Question about E-Machines eMachines Desktop PC
Won't get beyond a certain page
When I start up my computer it goes to the page asking me if I want to start it in safe mode or Windows. I click Windows, it starts (you can hear it running) and then returns to that page. Over and over I can not get past it. It almost sounds like it shuts down and then restarts again. Help me! I'm in a on-line course at school. This the worst possible time for this to happen
  • 32 Answers
Have you tried starting in safe mode? If so what happens?
Posted on Nov 19, 2008
Can't uninstall Canon MX410 MP Drivers
Have you tried uninstalling the drivers in safe mode ?
1.
You should print these instructions before continuing.
They will not be available after you shut your computer down in step 2.
2.
Click Start and then click Shut Down.
3.
In the drop-down list of the Shut Down Windows dialog box, click Restart, and then click OK.
4.
As your computer restarts but before Windows launches, press F8.
On a computer that is configured for booting to multiple operating systems, you can press F8 when the boot menu appears.
5.
Use the arrow keys to highlight the appropriate safe mode option, and then press ENTER.
6.
If you have a dual-boot or multiple-boot system, choose the installation that you need to access using the arrow keys, and then press ENTER.
Note
If Windows launches before you can choose a safe mode, restart your computer and try again.
In safe mode, you have access to only basic files and drivers (mouse, monitor, keyboard, mass storage, base video, default system services, and no network connections). You can choose the Safe Mode with Networking option, which loads all of the above files and drivers and the essential services and drivers to start networking, or you can choose the Safe Mode with Command Prompt option, which is exactly the same as safe mode except that a command prompt is started instead of the graphical user interface. You can also choose Last Known Good Configuration, which starts your computer using the registry information that was saved at the last shutdown.
Safe mode helps you diagnose problems.
If a symptom does not reappear when you start in safe mode, you can eliminate the default settings and minimum device drivers as possible causes.
If a newly added device or a changed driver is causing problems, you can use safe mode to remove the device or reverse the change.
There are circumstances where safe mode will not be able to help you, such as when Windows system files that are required to start the system are corrupted or damaged.
In this case, the Recovery Console may help you.
NUM LOCK must be off before the arrow keys on the numeric keypad will function.
Jul 23, 2013 | Canon Pixma MX410 All-In-One Printer
Aspire 5475 freezes on startup
It is most certainly a driver, but if you cant access the safe mode also that could be a hardware issue.. Try to troubleshoot with a windows installation cd. Put it in and boot the pc. It will start the windows instalation, you choose repair computer and not install windows. The command prompt will open, try to troubleshoot from there.. Thanks!
Mar 19, 2013 | Computers & Internet
My netbook won't go from the loading os image page
Reboot while pressing F8 as it goes to Windows. It will show a menu, choose safe mode.
After entering Windows, click computer, right click the C drive - properties. Click tools, click all selections for error checking, reboot when the resulting message tells you to. Windows should check and repair your drive, on finish, it should load normally.
Sep 13, 2011 | Sylvania G-Netbook
My dell won't reboot. Goes to a screen that says windows error recovery, and gives me two options.1. resume windows normally or 2. launch startup repair. I tried the 2nd one and nothing happens. It...
"Step 1
I would suggest you to boot the computer in safe mode and check if you can boot to the desktop and post back the result. To boot to the desktop in safe mode with networking keep tapping F8 key during restart. Once you see the option to boot in safe mode with networking select it and press enter.
Access the link to know more about how to boot the computer in safe mode:
http://windows.microsoft.com/en-US/windows-vista/Start-your-computer-in-safe-mode
Step 2
If you are unable to boot to the computer in safe mode, you may try to perform a system restore from Windows Recovery Enviornment (WINRE Mode) to an earlier date and check if it helps you fix the issue.
If you have Windows Vista disk you may try to perform a system restore using Windows Vista disk:
a. Insert the installation disc.
b. Restart your computer.
c. If prompted, press any key to start Windows from the installation disc.
Note: If your computer is not configured to start from a CD or DVD, check the information that came with your computer. You may need to change your computer's BIOS settings. For more information, see BIOS: frequently asked questions.
d. Choose your language settings, and then click Next.
e. Click Repair your computer.
f. Select the operating system you want to repair, and then click Next.
g. On the System Recovery Options menu, click System restore and select the date when the computer was working fine.
If System Recovery Options is a preinstalled recovery option on your computer:
a. Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer.
Click the Start button, click the arrow next to the Lock button, and then click Restart.
b. Do one of the following:
• If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you will need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
• If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to repair, and then press and hold F8.
c. On the Advanced Boot Options screen, use the arrow keys to highlight Repair your computer, and then press ENTER. (If Repair your computer is not listed as an option, then your computer does not include System Recovery Option as a preinstalled recovery option.)
d. Select a keyboard layout, and then click next.
e. Select a user name and enter the password, and then click OK.
f. On the System Recovery Options menu, click system restore and restore the computer to the date it was working fine.
After running the system restore check if you can boot to the desktop normally.
Access the link below to find more information about system restore.
http://windows.microsoft.com/en-US/windows-vista/What-are-the-system-recovery-options-in-Windows-Vista
http://windows.microsoft.com/en-US/windows-vista/What-to-do-if-Windows-wont-start-correctly "
This guide should help you out
Aug 24, 2011 | Dell Inspiron 1545 Notebook
How do I put my HP computer in safe mode.
Just after post(the computer boots up) and just before you see windows booting press F8, it will bring up a blck page with different selection options to boot your pc, use the arrow keys to go to the top of the page where it says safe mode and hit enter,, the computer should now boot to windows in save mode. hope this helps.
Sep 23, 2010 | Computers & Internet
My A30 ibm laptop wont start up??
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Mar 03, 2010 | IBM ThinkPad A30 2652 Notebook
When i turn on my laptop it goes to start windows normally or last known good configuration but when i select one it goes right back to start windows normally page again
Insert your OS system disk or recovery disk. reboot computer, boot from DVD, start installation of software, do not repair from the first prompt when asked, click install, once windows searches for previous version of windows click repair. This will reinstall the system folders and straighten out any registry problems. once complete you are done.
Nov 30, 2009 | Acer Aspire One AOA150-1784 Netbook
Dell Inspiron blank screen
You can restore your system in your safe mode.
To use System Restore to restore Windows XP to a previous state, follow these steps:
  1. Log on to Windows as Administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  4. On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
    Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
  5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  6. Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
  7. Click OK.
If you successfully restored your computer to a previous state, and the computer is performing as it should be, you are finished.
Jun 11, 2009 | Dell Inspiron 9300 Notebook
Black screen
hi,
do you see any error or does it go blank after you see the windows logo,
if it goes blank after you see the windows logo, that means that there has been software misconfiguration at the level of windows operating system, restart your system using the power button and wehn you see the asus logo at start start tapping F8 key, it will lead you to a menu that will say boot into safe mode, select safe mode and enter, see if you are able to boot into safe mode, if you are then what we can do is restore your system back to a previous date
to do that in safe mode follow the following instructions
Caution: After a system restore the configurations/software that are done after the restore point will be lost
for system restore
click on start button > go to run > in there type in without quotes
"%systemroot%\system32\restore\rstrui.exe"
system restore window will open
  1. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  2. On the Select a Restore Point page, click the most recent system restore point in the On this list the dat eon which your computer was working, click a restore point list, and then click Next.
  3. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  4. Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
  5. Click OK.
further Queries are welcome
If you find my solution helpfull please do rate me
Feb 24, 2009 | ASUS Eee 4G Notebook
Red vertical lines appear, can only run computer in Safe Mode
check the video cable and see if it;s properly seated. run the laptop with something that uses memory. if the video chip it going to show signs of problems, it will be more prominent when the laptop gets hot. most cases laptop motherboards have integrated video cards and cannot be replaced.
Aug 27, 2007 | Dell Latitude C640 Notebook
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
