Question about Sony Televison & Video
My Sony KP48V90 tv has three images on screen
The image on screen has a green shadow on the left side and a pinkish shadow on the right side of picture image.
    Genius:
  • 2,920 Answers
You need to have the tv converged
Posted on Nov 22, 2008
Hi, Expert: I have a 52" Sony LCD TV (
Hello
If I send you its schematic diagram and give you instructions, can you follow me?
Oct 18, 2011 | Televison & Video
The right side of the TV has shadows/distorted images and colors
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jan 22, 2010 | Samsung PCL545R 54" Rear Projection...
Colors on the left side of the screen are shadowed with duplicate
Your set has a convergence problem which is a common issue.
Take a look at this solution posted earlier on Fixya. It worked for me.
http://www.fixya.com/support/t2703612-double_red_image
Aug 20, 2009 | Sony KP-51WS500 51" Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Three separate images about 4-5 inch apart on my TV
Symptoms shows TV has problem of faliure of convergence out ICs. (2 ICs in TV) and need to be replaced.Let me know do you want to repair it at your own? ...
... if yes, it is necessary to have experience of TV repair and basic electronics knowledge.
Nov 23, 2008 | Sony KP-51WS500 51" Rear Projection...
Picture shadow on rear projection Sony big screen TV
You have 2 distinct problems that should be addressed separately. Please repost the Samsung problem. I will address the Sony problem here.
If the "shadow" makes the picture seem somewhat of a 3D one, the problem is with the convergence circuit. This could be as simple as bad connections on the pins of the convergence ICs or defective ICs. If you can solder and would like to attempt the repair, update this and I'll provide more details and instructions.
Dan
Sep 25, 2008 | Samsung HCM4216W 42" Rear Projection...
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Hitachi hdtv model 43uwx10b is showing a green shadow on the left side of the pictures
Good Day;
If you order KIT 10 from B&D ENTERPRISES at 1-800-458-6053 The KIT will include all parts neede and layout of part value & locations on simple paper lay out diagram.
Jul 13, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Oct 31, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Pinkish screen and green blurred picture
Sounds like the image sensor is malfunctioning (common symptoms: distorted images with purple or green cast, completely dark images, flickering lines across the screen.)
Oct 26, 2007 | Kodak EasyShare C643 Digital Camera
Televison & Video Logo
118 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
