Question about Dryers
Change the digital read out for time and charge.
I have a whirlpool model CGP2961EW1, serial number MJ4403817, type: BWSR-NAT-1206006-MC22. I have installed a new coin apparatus and am changing the cost of using the dryer from .50 to.75. I have figured out how to get the proper digital readout by using the drying temperature levels, but not how to make it set permanently. I have ended up unplugging the dryer and it resets to the original information. Could you please advise.
Thanks Mark
There are actually two hidden buttons that you cant see below the start button... Change the amount to what you prefer and press the hidden button across from the low temp. button twice.
Hope that helps, Mike
Posted on Dec 10, 2012
  • mpgil3479
    mpgil3479 Dec 10, 2012
3 Suggested Answers
  • 1028 Answers
SOURCE: the dryer belt broke and
sears..belt part #341241 probably and idler 691366 i think
Posted on Jul 24, 2008
Scoutlewis
  • 3 Answers
SOURCE: light comes on wont spin
Check the door switch. It just might be sticking which is why the light remains on and the dryer won't spin...
J. Lewis
Posted on Dec 21, 2009
My kenmore dryer with serial number: DESR-NAT-1206006-FM22 doesn't have heat at all and my clothes are still wet. What to do before I call the repair guy?
Clean lint screen could be clogged a dryer sheet can sometime block the grille if a loads to large and heavy that will result in wet clothes.some dryers have an option for air dry if that is selec
Jul 24, 2015 | Kenmore Dryers
Notice a "rubber"smell this winter. The lint vent is clean after each use, outside vent is clear of any debris. can the wind blow smell back into house or is it a belt? Installed new by dealer 1/9/13.
I have found that when people start smelling things in the dryer it's from chemicals from like paint or varnish,all the dryer does is move air when it gets hot you start smelling it.you can pull it apart and check the belt and rollers but your dryer has the lint filter on top and there isn't anything in there that could really make it smell,on some of these dryers the belt pulley doesn't have a wheel on it,the pulley is just a piece of metal with no moving parts and the belt rubs on the pulley but i've never smelt anything from that,like i say usually it's from having your floors done over the smell from the polyurethane coating or from paint can make the dryer smell.go here to take dryer apart
http://www.youtube.com/watch?v=xGIG8Wo5-N4
hope this helps
Jan 19, 2014 | Whirlpool Dryers
Whirlpool dryer dwsr nat 1206006 fm22 will not turn on when on button is pressed. There is a black plastic piece to the right of the metal catch on the dryer that if pressed the right way, the dryer will...
The peice your refering to is called a door switch, and its a pretty easy repair. You'll need your model number handy, and then contact a local parts distributor in your area. Once that is done, if your dryer is a standard whirlpool, you'll just take the two screws out of the top by the lint trap and pop the top up. Once thats done look down to the right and you'll aee the switch which is held in by two screws on the outside portion of the door.
Apr 28, 2012 | Whirlpool Dryers
My dryer is about 7 years old...it runs but no heat isnt spewing out....and it only works on the "timed" settings......Its a Roper super capacity.....model number RGX5634KQ2....serial...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 23, 2010 | Whirlpool Dryers
Light comes on wont spin wsr-maytag mod m6d5600tqo ser mw2607338 type bwsr-nat-1206006-fm22 light wont turn off even with door closed dryer is not old new in 2008
J. Lewis
Dec 21, 2009 | Maytag Dryers
Dryers Logo
55 people viewed this question
Top Dryers Experts
Richard Roth
Richard Roth
