Question about Dryers
I need a wiring diagram and flow chart for a unimac dryer
I have power to the machine, and 24 volts to the circuit board at the front of the machine, but it will not start, and the controls, including the LED's are dead. I don't have a wiring diagram or any kind of flow chart.
If there was one with the machine, someone took them. The machine is only about 1.5 years old I think.
This is a Unimac commercial dryer
Model # UTO75NQTB1G1WO1
Serial # 0603000179
  • 1462 Answers
SOURCE: The Drum on my LG DLE2512W Dryer will not turn
no problem with motor or control board. fault is with the motor capacitor only. this is often attached to the motor or near it. the value of the capacitor will be printed on it (usually about 8uf) and you should be able to source from an electrical spares shop
Posted on May 23, 2007
SOURCE: Same problem- microwave shuts off
Thanks for the help. I replaced magnetron and problem is solved.
Posted on Mar 10, 2008
jsrock516
  • 5911 Answers
SOURCE: WIRING DIAGRAM
The following link explains the proper wiring scheme for installing a 220VAC power cord to an appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Make sure you also have a dedicated outlet and power source for your dryer. This means a single outlet with a single circuit breaker. Most homes are constructed this way to ensure safe operation of the appliance and to prevent improper loading. If you have questions, please let me know.
As far as a wiring diagram is concerned, most manufacturers place a schematic drawing inside the operator console of the appliance for troublshooting purposes. I hope this helps.
Posted on Oct 16, 2008
pollyluvpat
  • 103 Answers
SOURCE: samsung front load dryer had a burning smell-it
ck recalls on this issue.
there may be one.
under warranty??
do not buy samsung they are notorious for having problems.
sounds like the heating element and relay may have went out.
however if it does not start up at all it could be the motor itself.
Posted on May 14, 2009
jumptrout51
  • 3361 Answers
SOURCE: Replacing Control Board on Frigidaire model LEQ1442ES0 Dryer
There should be screws on the back side of the top panel that come out. Then the panel will slide out so that you can access the front controls.
Posted on Aug 18, 2009
Need wireing diagram for 2002 focus split port am came& crank sensor diagnostics flow chart
Google for it, ask dealer for it, Possibly library repair manual.
Mar 04, 2015 | Cars & Trucks
Frigadare Dryer
Basic Dryer Electrical
Electric dryers in the US operate on two 110 volt A/C circuits. The two 110 volt circuits combine to deliver 220 volts A/C to the dryer heater. 2-dryer-plugs.gifSee the basic dryer heat circuit. The dryer motor operates on 110volts A/C. Dryer receptacles have an L-shaped neutral post. You can check the voltage to your dryer by slightly sliding the cord out of the receptacle and using the leads from a multi meter to check for voltage on the blades of the cord that slide into the receptacle. Between the left and the right blades you should read 220 volts. Between the left or right blade to the center blade (the L-shaped blade) you should read 110 volts AC. The 4-post receptacle above has the L-shaped neutral and a seperate ground. It requires a 4 wire cord and the ground wire is isolated from the neutral on the dryer.
Technicians check for voltage when the dryer is attempting to start or not heating for a very specific reason. Checking for voltage without the dryer plugged in does not tell the full story. A dryer heater uses 220 Volts and draws about 20 amps when it is heating. Checking for voltage from L1 to L 2 on a defective circuit may show 220 volts but when the heater kicks in and starts to draw 20 amps the voltage may drop off to 0 volts. Imagine the wiring to your dryer was stranded wire. Stranded wire is composed of a number of small-gauge wires bundled together to make a larger wire. What if all but one of those stands were cut and only one small wire was completing the circuit? Reading voltage at the receptacle without the dryer plugged in you would read 220 volts from L 1 to L 2. However with the dryer plugged in and the heater attempting to draw a heavy current, the electrons (current flow) would be dammed up behind the cut and only a small amount of current would pass through the wire. Certainly not enough to make the heater heat. There are a lot of things that can cause a partial circuit but the result is the same as the stranded wire example. Many a heater or dryer motor has been changed needlessly because of a loose connection in the fuse box / circuit panel or some other dryer electrical circuit problem.
Aug 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
How to trouble shoot the fan after it was exposed to spikes in the power supply
You have an owners manual with a trouble chart
to follow?
If you pay for service, they won't come for two weeks,
& then leave for a week, until the parts come in
The parts come in one day ,they come back in one week with
them,now you got no dryer for three weeks
Need to diagnose this yourself
If you have the manual & wiring diagram, you may have
to test down to the circuit control board, as I did with a
washer, not a year old
I had no power spike & it failed & all tests passed in the
diagnostic manual,just had to go for the board
Doubt the fan is ruined from the power company issue
The electronics are more likely
Nov 25, 2014 | Dryers
Unimac washing machine is displaying FULL & cant open the door
Try unplugging the machine for a few hours to rest the code on the board.
Oct 14, 2013 | Unimac Parts Unimac 1300757 Washer HOSE,...
I was expecting to find this relay. It's not there. My unit has a rather complicated looking circuit board. The circuit board seems to have been made by Emerson Climate Technology. On the top edge of...
this board needs a 24 volt supply run from the furnace to power up the communicating board
check your wiring diagram on the inside of the panel this will help you
Apr 04, 2011 | Amana Heating & Cooling
My aprilaire 700 isn't coming on (no water flow). The front part of the unit has fallen off the furnace twice (held on by plastic nubs/slots...) and blew the furnace fuse/ and circuit breaker probably...
Check for voltaged at the solenoid valve. This will either be a 24 volt or 110 volt solenoid valve. Confirm power into the unit 110 volts. If you have power into the unit and no voltaged at the solenoid valve on a call for humidification at the humidistat than the circuit board or the step down transfgormer has failed.. If you do have voltage at the solenid valve than the valve has failed.
Jan 26, 2011 | Aprilaire 700 Humidifier
Wiring diagram for Thermoking V700MAX
Red or R is the "Hot leg" of the Transformers 24volt supply,
Common or C is the "Neutral leg" of the Transformers 24 volt supply;
and the side of power to which ALL the 24 volt control circuits
terminate to complete the circuit, example; Heat=W, Cool=Y, Fan=G.
Upon a call for heat a switch closes betwen the Red and White Thermostat terminals.
The stat sends the 24 volts to White or W for the heat circuit on W on the
furnaces LVTB low voltage terminal board.
Yellow or Y goes from Thermostat to furnace Y on LVTB, which is simply
a connecting point on its way to the AC units 24v contactor coil located outdoors.
It actually isnt even attached to the furnace many times as it serves no purpose there and simply
continues to the AC unit with the copper lineset that the AC unit feeds.
The remaing 24 volt Thermostat wire goes back to common on transformer to complete the Yellow
24 volt control circuit.
Green or G exits the Thermostat and connects to G on LVTB for the fan relays 24volt coil
and returns to Common to complete the Green 24 volt control circuit.
O is for a Heat pump reversing valves 24 volt solenoid, and return to Common as all 24v circuits must to terminate or complete the circuit.
Some parasitic type Termostats need the 24v power to run, some are battery, some are both.
Nov 01, 2010 | Heating & Cooling
No water flowing to water panel but have water to the solenoid. I have a Aprilaire model 550. wondering if the solenoid is bad and how do I check it.
To test solenoid, apply 24V directly to the terminals as see if water flows through it. Alternativly, turn everything on, ensure that there is 24 volts accross the solenoid wires, if you show 24Volts and no water, solenoid is bad. To test you will need to set your meter to AC Volts.
If you have a separate black transformer supplying the 24 volts, hook that directly to the solenoid. You may also be getting the 24Volts from your furnace circuit board, if that is the case you will see two terminals usually marked HUMIDIFIER on the furnace circuit board (you will need to open your furnace usually 4 screws or so.) There is 24 volts there WHEN THE HEAT IS ON , run two new wires from those terminals to the solinoid and see if it passes water cuz that is when those terminals have voltage. Best way is with a meter though and if you have 24 volts at the solenoid AND no water, it is bad. If NO VOLTS, then could be the the humidistat or a disconnected wire somewhere in the path.
Dec 26, 2009 | Aprilaire Humidifiers
My maytag neptune has no power any suggestions
Check for ~220 volts AC across the two slanted contacts on the dryer power socket. If nothing, check the house electrical panel for tripped dryer circuit breakers(pair)--push the breakers OFF, then ON to reset. Recheck for 220 volts at dryer socket--if ok now, try the dryer. You need to use a voltmeter for this checking. If it starts, then quits, you likely have an internal short (heating element) inside the dryer case that trips the circuit breakers.
Jul 23, 2009 | Maytag Neptune MAH9700 Front Load Washer
No Power to dryer
The first thing you need to check is the breaker. turn all the way to off then back to on. Next you need to make sure there is power to the appliance, a volt meter is crucial for this. If you have no access to one, unplug the cord from the wall, remove the little plate on the back of the dryer where the cord attaches. Look at the connections. If all is good and you can check for power all the way to the connections behind the plug, then the control board may have a fuse designed in it. This is a new machine, and they all have circuit boards. The board will be on underneath the top where the controls are. If you can or know someone who can read a wiring diagram, he/she can look at the one on your machine and tell if there is a fuse.
Dec 19, 2007 | Dryers
Dryers Logo
664 people viewed this question
Top Dryers Experts
Marvin
Marvin
