Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer not spinning or draining. Making LOUD grinding noise.
We were doing laundry yesterday and heard a very loud noise, almost like the sound of a sink garbage disposal (but louder), coming from the laundry room. It turns out that the sound was coming from the washer. I turned the machine off and tried to turn the dial to get it to do anything, but it just makes that noise. I can't drain it to get the water out either. Any suggestions? I read the boards, and it looks like it might be the coupler. The washer is about 4 years old, so I will see if Whirlpool has any ideas.
  • ryanhall Nov 21, 2008
    Luckily, I finally got the thing to drain, and then I pulled the machine apart and the coupler piece was broken. So, I replaced it for $18 and it seems good as new. Thanks for the offer of help and I am very thankful it's not the transmission.
  • rsbonica Nov 24, 2008
    I may have more than one problem. For the past week the agitator was turning slowly and seemed like it was jumping over a bad gear or spline. The agitator movement also came with a clunking noise as it slowly turned. Now it also will not pump out the water from the tub. The switch below the cover is working but it only puts water in on the rinse or spin cycle but will not pump it out. Thanks.
I started a load it aggetates but when it gets to next cycle it does nothing . i can hear timer switch to next cycle but it doesnt soin or drain .what can it be?
Posted on Jan 14, 2009
Tried to star up our gas fireplace after a couple years of non use. It did not start up till after about 10 tries pressing the on button.
Now it usually lights up after 3 or 4 tries but will not stay lit till after relighting it 3 or 4 times. Our fireplace does not have a blower. Thanks for any help provided.
Posted on Apr 23, 2011
  • 370 Answers
The drive coupler does not make the machine have a loud grinding noise. And if it was just the coupler the machine would drain. Your transmission has gone out. You may be able to find a used one at a local used appliance store. if not, you can get me the model number and i can get the part number the transmission. Sorry for the bad news but it is Your transmission for sure.
Posted on Nov 21, 2008
  • Justin Duby
    Justin Duby Nov 21, 2008
    Glad you figured it out. sorry for the bad info. The coupler usually doesnt make a loud grinding noise but a soft one. Glad you got it fixed.
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
My washer will not spin or agitate, but will fill & drain
with it empty need to look at the bottom of the unit and see if the pulley and belt setup is bad.. my sisters un it broke the pulley and hers is newer..seems they dont make them to last anymore..
Feb 08, 2014 | Washing Machines
Loud metal grinding noise during wash cycle kenm ore 11020022011
All Kenmores are the bottom of the line appliances. If under warranty, call Sears. Your machine has problems. May be on it's last legs. None of these sounds are 'normal'. Motors wearing out, likely.
Mar 04, 2018 | Kenmore Washing Machines
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer is loud, and won't spin or agitate
check the motor bushes,and also check for bearings in drum you can check this by lifting the inner drum up and down if you feel a knocking noise then this will be the bearings have worn.
Jul 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer loud grinding noise spin stop
if its brand new it shouldnt be making a loud grinding noise id get it checked make sure they removed all shipping bolts
May 17, 2009 | Maytag Washing Machines
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
Whirlpool Duet Washer Making Loud Grinding Noise
not nesseccarrily your pump, possible you have a rear bearing going bad, which will sound as if a helicopter is coming through your laundry room. ( noisy pump can be the issue , honestly a better and cheapre problem to have) in order to determine if its apump problem you can remove the lower access panel and unplug the pump then start the spinn cycle, if it still loud the pumpms not hte issue.
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My Capacity Plus Admiral Washer will spin and agitate, but it makes a loud grinding noise.
Well, Sounds to me like the Bearings are going out, but it could make that noise a good while, before it goes completely out.. Replacement would possably be more cost effective, Kinda hard to beleive !!!!!!
Oct 26, 2008 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
1,436 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
