way to put in another video card.Go ahead check with your local computer tech,He will help you
Mar 16, 2012 | Sony HMD A200/L 17 in.CRT Conventional...
I hooked the sony hmda400 to a asus computer and cant get any sound from the monitor. Help!
This monitor doesn't have speakers. You need to use a separate audio connection - from the Line out of your Asus to the input of a separate audio amplifier.
Apr 17, 2011 | Sony HMD A400/L (Blue, Silver) 19 in.CRT...
Could you pl. tell me the wattage (power) required by Sony HMD A240 monitor, and Sony PCV 7752 computer? Thx
on the back of your equipment , there a small piece of paper where you can find all that information. Power= Voltage x current , you will see for 12VDC and 2.5 A . then multiply the two . that is simple
Sep 12, 2009 | Sony HMD A200 Monitor
Red screen and lines, then TV shuts off automatically
Adjust RED screen drive down, or disconnect,unplug CRT board from red tube turn set back on if it plays without shuting off RED tube is shorted or video IC on CRT board is bad.
Jun 19, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
System shuts off and turns to red light standby
Hello. You may want to double check your connections and cables. The only time I've ever heard a clicking before a system shut it's self down was when a kid had stuck the battery cover from a TV remote into the disc drive.
Also, if the PS3 keeps acting like that, Sony will repair/replace the unit for free including shipping since it's under a year old. Thanks and good luck!
Jan 09, 2009 | Sony Playstation 3 (PS3) Console
Sony bravia 46''
It sounds like it is defective, you have warranty call for service!
Jun 13, 2008 | Sony BRAVIA KDL-46V3000 Television
Sony hmd-a400 monitor
Next time you get it running, right click my computer>properties>hardware tab>device manager and look for your monitor on the 'Monitors' '+' sign and right click>delete. Also check 'Display adapter' see if the correct driver is displayed. Re- boot and let Windows re-install monitor driver(it should list it as 'Sony')
Nov 30, 2006 | Sony HMD A400/L (Blue, Silver) 19 in.CRT...
Sony HMD A400/L (Blue, Silver) 19 in.CRT Conventional Monitor Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
