Abit KT7A motherboard need the pin definitions for the 2 onboard USB connectors please
  • 6 more comments
  • mike1941 Nov 19, 2008
    Unfortunately this manual does not give this info
    Dowload centre for Abit KT7A does not give details of USB pins
    Sorry this does not help either
    Not on this one it doesn't!
    Yes i've seen this but no pin numbers are shown in detail like for the other connectors
    What i need is the pins numbered 1 to 9 and the assignment of the leads marked G, Port+, Port-, and VCC
    An extremely comprehensive site thankyou but still does not answer my problem!
  • mike1941 Nov 23, 2008
    Have now solved the problem with patience and a systematic series of elimination. But thanks to all.
  • 19,396 Answers
Here is the pinout, with pin numbers, this is what you are asking, if not , you need to explain why, since here you have USB pinout:
Pin one is at the lower right hand corner.
If this is not what you are looking for you need to explain Why.
This is USB pinot for usb connector on your motherboard.
Let me know .
Thanks.
Posted on Nov 19, 2008
  • Ginko
    Ginko Nov 19, 2008
    I do not know if you can see all solutions , this had ben posted many times.
    Evidently the system on Fixya is disfunctional.
    Here
    Pin 2 is in front of it.
    then pin three bove pin one.
    pin 4 above pin 2 and so on.
    Let me know .
    Thanks.
    Brigadier General:
  • 6,966 Answers
Normally front USB ports have a pair of 4 wire cable with connectors marked red wire is vcc; white wire is -D; green wire is +D; and black wire is gnd. The motherboard would normally have two pairs of dual pin connectors that would be sitting side by side or in-line with uneven pins - 4 and 5 pins; then another 4 and 5 pins. Please refer to the attached simple diagram for your connection.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 19, 2008
    For your Abit KT7A
    G - GND/Ground
    Port+ is DATA +
    Port- is DATA -
    VCC is +5 supply
  • Louie  Role
    Louie Role Nov 23, 2008
    Hi again,
    Any updates or development so far?
    President:
  • 1,952 Answers
... http://www.motherboardpoint.com/archive/f-2-p-13.html
Discard Newest Oldest Positive Negative Recommended Be the first to Comment! Comment Posted, thanks! 0/500 characters Close Be the first to Comment! Comment Posted, thanks! 0/500 characters 0 http://www.motherboardpoint.com/archive/f-2-p-13.html 0
  • 10,515 Answers
Hey dude,
Read the instructions to configure motherboard :-
http://www.pcguide.com/proc/config/mb.htm
*******************Take Care **************************
  • 2 more comments
  • taran_2005
    taran_2005 Nov 19, 2008
    Hey buddy,
    If u look at the down of that link, there is one mre link.................
    ******YOU WLD BE ABLE TO GET ALL THE CONFIGURATION SETTINGS FROM THESE FEW LINKS****************************************
    If this wld solve ur problem, u may lock the thread as fixya.
    Take care Bro.
  • taran_2005
    ****************one mre link for diagram :-************************
    http://www.hexus.net/content/item.php?it...
    TakeCare.
  • taran_2005
    Hey dude,
    As per ur request, i have found an interesting pdf file for u.............
    All pin and connector combination details are there alongwith the diagrams :)
    http://www.formfactors.org/developer/spe...
    I hope i have answered ur query :)..............
    Ba Bye.
  • taran_2005
    taran_2005 Nov 23, 2008
    ur alwayz wlcme mike............
    Bt we wld appreciate if u may lock the thread,
    As Fixya.
    Thanx bro.
    Take Care.
  • 734 Answers
Follow the blow link --
http://media.wiley.com/product_data/excerpt/01/04700483/0470048301.pdf
  • 13,433 Answers
Here is the pinout
  • 1,879 Answers
The manual from the abit website does not indicate where pin 1 is.
look closer to the board, pin 1 has a white dot under it
  • monk3ybidzness
    monk3ybidzness Nov 19, 2008
    If your board is color coded, locate the black pins - pin 1 is on the other side. left side if your looking at it vertically.
    Sergeant:
    Champion:
  • 200 Answers
Hi
Check the user manual of ur mother board....U can get detail...
Or else download the user manual....
try this links
Click here
Thank you
  • 1 more comment
  • Thafa Nov 19, 2008
    Hi
    Check this link also
    Click here
    thank you
    Hi
    KT7 - ABIT
    CPU
    1. Supports AMD-K7 Athlon Socket A 200MHz FSB Processors
    2. Supports AMD-K7 Duron Socket A 200MHz FSB Processors
    Chipset
    1. VIA (KT133) /VIA 686A
    2. Supports Advanced Configuration and Power Management Interface (ACPI)
    3. Supports AGP 2X/4X (Sideband)
    4. Supports 100/133MHz Memory Bus Settings
    Memory
    1. Three 168-pin DIMM sockets support PC100/PC133 SDRAM module
    2. Supports up to 1.5 GB MAX. (8, 16, 32, 64, 128, 256, 512MB SDRAM)
    3. Supports VCM module
    System BIOS
    1. SOFTMENUTM III Technology to set CPU parameters
    2. Award Plug and Play BIOS
    3. Write-Protect Anti-Virus function by AWARD BIOS
    4. Year 2000 Compliant
    Multi I/O Functions
    1. On board Bus Master IDE Ports supporting UDMA 33/66
    2. PS/2 Keyboard and PS/2 Mouse Connectors
    3. 1x Floppy Port (up to 2.88MB)
    4. 1x Parallel Port (EPP/ECP)
    5. 2x Serial Ports
    6. 2x USB Connectors
    7. On board USB header for Two extra USB channels
    Miscellaneous
    1. ATX form factor
    2. 1 AGP slot, 6 PCI slots and 1 ISA slots
    3. Hardware monitoring - Including Fan speed, Voltages, System environment temperature
    4. Built-in Wake on LAN/Wake on Modem
    5. Built-in IrDA TX/RX header
    6. One Thermal Sensor Cable Included
    thank you
    Diagram
    Master:
    Sergeant:
  • 449 Answers
  • 541 Answers
  • Lee Reynolds
    Lee Reynolds Nov 19, 2008
    the link i sent you for the manual dose show where to put them
    Master:
  • 505 Answers
The two onboard USB connectors are PCI connectors. You can buy the normal PCI card for the same not the smaller one which are know as PCI-Express. Click on the link for more information.
Thanks
  • 83 Answers
Heres the manual for the motherboard. On it you will find the USB connectors.
Just download the .zip file and extract it to view the manual.
I have a ABIT KT7A Motherboard AMD2000+ Win98SE
Since it "runs fine with a 128 & 256", install those and go to a website called crucial.com. Study their opening page and let their website look at your system to see what it accepts. This is a fine company to buy memory from, AND it will ALSO tell you what your computer can be populated with. I've also seen weird things happen when your CMOS (coin battery) gets low. They're cheap, change it as a precaution.
Oct 25, 2013 | Abit KT7A Motherboard
What processor supports a am35306 motherboard
HP and Compaq Desktop PCs - Motherboard Specifications, RC410-M (AsteropeA)gtabseps.gif
gtabblt.gif Motherboard specifications table gtabblt.gif Motherboard layout and photos gtabblt.gif Clearing the BIOS settings gtabseps.gif Motherboard specifications table Part / Feature Specification / Support Motherboard description
  • Motherboard manufacturer's name: ECS RC410-M
  • HP/Compaq name: AsteropeA-GL8E
CPU/Processor
  • Socket: 775
  • Supports the following processors:
    • Pentium D 900 series Dual Core (Presler)
    • Pentium D 800 series Dual Core (Smithfield)
    • Pentium 4 500 (Prescott)
    • Pentium 4 600 (Prescott)
    • Celeron D (Prescott)
    • Celeron D (Cedar Mill)
Front-side bus (FSB)
  • 800/533 MHz
Chipset
  • Northbridge: ATI RC410
  • Southbridge: ATI IXP450
BIOS features
  • AMI BIOS
Form factor
  • Micro ATX size form factor, 9.6 in x 9.6 in
Memory
  • Single-channel memory architecture
  • 2 x 240-pin DIMM sockets support unbuffered non-ECC 400/533 MHZ DDR2 memory modules
  • Maximum HP/Compaq approved memory is 2 GB
Expansion slots
  • Three PCI
  • One PCI Express
Video graphics
  • Integrated
  • Supports PCI Express x16 graphics cards
Onboard audio or audio card
  • Built-in Azalia 8 channel audio
  • Realtek ALC883 8-channel High Definition Audio CODEC
Onboard LAN
  • Realtek RTL8100 10/100 Mbps Fast Ethernet controller
Back panel I/O
  • PS/2 keyboard (purple)
  • PS/2 mouse (green)
  • One SPDIF out port
  • One S-video out port
  • One VGA out port
  • One Parallel port
  • Four USB (2.0)
  • One IEEE 1394a
  • One RJ-45 networking port (LAN)
  • Audio ports:
    • line in (light blue)
    • line out (lime)
    • microphone (pink)
    • side speaker out (gray)
    • rear speaker out (black)
    • center/subwoofer (yellow orange)
Internal connectors
  • Two IDE connectors
  • One floppy drive connector
  • One ATX 24-pin power connector
  • One ATX 4-pin +12v power connector
  • Four Serial ATA connectors
  • One VGA connector
  • One IEEE 1394a connector
  • One CPU fan connector
  • One PC fan connector
  • One CD_IN connector
  • One front panel audio connector
  • One PC panel connector
  • Two USB connectors supporting 2.0 ports
NOTE: Motherboard specifications are subject to change without notice.
hope this helps
Sep 25, 2011 | HP Compaq Motherboard
I need to figure out where to plug in the Power LED and the power SW wires to the mother board
Hi
The link for the motherboard manual can be found here, on which there will be a pinout diagram of the Fpanel pin headers
http://www.abit.com.tw/page/en/download/download_manual_detail.php?pFILE_TYPE=Manual&fSEARCHTEXT=kt7a
USUALLY the wires are marked as:
Power switch: PW
Power led = Pled
On the motherboard you will see (bottom right corner I think), a group of about 8 pins in a block, this is the Fpanel pinset. on the motherboard next to each pin SHOULD show the wire connections as described above, but consult the manual to be sure.. this is a VERY old mobo
Dec 28, 2010 | Abit KT7A Motherboard
No boot. Continuous long beeps
Remove the following one by one: 1. RAM. Reinsert and reboot. 2. HDD cable (both from the motherboard and from the HDD side). Reconnect and reboot. 3. Power cable from the mother board. reconnect and reboot. 4. Processor. Reinsert and reboot. 5. The 3 connectors from the front basel to the motherboard. Reconnect and reboot.
Nov 05, 2009 | Abit KT7A (KT7A-RE) Motherboard
Abit Kg7-Lite motherboard USB2 pin Locations desperately needed!
Lay case down with the bottom in front of you. Looking straight down at the row nearest the case bottom reading right to left there will be two rows of four pins.
Reading right to left the row closets to the case bottom the first lead is vcc1, next usb1-, next usb1+ and grnd1.
Top row reading right to left is vcc2, next usb2-, next usb2+ and grnd2.
I just replaced bad caps on my kg7 and had to remove the motherboard for the repair so I just reinstalled my front case usb ports.
Help this helps.
anon paranoid
Feb 18, 2009 | Abit KG7-Lite Motherboard
Unable to find Mass Storage Controller Driver
Hi koolkeef, your KT7A-RAID uses the KT133A chipset. You can find drivers for that chipset located at VIA's web site.
http://www.viaarena.com/default.aspx?PageID=2&OSID=1
Happy hunting & good luck!
Mike
Apr 01, 2008 | Abit KT7A-RAID Motherboard
Usb hookup
Here's a link to the ABIT website where you can download the KT7A-RAID manual:
http://www.uabit.com/index.php?option=com_content&task=view&id=32&Itemid=48&page=6&category=5&subcategory=256&model=89&product_name=KT7A-RAID
When I clicked on the "Download" link it failed, but when I clicked on HTTP Download it worked. I'll keep the file a few days. If you can't get it post your email address and I will send it to you.
Nov 19, 2007 | Abit KT7A-RAID Motherboard
Computers & Internet Logo
243 people viewed this question
Alun Cox
David Payne
David Payne
