Question about Whirlpool Gold Series GI15NDXT 15" Automatic Ice Maker with 25 Lbs. Storage Capacity, 50 Lbs Daily P...
THIN OR HOLLOW ICE
I RECENTLY MOVE MY ROPER REF WITH A WHIRLPOOL AUTOMATIC ICE MAKER IT WORKED FINE BEFORE BUT NOE IT MAKES THIN OR HOLLOW ICE ???
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
Freezer too cold and not much water. When it is empty of ice check the water level in the ice tray. Probably not even halfway up. Unplug fridge for 8 hours and plug it back in. Need more help please live chat. If this has helped, please rate as fixya.
Posted on Jan 10, 2009
Ice cubes are too thin. Making on time, but no volume due to small cubes. What part will correct this?
Well this thing is made to make ice cubes so if the ice cube are to small thin then you water supply must be restricted because its cold enough to make the ice just the volume of water isn't their .Check the feed system for restrictions .
Jun 01, 2015 | Whirlpool Gold Series GI15NDXT 15"...
ICE MAKER ONLY MAKES HOLLOW ICE
Hollow ice is usually caused by not having enough water in the mold. A strainer before the inlet valve where the water supply connects can get stopped up restricting flow.
Or look for an adjustment behind the plastic endcover on the ice maker with a +/- on it. - is less water.
Sep 21, 2009 | Whirlpool ET1FHTXM Top Freezer...
Ice maker makes hollow ice cubs or cubes with
Whats happening is the ice isnt freezing all the way. Try cleaning your condensor's under the frig.In Hotter weather when condensor's get filled with dust it causes the frig to cycle to ofeten. In turn your cubes aren't freezing all the way.
Jun 26, 2009 | Whirlpool Refrigerators
My ice maker is not making ice and has no water in the tray. the incoming line appears to be fine. Roper model #RS25AWXAL00 water dispencer puts out very little water. Ice maker works but cubes are...
Frozen water line at input to the ice maker. You need to defrost the freezer - this means moving freezer food to a dry ice loaded cooler for a while and then let the freezer defrost about 4 hours. That should do the trick.
May 23, 2009 | Refrigerators
Ice cubes are hollow.
some fridges are designed to make hollow cubes where they always hollow or just recently
Apr 13, 2009 | Refrigerators
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice Maker problem
check if it has one the filter, hollow ice = lack of water flow into the icemaker
Apr 26, 2008 | Refrigerators
Roper top freezer ice maker out of sync? Too warm?
sorry you must replace the icemaker.
Mar 30, 2008 | Refrigerators
Ice maker making hollow cubes
check your incoming water pressure, change the water filter recently? hollow ice cubes is a sign of low water pressure
Mar 05, 2008 | Refrigerators
Open Questions:
See all Whirlpool Gold Series GI15NDXT 15" Automatic Ice Questions
Whirlpool Gold Series GI15NDXT 15" Automatic Ice Maker with 25 Lbs. Storage Capacity, 50 Lbs Daily P... Logo
169 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
