Question about Canon MV700i Mini DV Digital Camcorder
MV700i The tape transport fails to eject. There is enough power but the geared wheel only moves a small amount then stops under strain and gives up. The carriage does not move upwards at all. I removed a few parts and managed to the get the unit to rise with some encouragement so that I could extract the tape. Then the transport mech worked perfectly when no tape was loaded, but once I tried with a new tape, it takes down and fails to engage the tape. Everytime you switch on it complains and asks for the tape to be ejected, and of course it cannot achieve this as described above. Any help would be appreciated. regards, Kev.
Had same problem. Had to take to certified repairer. Only cost $70 (Aus)to repair.
Posted on Jun 28, 2007
Tascam 122MKIII Cassette player/recorder is malfunctioning.
I have one here at my shop that does the same thing almost. I found a gear broken in the mechanism system. The flashing LEDs tells you that the system control IC can not get the transport where it is suppose to go. The Gear C as described in the manual was the problem in the deck here. The head base was in the up position in this unit and thus would not eject. My E mail is skywavebe@sbcglobal.net. Due to the amount of dis-assembly to get to the transport control section this might be a job for a technician.
Feb 22, 2013 | Tascam Audio Players & Recorders
The VCR accepts the tape and starts to play; then stops and shuts off; when you turn the power back on the tape ejects
You have a transport problem, the mechanism the plays, FF or rewinds is not working.
Someone is going to have to open and look at the unit---as simple as a belt off or broken to the idler (rubber or geared) that doe the actual work, finding a shop that will work on a VCR unit is getting hard as most of the current techs have never seen this type of unit.
What I used to do when I opened one was have a old cassette with the tape removed! but the reels inside of it still there--tape off both sides of the cassette where it opens so the sensors on either side do not try to stop the unit from allowing this.
This way with the unit open and the dummy cassette in you can see thru its top to see if the reels are moving or not and not have the tape get in the way.
Dec 06, 2012 | Magnavox DV220MW9 DVD Player VCR
How to repair my vcr I have a faulty tape in the machine and unable to remove it
I hope your vcr is not built in with TV. It is separate from TV. If it is not then you have to call a technician to open the vcr and remove the faulty tape. If it is separate then open the top cover by unscrewing the screws on the side. These can be located very easily. Remove the top cover gently. Look for the gear toothed wheels which load/eject the tape. You can do so by switching the power button on and off. Switch of the power to vcr. Move the toothed wheels by hand to bring the tape up if you do not want the tape to get damaged. When the tape comes up then give it a gentle push so that it can eject itself. If not, repeat the process again. If you see the magnetic tape is stuck or entangled with moving wheel the cut it,remove it gently. Make sure that you do not touch or damage the video head. Once removed, you can fix the top cover.
Apr 04, 2011 | Televison & Video
A vhf tape got stuck in the machine. I could see the tape itself was caught on some moving prongs. now i don't know the proper setting for the prongs and cannot get any vhs tapes to play.
Hi, if VHS tape is in you have only one solution..to disassemble DVD/VCR ..Can you do it ? you may try !!t
Here's how to do it..
* 1 Turn off the COMBO. and unplug it.
* 2 Remove the 4x screws off COMBO on the sides and take off the DVD/VCR casing.
* 3 Look for the Tape which messed up with VCR transport mechanism ,try to release tape of the transport with your hand..
* 4 Since EJECT feature works with power only ,while you keep the tape off from transport plug the device to power and turn it on..Don't worry,you will see the eject mechanism starts moving back on forth,keep the tape off it and let it eject..
* 5.When tape is out .If it destroyed badly normally you should not use it however if the recording in is valuable for you you can cut the chewed portion and
splice it back together .(Pls see the video included...How to fix a broken VHS tape.)
* 6 While it is open,place another Tape to see if mechanism works properly. and eject it...
* 7 Replace the casing and the screws. Plug the player in and turn it on. Now player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
http://www.youtube.com/watch?v=Q1PJWA2KGyg
Mar 13, 2011 | Philips DVD740VR DVD Player/VCR
7E57 SAMSUNG ERROR CODE ON VCR SAMSUNG SV657X AND NOTHING WORKS WHEN I PRESS PLAY THEN THE CODE APPEARS TO THE SCREEN
the machine monitors the pully speeds to make sure tape is actually moving properly .. if it isnt then it halts rather than spool off hundreds of feet of tape inside the machine .. what a mess that would be ... almost always the problem is an idler pully that operates the takeup reel .. the rubber gets hard or contaminated so that it slips .. if it fails to turn the takeup reel then every thing stops ... you an try cleaning the wheel if you can find it .. it usually under the transport mechanism (sometimes available if you can take the bottom off the unit) .. dont use alcohol .. you can use water or special idler wheel cleaner or even a pencil eraser .to clean it ... or for name brands there may be parts still available .. you can just replace the idler pully with a new one ... this requires more work than most people are willing to do ... and if you have someone repair it the cost is often more than a new machine .. if it gives you enough time you might try to fast forward all the way then reverse all the way .. do that a few times and it may clean the idler wheel enough to work for normal play .. ...
Nov 22, 2009 | Samsung SV5000W VHS VCR
Tape stuck in player - error code e13 shows
I just got a tape unstuck myself. Everytime I would hit eject it would make a clicking noise.
Here is what I did:
First I watched these videos to remove the radio.
http://www.youtube.com/watch?v=29MTa4FLjtk&feature=channel
http://www.youtube.com/watch?v=fqvk_PNo9Kg&feature=channel
Then I unscrewed the bottom panel of the radio.
Unscrew the brass screws holding in the cassette player portion of the radio.
Now flip the cassette player over to see your tape, etc.
When I pressed the eject button, I noticed a little motor with a worm gear would move a a gear which moved several other gears until it eventually moved a black gear which has a little post that moves the metal arm which moves back when pushing in a tape and moves forward when ejecting a tape. But I would get a clicking sound which seemed to be due to one gear trying to move a stuck gear.
I forgot the exact details of how I managed to get the tape out, but when I did get it out I noticed when I turned on the radio, it would act like it was trying to play a tape. But when it found out it couldn't, it would try to eject but would fail once again with the gear clicking sound.
I think I tried moving the black post on the black gear that moves the arm that pushes the tape out. Eventually I got to the point where the arm was pushed forward like it should be when a tape is ejected. At that point I was able to insert and eject a tape without any problems.
Mar 22, 2009 | 1998 Buick LeSabre
VCR tape loads and runs about 5-10 sec; then ejects
you need to clean the vcr with a cleaner that you can buy at a store. If that doesnt work then you need to take the 4 or 5 skrews out that hold the top on and look at the motor and gears move while you put a tape in and you should spot the problem pretty quick. It'll be with the round metal wheel that turns the tape.
Jan 02, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
VCR SLV-640HF
The mode switch is the device that monitors the various positions of all mechanical components in the transport area. It is usually an encoder type device, located near the center or right side bottom of the transport. But, before I'd condemn the switch, I would certainly check and see the the transport is "cycling", and that nothing is slipping. This is usually the case when this symptom crops up...accordianman
May 13, 2008 | Sony SLV-640HF VHS VCR
VCR tape won't eject
you should take the bottom off and you will see a gear with a belt around it try to turn it the same direction as when it is turned off, do not force it but it may need a little force to move the wheel.
Mar 17, 2008 | Sony SLV-998HF VHS VCR
More info on Aiwa HV-MX100 not powering up
mechanical fault needs profesional technisian just not to make it worse , regards
Apr 30, 2007 | Aiwa HV-MX100 VHS VCR
Canon MV700i Mini DV Digital Camcorder Logo
67 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
