Question about JVC RX-8010V Receiver
Reciever Shutting Down
I've had my JVC RX-8010V receiver for 6 years now with no problems, until recently. Today it suddenly shut down and after turning it on again it shuts down several seconds later. I'm using a USB connection with my laptop and I use it for music composition. I'm wondering if it is possible for the receiver to be sabotaged by a hacker? Any help would be appreciated, thank you.
  • punkedphuck Nov 18, 2007
    JVC RX-8010V started shutting down on its own last night. I assume it has been overheated or something, I Have had it for about 4 years now and this is the first problems. The reciever starts up, them a few seconds later shuts off. Please help!
I replaced R916 with a 10 ohm wire wound resister and that fixed the problem on the unit I have. That resister is in serise with R 915 so they should be close in value. Both were marked 8 ohms but tested about 11 ohms on R915 and the bad one tested very high (over 1 meg) so I replaced it. When I first put it back together it didn't work but I noticed that the ground screw at EP901 was not retighted so be sure that all ground screws are tight and all conections are redone before testing with the power cord.
Good Luck,
Thomas
Posted on Aug 06, 2009
SOURCE:
I bought Yamaha RX V565 4yrs ago, then after 2 years, may receiver always shut off 5 minutes everytime I open. What is the problem or reason of shutting down my receiver? Thank you
press and hold both the "DIRECT" and "TONE CONTROL" buttons and press power and see what it says on the display. This will give us some idea of what is causing the receiver to turn off.
Mar 30, 2015 | Yamaha Rx-v565 Receiver
JVC RX-801V - No sound from right channel in speakers or headphones.
I'd troubleshoot first, even though you've already tried the headphones (good thinking). Get a battery (AA battery works) and put the black and red wires on opposite sides to see if the speakers are working.
Is there a menu of settings on the jvc, and is it set to 5.1? Just trying to help...
Jan 15, 2012 | JVC RX-8010V Receiver
I have jvc rx 801vbk and it is not putting a sound out i am positive it is not the speakers problem ??
Before you go crazy, and before you do anything, and before you take any of the above advice check the fuses!! Pop the top, look straight down to see 4 or 5 'buss' fuses. Lift at least one end of each fuse and check for continuity with a simple volt-ohm meter. I bet you find at least one bad. Bear in mind it blew for a reason so procede with extreme caution.
Mar 20, 2011 | JVC RX-8010V Receiver
Around 4 second after power up the unit shuts down..
my jvc rx-8010v turns on and after 4 seconds it shuts down.
Jan 05, 2011 | JVC RX-8010V Receiver
I have a JVC RX-801VBK. When I turn the power on it clicks on and shuts of. please help
the problem is probably a bad power transformer that will need to be replaced the best way is to contact JVC and they will be able to help you more. it may be easier to purchase a new reciever.
Jan 02, 2011 | JVC RX-8010V Receiver
I get my receiver to about 65% volume and it turns off
Check the ohm load for the reciever, then check to see what ohms are of the speakers. make sure they match. 4ohm to 4ohm, 8ohm to 8ohm. If unit feels hot when it shuts off, it's a themal overload, put in to keep the reciever from getting damaged. It comes back on when cool right? Overload could be on its way out and shutting down at a lower temp too
Jan 05, 2010 | Yamaha RX-797 Receiver
No sound output at all
check your A-B speaker button. some have a small fuse inside.
Sep 08, 2009 | JVC RX-8010V Receiver
Yamaha Receiver RX-V630 not working (resets itself immediately)
This maybe an easy one. Have you unhooked all the wires going in to the stereo. "SP wires" means you have wires to the speakers are touching and the stereo is shutting down to avoid overloading. Hope this helps...
Jun 05, 2007 | Yamaha RX-V630 Receiver
OVERLOAD
I had incountered before VICTOR colored TV.ive found out that the problem was in the switch relay on the power supply area.. My suggestion is to check the relays wich is located at the supply board area resoldered the pin to make sure the pin is in solid contact. or put an AVR back up to your TV. If the problem still occur check the regulator IC or try to change a new IC this might help the problem.
Feb 04, 2007 | JVC (TC30EHGDU6) VHS-C Tape (6-Pack)
JVC RX-8010V Receiver Logo
786 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
