Question about IBM ThinkPad 600E 2645 Notebook
Toshiba laptop comes on then goes of again its stuck on confi 3
The laptop was going through a congieration 1 to 3 it did 1 ok and 2 but got stuck on 3 and now it just goes on and of all the time
can you help
  • 1,602 Answers
THE SYSTEM HAS TO BE TURNED ON IN SAFE MODE
WHEN YOU 1ST TURN ON THE COMPUTER WRITING WILL POP UP FAST PAUSE THAT SCREEN AND SEE WHAT KEY YOU PUSH TO GO TO RESTORE OR SAFE MODE
PICK THE SAFE MODE THAT FITS YOU BEST NEEDS.
THE MOUSE MAY NOT WORK, SO THE TAB KEY, WHEN YOU PUSH DOWN THE KEY IT WILL HIGHLIGHT THE BUTTON OR ACTION IT IS ON AND IF THAT IS WHAT YOU WANT PUSH THE ENTER KEY OR FOLLOW THE INSTRUCTION LOCATED AT THE BUTTOM OF THE SCREEN.
ROD THE CANDYMANGANDY
Posted on Feb 11, 2009
It does not read even if a bootable cd is put. It gets stuck at checking cd rom. It goes to a blue scree - mountable boot error How can I restart it with an Os
1.Go to bios(pressf2/f10)
2.select main option
3 change SATA MODE and change to IDE
4.preeF10 and save
5.then start your installation
more help please vote me and rate it
Sep 03, 2011 | Toshiba Satellite A60 Notebook
Hey there just have simple question: Is it possible to lock setting for the different modes? I have found that a little brighter for movies and games works for me but I think that it keeps switching back...
Hello
Just enter to its picture and sound settings by menu option, and do the picture setting as you interested in.
1 Press MENU on the remote control.
2 Use Up, Down, Forward, Reverse buttons to select [ Setup] > [ Picture].
3 Use Up, Down, Forward, Reverse buttons to select one of the picture settings, and press OK
to enter the setting.
4 Adjust the picture quality.
The following picture settings can be confi gured. Depending on
the format of the picture source, some picture settings are not
available
You must set [Home] in [ Location] Otherwise, the settings you adjusted will not be memorized after you
turn off the unit.
You can set the location of your TV to [Home] or [Retail store].
Choosing [Home] gives you full fl exibility to change predefi ned settings for
picture and sound.
1 Press MENU on the remote control and then use Up, Down, Forward, Reverse buttons to
select [Setup] > [Installation] > [Preferences] > [Location].
2 Select [Home] and then press OK to confi rm your choice.
3 Press MENU to exit.
Mar 23, 2011 | Philips 55PFL7705D 55" LCD TV
Divx doent work in my dvd player. dvd 5166k Phillips
hi,
1. Load a DivX® disc.
The data disc menu appears on the TV screen.
2. Press up or down to select the folder and press OK to open the folder.
3. Press up or down arrow to select a track/fi le.
4. Press OK to confi rm.
ok
Jan 30, 2011 | Philips Televison & Video
How can a remove a stuck Screw inside of a Toshiba Satellite L455-S5989 Laptop. The screw that is stuck holds down a PCIe mini Wireless Card.
Take the laptop apart techgeek564.
You Definitely do Not want it roaming around in there, to short out the laptop.
Here is the Service Manual, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Go to the 11th line down.
The one that starts with > Satellite A10
In this listing of files go down to the second line, (Starts with > C650D), and then go across to >
L450. Click on L450.
[The Toshiba Satellite L455-S5989 is part of the Toshiba Satellite L450 series ]
After you click on L450 it will take about 5 seconds to see the first page, and additional time to fully download.
(Took 45 seconds for me just now)
Suggest you let the file download all the way before looking through it.
You are not permanently downloading the file. If you want to save a copy to your computer, and do not know how, post in a Comment.
[This way you won't have to download again. You can also burn a copy of to a CD disk for safekeeping, and having access anytime you want.
Further, you can delete the file from your harddrive after burning a copy, and save harddrive space ]
A) ALL power removed from the laptop. AC adapter (Charger) and Battery.
B) Buy and use an ESD wrist strap. Connect the alligator clip to a good ground source.
(Electro Static Discharge)
Your body carries Static electricity, and Static WILL fry out (Short Circuit) the hardware components inside a computer.
The ESD wrist strap will relieve your body of Static, and safeguard your laptop from Static shock
Average price of an ESD wrist strap is around $3 to $6. Much cheaper than a new laptop.
C) Use a multi-compartment container for the various screws you will remove.
Mark each compartment for the area the screws come out of.
There may be as many as 60 screws, and 12 different types.
Do Not mix them up!
You can use a clean egg carton, and mark the egg holders.
D) Make a record as you disassemble. Make drawings and notes. Use a camera, or videocam if available.
(Use Good lighting)
It's nice to have a record to refer back to in case you get interrupted.
You may find this information to be helpful also,
1) http://www.irisvista.com/
2) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L45/laptop-disassembly-instructions-1.htm
[You are on Page 1. Page 2 and 3 links are on the Top, or on the Bottom of the page in white.
Page 1::Page 2::Page 3::Find another model ]
IF you need ANY guidance, please post in a Comment.
Regards,
joecoolvette
Nov 30, 2010 | Computers & Internet
My Toshiba laptop hangs in 2 -3 mins of starting
Ok at boot up press F8, when the Menu comes up, choose Safe Mode, but this time instead of going to the desktop, choose System Restore, follow instructions, and when the Calender type window comes up, simply choose a time BEFORE, the time it went faulty. This should completely restore you to working again. As long as there are NO other problems.
support.microsoft.com/kb/306084
Apr 12, 2010 | Toshiba Satellite A135-S2276 Notebook
Toshiba a215-s4807 builin hdd1 password please
YOu can reset bios password with 2 method.
(1) open back cover of laptop then find motherbord .Pull cmos cell from motherbord for 15 minutes then again put it in it's position .then it not ask for password.
(2)You can clear password with jumper settings find jumper on motherbord named clear cmos it has 3 pin .1-2-3
Put jumper in 2-3 position then again put it in 1-2 position then check .
Let me know if you need more assistance.
Thanks.
Nov 22, 2009 | Toshiba Satellite A215-S4807 Notebook
Toshiba Laptop Stuck in Sleep/standby Mode
maybe u got problem with the flex cable that connect the lcd to keboard/mouse
Aug 27, 2008 | Toshiba Satellite A135-S2386 Notebook
Black screen
Yes, it could be stuck in hybernation
Or.. Check to See if the Lid Switch is Stuck Down... Some laptops have alittle Movable plastic pin that depresses when the lid is closed to turn the screen off... this can sometimes get stuck down to the board button.. causing the symptoms youre experiencing
Jun 04, 2008 | Toshiba Satellite A105 Notebook
Scenium DLP quit recognizing cable signal
You may have inadvertently pressed some buttons on the remote to take it out of the mode to receive cable channels.
If you unplug the tv from the wall for a while, it may clear the error.
Step 1: Identifying Your TV’s Location
1. If your country is highlighted, press OK on the remote control.
If your country isn’t highlighted, press the up or down arrow button on the
remote control to highlight your country and press OK.
2. Use the number buttons and/or the arrows on your remote to enter your
zip code or postal code. Press OK when you’re fi nished.
Note: If your postal code contains letters, press the up and down arrow
buttons on your remote to enter letters, and press the right arrow button
to go to the next space. The left arrow button also moves the highlight to
the left.
Step 2: Confi guring for Cable
The next series of screens asks you about your cable setup. To supply your TV
with the correct TV program listings, the TV Guide On Screen system needs to
know if your TV is connected to cable.
Note: If you’re using a cable box, always leave it on so you can receive
program information.
1. If your TV is connected to cable, highlight Yes and press OK.
If your TV isn’t connected to cable, highlight No and press OK. (STEP 3:
Confi guring for Antenna
appears–go to page 24).
2. If you have a cable box connected to this TV, highlight Yes and press OK.
Note: The next series of screens is very important because the TV Guide
On Screen system must fi nd the correct cable box information in order
to receive the correct TV program listings.
If you don’t have a cable box connected to this TV, highlight No and
press OK (STEP 3: Confi guring for Antenna appears–go to page 24).
3. Highlight the input where you connected your cable box to the TV, and
press OK.
If you select Cable Input, continue to step 4.
If you select any other option, go to step 5 on the next page.
Important Note: Your cable box can’t be connected to ANTENNA
INPUT if it is to be controlled by the TV Guide On Screen system.
try using the guidelines above.
Mar 25, 2008 | Televison & Video
Blank screen
hi
start your sys and press F8 key.
then go to safe mode. or last good confi..........
change your resolution to 800x600 or 1024x768
Mar 23, 2008 | Computers & Internet
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
32 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
