Question about Acer TravelMate 2201LCi Notebook
When on AC will not charge or operate as AC powered.
Acer Travelmate 2201LCi
Problem started as intermittent. Now when on ac will not run except as on battery. When I power down and am plugged in the battery will charge. Also see that only one of the two fans operate except when I first start up then both work.
Any insight will be helpful.
Thanks,
Del
  • 458 Answers
You Need To Replace The DC Jack..< the port where your AC Adapter plugs into the laptop>
Posted on Nov 19, 2008
My Acer Travelmate 7530 does not want to start up. Switch on button lights up green
Here below is possible cause and troubleshooting steps of laptop that can power on, hope it may help:Possible cause:
AC adapter failure.
Power jack failure.
Motherboard failure.
Possible troubleshooting steps and repair solution:
Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
If you are sure that your laptop charger is malfuction, just get a new adapter from chargerbuy.com:
http://www.chargerbuy.com/replacement-acer-travelmate-7530g-ac-adapter-19v-90watt.html
Oct 28, 2012 | Acer TravelMate 7530 Laptop Charger...
The initial battery of my Acer Travelmate 2480 packed up and I ordered and installed a new one. However, the laptop remains on "AC Only" power and the battery is not charged, giving a...
RTFM You can download the manual by googling "acer travelmate 2480 manual" (without the quotes). Or just click here
According to the Acer manual:
"Conditioning a new battery pack
Before you use a battery pack for the first time, there is a
"conditioning" process that you should follow:
1 Insert the new battery without turning the computer on.
2 Connect the AC adapter and fully charge the battery.
3 Disconnect the AC adapter.
4 Turn on the computer and operate using battery power.
5 Fully deplete the battery until the battery-low warning appears.
6 Reconnect the AC adapter and fully charge the battery again.
Follow these steps again until the battery has been charged and
discharged three times.
Use this conditioning process for all new batteries, or if a battery hasn't
been used for a long time. If the computer is to be stored for more
than two weeks, you are advised to remove the battery pack from the
unit.
Warning: Do not expose battery packs to temperatures below 0°C
(32°F) or above 60°C (140°F). Extreme temperatures may adversely
affect the battery pack.
By following the battery conditioning process you condition your
battery to accept the maximum possible charge. Failure to follow this
procedure will prevent you from obtaining the maximum battery
charge, and will also shorten the effective lifespan of the battery.
In addition, the useful lifespan of the battery is adversely affected by
the following usage patterns:
• Using the computer on constant AC power with the battery
inserted. If you want to use constant AC power, you are advised to
remove the battery pack after it is fully charged.
• Not discharging and recharging the battery to its extremes, as
described above.
• Frequent use; the more you use the battery, the faster it will reach
the end of its effective life. A standard computer battery has a life
span of about 500 charges."
Jun 16, 2011 | Acer TravelMate 2480 PC Notebook
Travelmate 2700 will run on AC from power supply but will not charge battery. Have fitted new battery
so most likely the problem on a faulty battery because the battery will not accept a charge or charging.
Apr 11, 2010 | Acer TravelMate 2700 Notebook
How do i get to bios on my usb is switched on acer travelmate 220 to check if my
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses theCtrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 orCtrl+Alt+Esc keys to access BIOS.
Mar 07, 2010 | Acer TravelMate 2201LCi Notebook
Just bought a second hand acer travelmate 4200. I have never owned a lap top. How do I change from using battery power to outlet power
On the left side, towards the rear is a DC jack. Plug the power cord in there. It should automatically start operating on AC power, and charge the battery.
Feb 24, 2010 | Acer TravelMate 4200 Notebook
Travelmate only powers up with battery inserted. But AC still charges battery. Orange light goes on and of
Sorry to tell you this but you may have a problem with the charging system. That will require you to return it to Acer or an Acer service center. You can also try this. I got this from Acers' travelmate support website:
If the notebook does not power on:
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a ‘power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
You can aslo google your specific model of Travelmate to see if others are having this issue.
Les
Jun 27, 2009 | Acer Computers & Internet
I have an Acer 2201LCi laptop forgot the logon Win XP password
you can use password reset tools that boot into dos and modify the sam try googling for them as I cannot supply the tools
Mar 14, 2009 | Acer TravelMate 2201LCi Notebook
Battery works and then doesn't
first off all remove the batterey and just connect the laptop directly to the power adaptor and check out is it working properly with out battery as it should work without battery on power adaptoir.if it works that means the battery is faulty if it does not works that means the laptop main board is having loose connection problem get it repaired do not do it your self very risky.
Mar 02, 2009 | Acer TravelMate 2201LCi Notebook
Laptop Acer does not see AC power
ok..try it without the battery installed at all, and let us know how that works..AC power only..
Mar 23, 2008 | Computers & Internet
Travelmate 2300 won't power on
The problem could be your bezel.  Remove the 3 screws from the hinges from the rear and you will be able to remove the black strip above the keyboard (after removing the screws, make sure laptop is layed wide open)  once removed, press the button on the motherboard under where the power button is.  If the unit still does not power up, then your motherboard is bad and needs to be replaced.  If it does power up, you need to replace the bezel.
Oct 18, 2007 | Acer TravelMate 2300 Notebook
Acer TravelMate 2201LCi Notebook Logo
109 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
