Question about Toshiba DKT-3220-SD Corded Phone
Message light doesn't come on
We have a Toshiba Strata CIX 200 (DKT3220-SD) business phone. The message light doens't come on when we have a new message. Any way to fix this problem?
  • 38 Answers
How do u know have new message?
u may have a try to send a ,essage by key in the extention number followed by "7"or press message key at the key pad.
RED indicator light will turn on, press the message button to retrive message.
if voioce message the default security code extention number+991# exp : 201997#foloew the instruction
to cancel message light key in #409
Posted on Mar 01, 2009
We have a Toshiba Strata DKT3512F-SD system in the office, only the main line actually rings the others just flash but we need to make them ring.. any advise would be much appreciated!! I'm lost!
On the old DK system, it must be done using key strokes from port 005. On the newer CiX system, it's handled via system programming using the Network eManager.
Dec 07, 2015 | Toshiba Lands Phones
Need to add a caller id scroll button on phone for toshiba cix 40 phone system
Your problem was posted in the printers and copiers section. Try posting it again in the correct section.
Dec 03, 2013 | Toshiba Strata Cix40 Cix 40 Complete Phone...
Does teh DKT 2010-sd have a PRI card slot for voip
Since a DKT-2010 is just a phone that attaches to a Toshiba Key System, it's hard to say.
PRI and VoIP are two entirely different protocols. PRI is delivered on two pairs of wires and it contains up to 23 circuits and a data channel. It requires a card in your system, a DK, CTX, or CIX Key service unit.
VoIP can be delivered via an Analog Terminal Adapter, or directly into the KSU if you have a CIX-100 or higher system. Likewise, faxes are deliered on trunks to analog stations, or it just requires an analog line to receive. It can work within your system or outside of your system.
If you look at the manual, starting at page 21-23, this will give you an idea of the capabilities of a CIX system. http://cdgenp01.csd.toshiba.com/tsd/docum/gen_desc/CIX/CIX-GD-ALL-VF_E.pdf
Carl
Apr 15, 2010 | Toshiba Lands Phones
How do I set up and use speed dial on a Toshiba dkt2010-sd
what system u using??
if DK series go to phone port number "000" (at phone press Intercom #401 to check port), check at every phone with display phone.
- to set speed dial press REDIAL SPEED DIAL standard speed dial   code 60 or 600, follow by 9+destination number, REDIAL to confirm.
- to call press speed dial + code or press * + speed dial code (*60 / *600)
- if CTX/CIX must set at adminsrater phone. #66, speed dial code number (200-999), 9 follow destination number #
- to dial press *200...
Apr 22, 2009 | Toshiba DKT2020SD Phone
How do I set up speed dial for a Toshiba DKT2010-Sd phone
what system u using??if DK series go to phone port number "000" (at phone press Intercom #401 to check port), check at every phone with display phone.
Toshiba Strata DKT 3512 ,!how to set the speed dials!?
for strata CIX/CTX if the program r enable
#66 100 to 109 (speed dial code) 9 follow by destination number #
Mar 13, 2009 | Toshiba DKT 3010 Corded Phone
Toshiba DKT3220
sounds like your voicemail is down, try and reboot the entire system and see if it comes back up, if it is a inskin voicemail like a ivp8 tell me what lights are on after it boots and there colors.
Aug 13, 2008 | Toshiba DKT 3010 Corded Phone
Toshiba strata dk 280
it may be setup to block outbound calling, remember also, you have to dial a 9 to get dial tone on a centrex line, so in this case if your phone system is setup to dial 9 as a line access code you will actually have to dial 99. hope that helps
May 13, 2008 | Toshiba Strata PT-390 Corded Phone
Toshiba DKT-3220-SD Corded Phone Logo
1,018 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Marvin
Marvin
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
