Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Handle fell off Bosch stainless steel dishwasher
The right hand side handle of our Bosch SHV4303UC built-in dishwasher fell off of it's screw. I don't know how to put it ack on. The screw is built-in to the main part of the dw and is sticking out the face side of the dw. There is a nut of some sort on the inside of the handle part that the screw screws into, but I don't know how to access either the inside screw or the nut on the inside of the handle. I wonder if I can either open up the dw and hold the handle while screwing in the screw (have no idea how to do that & don't want to damage machine) or can I flip off the end of the handle (to hopefully reveal) some sort of allen wrench hole where I could then manuver the nut around the screw?.... Not quite sure how to attempt this....Help, please!
  • redandcharli Nov 19, 2008
    The right hand side handle of our Bosch SHV4303UC built-in dishwasher fell off of it's screw. I don't know how to put it back on. The screw is built-in to the main part of the dw and is sticking out the face side of the dw. There is a nut of some sort on the inside of the handle part that the screw screws into, but I don't know how to access either the inside screw or the nut on the inside of the handle. I wonder if I can either open up the dw and hold the handle while screwing in the screw (have no idea how to do that & don't want to damage machine) or can I flip off the end of the handle (to hopefully reveal) some sort of allen wrench hole where I could then manuver the nut around the screw?.... Not quite sure how to attempt this....Help, please!
  • 4,806 Answers
Hi
here is a web address for the service manual for free, all you have to is sign up to the forum for FREE to download it. :)
http://forum.appliancepartspros.com/dishwasher-repair/7123-bosch-dishwasher-troubleshoot-manual.html
hope this helps
kind regards
Posted on Nov 19, 2008
    Sergeant:
    Champion:
  • 435 Answers
Please try it
To remove the outer door, open the door and remove the T-20 Torx screws located on each side of the inner stainless door.
Return the door back to its upright position, and bring the bottom of the door panel out toward you, then slide the top of the panel down and out from under the fascia panel.
As the outer door is being removed, the left or right door guards may shift or fall out of place. To reposition them, slide them back in over the hinge, lining up the door guard square tab with the hinge lever square notch. Please note: door guards must be in place before reinstalling the door panel.
Tighten the screws holding the door handle.
Assemble in the reverse order.
Ref: (www.appliancepartspros.com)
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
find surplus part near you!!
  • Bosch Master
  • 19,396 Answers
Dishwasher door handle
Remove the screws around the inside of the stainless steel door panel, once you can gain access, repair or replace the door handle and return the door panel to normal.
May 05, 2016 | LG Dishwashers
Loose handle
Open the door and loosen the self threading screws around the sides of the inner door panel. Once this has been achieved lift the inner panel up so that you can access the door handle screws. Tighten these fasteners and reassemble the door panel.
Jan 24, 2014 | LG LDF6810ST Stainless Steel Built-in...
My bosch dishwasher (SHX46A05UC) has 2 problems:
there is not a manual for that kind of troubles,,,about the propeller is atached to the upper rack wout tools,,remove the plastic frame is in the lower of the upper rack and assembled backusing only your hands...theouter handle ...inside around the door have scrws remove thoes,you can see the loose srews of the handle,,
Feb 06, 2013 | Bosch 24 in. SHX36L05UC Stainless Steel...
I have a Bosch dishwasher that now doesn't easily open. The handle mechanism seems to be breaking. Can feel a plastic strip poking out from under the handle.
This is a child safety latch. It opens the door when slid to the right.
It can be reset to off by sliding it to the right and inserting a tooth pick into the small hole under the handle. It is hard to see and do! Get on the floor and look up.
It will stay over to the right when you are done.
If the plastic face panel is broken or cracked it will need to be replaced 8>(
HTH,John
Oct 22, 2010 | Bosch 24 in. SHE47C05UC Stainless Steel...
How do I tighten the door handle on my Bosch dishwasher model SHY56A 05UC/14?
Remove front panel then you can access the handle screws. Open the door and remove the 'torx' screws surrounding the perimeter of the door.
Oct 06, 2010 | Bosch 24 in. SHY56A05 Stainless Steel...
Can I get a different front door for my dishwasher?
From what I could gather, it appears that there may be a door panel kit available for your dishwasher. The kit appears to have the panel kit and the curved handle included. Some links for visual reference:
SGZ1005UC Stainless w/tubular Towel Bar Handle
SGZ1006UC Stanless w/curved Handle
Feb 06, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
LOOSE DOOR HANDLE
Remove 4 screws(Torx 20) along both sides of inner door liner. Be sure to have a good grip on the outer door as it will fall off. I always start at the top of the door and work down. You may have 2 blocks fall off, they go on the hinge and fit on only 1 way with the slot on the hinge.
May 10, 2008 | Bosch 24 in. SHX36L05UC Stainless Steel...
Handle coming loose
If you only remove the 4(T20 torx) along the flat edge this will only remove the outer door panel. Start from the top and work down. Also if yours has 2 blocks that fall out, they go on the hinge only 1 way.
Door handle loose
they are a vivration attenuator and yes are spacer too, but are a little dificult to mount if the machine are working well ok leaved like that but check every coples of month for a loose screew.....good luck and rate me
Jan 10, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
148 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
