Printer will not grab paper
I have an HP 2570 printer that will only grab one piece of paper at a time. If the paper tray is filled with paper the machine will not grab the next sheet of paper and the machine indicates it is out of paper. I have tried to clean the rollers but no luck. How difficult is it to take apart the printer and really clean or replace the rollers?
    Scholar:
  • 78 Answers
Check to make sure the paper sensor tab moves freely. You might try air dusting around the paper pick-up rollers to make sure the area is free from any accumulation of dust, dirt, or paper residue.
Posted on Nov 19, 2008
  • 300 Answers
You may need to obtain the HP Paper Feed Cleaning Kit from Customer Service by contacting them here. While your speaking with them you may want to ask about any issue that have came up with your particular model because I have read they have replaced some models that were even out of warranty.
To use:
It seems that by what Im reading, this is mostly caused by a dried out roller (especially if they are grey so you also may have some other options:
NOTE: These options may void warranty.
  • You may try applying a thin layer of vaseline on the rollers that pull paper. You can usually access these rollers from a door at the back of your printer. This should also soften the rubber. I would suggest running a sheet of plain paper through a couple times to clean off any excess.
  • You can try the Rubber Rejuvenator listed here.
Hope this helps. Please remember to rate this information.
Thanks
Manual feed won't grab paper
If the printer works good when it prints the envelopes/label one by one, I think it works normal (because the paper is not a standard paper).
Mar 06, 2014 | HP Office Equipment & Supplies
Paper jammed
Lift up the upper section of the printer (just like you were going to replace an ink cartridge) and look for the smallest torn piece of paper hiding in the gears. Then tip up and gently remove the top (black) paper tray assembly and remove any paper in the tray. Grab a flash light and check the "in" feed area.
Put it all back together and hit "start copy". If noting still clears the jam unplug the printer (power cord) from the wall, wait 30 seconds and plug it back in.
Hopefully that clears the paper Jam message.
If not call HP Support Center @ 1-866-408-5408. They're available 24/7.
Jul 25, 2012 | HP Officejet 6500 AllInOne InkJet Printer
Will not grab paper. says out of paper when its not
You can try cleaning the rubber wheels with alcohol. Sometimes they become covered in dust and won't grab the paper.
Apr 08, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Having a problem with prtinter it's not feeding right keep feeding from right side...tried putting one paperat a time but still not feeding right....PLEASE HELP...
Using high cotton paper causes cotton dust build up making it hard for the rubber rollers to grab the paper. Check inside for paper dust build up. If so, clean rollers with a window cleaner.
Another problem is saving too much money on paper. There are some very thin light weight papers which the printer rollers have a hard time gripping. Most printers do well with 22 lb paper. Otherwise you may need to put a piece of scotch tape under the roller so the machine can grab the thinner paper.
Also check your side paper alignment guide in the tray. As well as making sure your paper is sitting all the way back/down in the tray.
Apr 13, 2011 | HP PSC 1610 All-In-One InkJet Printer
My printer is now 2 years old. Always done great, nothing happened. But now he can't get the A4-paper out of the tray. He trays to grab the paper, but it doens't work. Photo's out of the photo-tray is...
Looks like you have a paper jam problem.Pieces of paper are stuck in the roller.Go to Control Panel ->Printers and Fax -> Select you printer and click properties.You will find a Printer Maintainance Wizard,which will have a paper jam clearing wizard.Click this and your printer will work as good as new.
Thank You.
Feb 20, 2011 | HP Photosmart D7160 InkJet Printer
Paper tray 2 is stuck -- cant move in or out
the paper lifting rack plastic tabs one of them is broken and the metal that is showing is catching on the guide so the lifting rack is not lowering into place, turn the printer around, remove the door that hides the back of the paper tray, grab the paper size tab and pull it out as far as you can, now get a flash light and either a ruller or a long screw driver and push the lifting rack down into the tray flat and then push the tray out of the printer. once this is done you can examine the broken tab on the lifting rack and call hp for a part number, get a whole baggie of the pieces because they break all the time!!! you can use some fabric medical tape to make a quick and temporary repair. but it will ware out and you will have to do it again. good luck.
Microapex Computer Systems and Printer Repair Center
www.microapex.com
Feb 02, 2011 | HP LaserJet 3600n Printer
Can't print on photo paper from iphoto
When running a piece of photo paper through the printer you must first remove the stack of regular paper from the tray and run only one photo paper at a time. Thank you, Dana
Oct 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
Paper in lower tray is not being "grabbed" by rollers to start the print or fax job.
I think you need to add some paper to it so that the printer will easily pick them,,,,or arrange the paper onto the tray..
May 17, 2009 | HP 4110 All-in-One USB Printer/Copier/Fax
My L7580 grabs too many pieces of paper. Instead of one sheet it grabs 4
Time to replace the paper pick rollers located in/near the tray and above on the pick-arm or paper path
May 17, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP Photosmart 3310 does not recognize paper in tray
This is usually do to a sensor, your correct on that, thers usually a plastic piece that indicates theres paper and its broken or worn.
The other thing is that it may be the little rubber grabber is worn and not grabbing the paper, so the printer thinks thers no paper because nothings going through. These parts can be orderd but are usually costly depending on the printer. If its under warranty, take it back.
Also, check the trey and make sure it isnt a I.D.10.T error and you just set the paper to legal or something. I've made that mistake before.
Nov 27, 2007 | HP Photosmart 3310 Printer
768 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
