How can i come to know that the processor supply to my system is as per my demand, without using any hardware tools?
    Novelist:
  • 93 Answers
Right Click on "My Computer" (it is on your desktop or Start Menu)
Left click on Properties
On the lower part of the box that opens, you will see the Manufacturer of your system, as well as CPU brand, speed, amount of RAM, etc.
Cheers
Nick
Posted on Nov 19, 2008
Why is my eMachines EL1360G processor overloading?
Without knowing the specs on your computer, I would say that the problem is not your CPU (processor) or Firefox but possibly several reasons:
>If you are streaming hi definition video your integrated graphics processor is inadequate for processing the video. You are getting what is called "dropped frames", which means that the video card (probably part of your motherboard as opposed to an independent video card installed inside the computer) is not powerful enough to process the incoming video stream, which means if falls behind in supplying the video;
>You have inadequate amount if memory for doing the video processing since it is being shared with the memory demands needed to run your computer's operating system.
>You have programs or PUP (Potentially Unwanted Programs) adware/spyware running in the background that is interfering with the system (very likely); you need a general system cleanup to get your unit back up to speed. Side thought: do NOT use these popularly advertised "register cleaners" or "system cleaners". People bring their computers to me all the time when these garbage programs trash their system.
>Your internet connection is slow-believe me, this is a hugely common problem.
If you need more help, I hang out at www.suggestafix.com
This is a free computer help forum, post in at the Hardware section.
Jun 29, 2014 | eMachines EL1360G-UW11P
Machine check exception
it is hardware problem change power supply unit and try
May 16, 2012 | E-Machines eMachines Desktop PC
Why does a 3 hour video req 9 Gb of disk space
It depends on the codec used, but video tends to eat space if in a high enough resolution to be enjoyable anywhere but in a small browser window.
Rule of thumb for high quality video is 4gb per hour. And, that's not even hi-def, just high quality.
MP4 codecs can cut that almost in half, but there are trade-offs, including increased processor demands, a tendency to lose audio sync, and blotchy black backgrounds/shadows.
Jun 25, 2011 | Computers & Internet
Dell power edge 2850 make 4 seconds beeps alarm without stopping and without show any error Msg on the screen.
I don't understand the beep code you describe, but the 2850 has many beep codes to help understand what is going on.
First ... Identify the beep. Does the beep start as soon as you power it on, or after several seconds? What is the pattern of the beep - is it a repeating set of beeps - 3 sets of beeps between 1 and 4 beeps ... like 1 beep-3 beeps-2 beeps, or 3 beeps, 3 beeps, 1 beep? Or is it a steady repeating beep - about once per second?
Second ... is the LCD panel on the server blue or orange? If orange, what is the error code(s) it is scrolling?
If it is a steady, once-per-second beep, it is probably your RAID controller. Does the system boot to Windows/OS ok? If so, use (or install) OpenManage Server Administrator (Managed Node from Dell's Support Site) to check the Hardware Logs and check the RAID array (under Storage/Virtual Disks). If it is not booting to the OS, then go into CTRL-M to see what the status of your array is.
Aug 16, 2010 | Dell 3.0 GHz Second Processor for...
The controller will not turn on. Green light on back comes on but when we turn on the unit, the fan starts briefly and then the power cuts off.
Bad Power Supply. Weak Voltage power rail.
Not enough power to turn the Processor on, and keep it on.
1) ALL those LED lights together, use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts
3) A typical Processor can use 51 to 125 Watts. Depends on what Processor it is. (Older Processors use less Wattage)
The Compaq Presario SR1810NX desktop computer, comes with an AMD Sempron 3200+, processor.
(Uses the Socket 939 processor socket)
[Maximum operating capability is a 1.8GigaHertz frequency rate.
1.8GHz
Giga = Approximately 1 Billion
Hertz stands for Cycles per Second.
Frequency Rate is correct computer speak for 'Speed'
The AMD Sempron 3200+ processor, can operate at a maximum frequency rate of 1.8 Billion Cycles per Second ]
HP Support >Compaq Presario SR1810NX desktop computer > Product Information > Product Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00609384&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=1841795&lang=en
The AMD Sempron 3200+, can use up to 62 Watts,
http://en.wikipedia.org/wiki/List_of_AMD_Sempron_microprocessors#.22Palermo.22_.28Socket_939.2C_E3_.26_E6.2C_90_nm.29
(Palermo Core)
When you press the plastic Power On button, you are contacting a Power On switch inside it.
(Typical ATX Power On switch,
http://www.directron.com/atxswitch.html )
When an ATX power supply is plugged into power, there is a 5 Volt Standby power, present inside the power supply.
Pressing the momentary contact power on switch, closes a circuit that directs the 5 Volt Standby power to 'excite' the power supply, and turn it on.
The first chip to receive power is the BIOS chip.
[Chip and Chipset are slang terms for I.C.
Integrated Circuit.
BIOS stands for Basic Input/Output System]
BIOS,
http://en.wikipedia.org/wiki/BIOS ]
BIOS looks to see what devices are installed, does a Ram Memory count, TURNS the Processor on, and hands the computer over to the Operating System.
(Windows XP is one example of an O/S. Operating System)
The LED lights receive power, so do the fans, and the Harddrive. When it's time for the Processor to kick on, there isn't enough power, and the Power Supply 'falls to it's knees'.
Replace the Power Supply.
It's just one of the basic ATX power supply's that are readily available in a multitude of places.
The Wattage is 300 Watts.
The ATX form factor for this power supply, (Size and shape), is approximately 6 inches Long, 6 inches Wide, and 3-1/2 inches Tall.
Power cables needed:
(Continued in a Comment)
Aug 02, 2010 | Compaq Presario SR1810NX Sempron 3200+ 1.8...
I just bought a new motherboard; basically new everything, well on my old motherboard there was a CPU and on this newer better motherboard there is not a CPU. Do I need to got one? What is a CPU exactly?
first, make sure that the new mother board support the old Processors, ask the M.Board supplier about it (or google it) , and make sure you know the old processors type.If you wasn't really sure, just remove the old Processor from old M.Board, then check for the ID (such as Pentium 4, Pentium D, etc ) on top of the processor.
If the new M.Board support the Processors, then you can re use the old processors, if don't, then you don't have a choice, buy the new one that match with the new M.Board specifications.
Hope you understand.
Feb 22, 2010 | Office Equipment & Supplies
ACME Skateboards Inc., has paid consultants to look over last year's sales and provide them with supply and demand equations that fit their sales data. The consultants provided the equation S = 0.09x^2 -...
Doesn't any body do their homework anymore? How are they supposed to learn anything?
Draw your graphs by hand or on a graphing calculator.
Think about the intersection points. (What does that mean when two curves intersect?)
Use the equation for the demand to obtain D for a particular x.
You can also determine by how much one function exceeds another for a particular value of the x variable (the graph is rather clear).
I assume you can solve a quadratic equation.
Use these hints to solve the problem.
Here is a graph. I even restricted it to the first quadrant so as not to mislead you into giving meaningless answers.
Hope it helps.
Oct 04, 2009 | Office Equipment & Supplies
Graphics card for D 101 GGC intel mobo/2.66/p-4/ram 512
Good news, you can upgrade the graphics card with almost any current PCIe (PCI Express) video card. Once you install a new graphics card in your system, the ATI Radeon x200 will be disabled automatically, as per the manual.
The one caveat is that the board is not PCIe 2.0 compliant, so any video card that requires PCIe 2.0 compliance will not work. This is not an issue as almost all modern graphics cards work on PCIe 1.0. However, make sure to check the requirements o fthe card before you buy it.
As for the most suitable graphics card for you, its hard to say without knowing what tasks you wish to use this computer for and what is your budget. If you are only using it for office tasks, then the onboard graphics processor is more than enough for your use.
I should mention, that the motherboard processor support constrains you to the P4 series of CPUs. This is fine for moderate tasks, but if your gola is to play a game like Crysis, then even the most powerful, multiGPU graphics card will only make the game playable. You will probably never be able to max out your frames per second.
That said, the board supports up to a 3.4ghz CPU, which is fast enough to play almost every modern game if you upgrade to a powerful graphics card.
If you wish to do 3D graphics design, I would not recomend upgrading the video card for this purpose. Video rendering and processing stil does rely on the CPU. However, if you look into nvidia's CUDA framekwork, it is possible to offload rendering to the GPU. This is probably not worth the effort unless you are relaly short on cash.
Bottom line is, yes you can upgrade no problem. As for the best video card, I do need to know he reason you wish to upgrade the video card.
Sep 06, 2009 | Computers & Internet
Installing LAN card
Can you connect to the internet?
Mar 07, 2009 | IBM (02K2776) Pentium II, 350 MHz...
Partmgr sys
did the computer originally come with windows xp or an older operating system?looks like you may have some hardware issues.download ultimate boot cd from this link.Follow the directs to burn the image to disc.Boot from the CD and run memtest to check your memory,then run any of the hard drive diagnostic tools from the hard drive manufacturer.Let me know what happens after that.If none of the hardware fails I will recommend using one of the hard drive formatting tools to do a low level format on your hard drive and try installing the operating system again.note,if you have files that you need on the hard rive you'll lose them if you reinstall the operating system without backing them up.
Aug 21, 2008 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
Alun Cox
David Payne
David Payne
