Question about Planar CT1904Z 19" Flat Panel LCD Monitor
MY LCD PLANAR MONITOR PL2010M, 20.1", IS GONE BLANK
I BOUGHT MY LCD PLANAR MONITOR 4 YEARS AGO AND WAS WORKING FINE UNTIL LAST WEEK WHEN IT SUDDENLY WENT BLANK (BLACK SCREEN.) SINCE THAN, I HAVE TESTED IT WITH A NEW VIDEO CABLE AND WITH ANOTHER COMPUTER, BUT THE PROBLEM IS THE SAME. I SEE THAT THE LITTLE LIGHT ON THE FRONT GOES GREEN WHEN THE COMPUTER BOOTS UP; AND I KNOW THAT THERE IS NO PROBLEM WITH THE POWER. THE MONITOR APPARENTLY DOESN'T PROCESS THE SIGNAL FROM THE COMPUTER.
ANY SOLUTIONS?
THANKS,
DAVID MS
  • 82 Answers
Bad back light
Posted on Aug 27, 2010
Hi My Planar (PL2010M) suddenly went black. On restart, it flashes briefly but never comes on. Any suggestions?
I have a similar problem on my Planar PD470; power supply failed after about a year and a half. I heard that their HDTV power supplies had a higher than normal failure rate. I have someone working with the company to resolve, but I'm not optimistic... Bah Humbug. How long have you had your set?
Nov 09, 2010 | Planar PL2010M 20" Flat Panel LCD Monitor
PL2010m displays two colors stays on just blue and white
Sorry, but this sounds like a controller issue. Are you able to open the monitor's menu? If yes, try the monitor on another computer with other cables, if that doesn't help its a internal problem. The only thing you could try yourself is opening it up and reseat all of the cables. If that doesn't help, you should contact a professional or consider replacing the unit.
May 29, 2010 | Planar PL2010M 20" Flat Panel LCD Monitor
My 5 yr old daughter's monitor now has a blueish green cast to it. It is a PL2010M. Did she change a setting (very likely) or is there a problem?
To find out, I would browse through the on-screen menu using buttons on the monitor to find an option "Reset to default" or "Factory Settings" or something to that effect.
Oct 26, 2009 | Planar PL2010M 20" Flat Panel LCD Monitor
Pl2010m orange standby light, black screen
Try booting the pc in safe mode (press f8 at startup). It may be possible that the pc is trying to send too high a resolution to the monitor...unlikely though. The symptom you describe usually indicates that the power board or the inverter board in the monitor are defective. If it does the same thing in safe mode, you have 2 options.
1. Replace the power board and inverter board (do the inverter board first.......it's the cheaper one (10-20 dollars).
2. Send the monitor back to the seller for a refund, or get a new monitor.
Sorry I couldn't give you more positive feedback. Hope this helps.
Joe
Oct 13, 2009 | Planar PL2010M 20" Flat Panel LCD Monitor
Planar 2010M auto adjust
This may be related to a power supply problem that these monitor have. I think you need to fix the power supply board inside the display itself. It's giving the logic board and backlights fluctuating power and they have weird / intermittant problems.
There is a supplier of power boards online, you can google them with numbers from the board but I don't suggest using them. Look for information on the company before you buy from them. I've seen a lot of complaints for this "international" company.
First check that you are getting a strong 12V from the external power adapter. If so, the problems may be as simple as changing out a few capacitors. (about $8 in new capacitors, plus shipping)
On the PL2010M monitors you need the following parts. I've added digikey part numbers to make life easier:
P10271-ND 220UF 25V Capacitor (3 or 4 depending on PS)
P10275-ND 470UF 25V Capacitor (1)
P10221-ND 470UF 10V Capacitor (4)
If you're not comfortable with soldering and de-soldering electronics, take it to a local technician for the work and give them the parts list above. That should work to fix your issues. I've fixed several of these monitors so far. All the problems were related to the power supplies having bad capacitors. Same with the Planar PL1700 LCD monitors.
There is also a single capacitor on the display logic board, but I haven't seen this one go bad yet.
-Chip
Nov 22, 2008 | Planar PL2010M 20" Flat Panel LCD Monitor
Resolution problem
A Chip on the monitor circut board must be reflashed. You need to send back to Planar, do an rma. They were very responive to me, sent me a replacement.
Sep 07, 2008 | Planar PL2010M 20" Flat Panel LCD Monitor
Pl2010m
This is the same problem I've seen several times. Fix the power supply board inside the display itself. It's giving the logic board and backlights fluctuating power and they just can't keep up.
There is a supplier of power boards online, you can google them with numbers from the board but I don't suggest using them. Look for information on the company also. I've seen a lot of complaints for this "international" company.
The fix for most of the problems on these monitors is about $8 on new capacitors (Plus shipping).
If you're not comfortable with soldering and de-soldering electronics, take it to a local technitian for the work and give them the parts list above. That should work to fix your issues. I've fixed several of these monitors so far. All the problems were related to the power supplies having bad capacitors. Same with the Planar PL1700 LCD monitors.
-Chip
May 31, 2008 | Planar PL2010M 20" Flat Panel LCD Monitor
Backlight replacement
Are you sure it's the backlight? Many Planar LCD monitors have issues with the capacitors on their power supply boards. The symptoms include a power light and no picture, or just a flash of a picture when powering up and then nothing.
The fix for some of these problems is about $8 on new capacitors (Plus shipping).
P10271-ND 220UF 25V Capacitor (3/4 depending on PS)
If you're not comfortable with soldering and de-soldering electronics, take it to a local technitian for the work and give them the parts list above. That should work if the failure looks like I described. I've fixed several of these monitors so far. All the problems were related to the power supplies. Same with the Planar PL1700 LCD monitors.
Jan 31, 2008 | Planar PL2010M 20" Flat Panel LCD Monitor
Bad power board Planar PL2010M
-Chip
Nov 25, 2007 | Planar PL2010M 20" Flat Panel LCD Monitor
Replacement External Power Supply
So the old power supply doesn't have the output voltage, current and polarity noted on the label? What a ripoff! *grin* Did you look on the case near where it plugs into the monitor? Sometimes that will tell you the voltasge and polarity. Poliarity? Get that one wrong and the monitor could be cooked instantly! But it's usually positive. I found a completed eBay listing that had this info: "the power supply which the seller used to power up this Planar Flat Panel is inventoried as follows: ViewSonic 12V Power Adaptor Model # SYS1126-5012" I looked that one up, and it's listed as 12V at 4.17A. PC Hub has them for $28.62: http://www.pchub.com/uph/laptop/345-19804-2285/AC_Power_Adapter_5V-12V_Others_SYS1126-5012.html Good luck!
Jan 06, 2007 | Planar PL2010M 20" Flat Panel LCD Monitor
Planar CT1904Z 19" Flat Panel LCD Monitor Logo
350 people viewed this question
Top Planar Computers & Internet Experts
William Miller
William Miller
Jay Plesset
syspro
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
