Question about RCA T19060GY 19 in. Combo
TV won't turn on
My dog sat on the remote and the TV hasn't turned back on since. I unplugged it for over 12 hours and it did the same thing when i tried turning it on again. The power light flashes three times and the TV never turns on. I've tried different outlets and there was no noise when it went out. It doesn't work manually or with the remote.
    Problem Solver:
  • 16 Answers
Also, try taking the remote batteries out. Maybe the power button is broken on the remote...
Posted on Nov 06, 2017
  • RCA Master
  • 22,117 Answers
  • 68 Answers
SOURCE: f32650/atc113ca1
This could cause a problem, because modern TVs and most other entertainment electronic goods, have a small kind of computer chip, but there should be a Reset button probably inside the set! If you feel confident about computer chips you may be able to find the button by tracing the circuit.(Disconnected from the mains). Another idea is if there is a small button cell or battery inside, then try disconnecting it for a day. Good Luck!
Posted on Dec 02, 2006
  • 236 Answers
SOURCE: TV won't stay turned on, no picture, started making high pitched noise
That high pitched noise you're hearing is the power supply telling you that it has too much of a load on it and lowered its operating frequency which in effect cuts its output way down! Normally you don't hear any thing since the power supply operates at a frequency that's beyond human hearing. In an RCA this indicates more than likely that your horizontal output transistor is shorted and this short was caused by the flyback transformer shorting. This is a common happening with RCA's You'd need to take to a tv shop and have it checked out. Stargazer
Posted on Feb 04, 2007
techman
  • 3130 Answers
SOURCE: TV On/Off button blinks but never turns on.
Ok you did not cause the problem as you could always turn on the TV set from the front panel button,, If the TV set will not turn on even with the front panel button, there is a major fault with the TV set. This is not a reset that can be done by the user as there is a circuit fault and will require you to take the TV set into a shop to be diagnoised or replaced. Good Luck
Posted on Mar 27, 2007
SOURCE: Screen is Black Power Light Blinks Three Times
bad power sorse bring the tech in unless u know how to chage outthat part
Posted on Mar 15, 2008
SOURCE: on/off button flashes green, unit will not turn on manually or with remote
PRESS THE TV BUTTON OF YOUR REMOTE CONTROL FOR FIVE SECONDS AND YOUR TV WILL TURN ON.
Posted on May 30, 2008
Sony bravia 65 inch won't turn off
There is one main thing you need to do before any thing you need to unplug the Tv leave off for 24 hours not plugged in do not temp to plug it in then after 24 hours off you need to plug in do not try the remote or press any buttons ok at all just plug in and leave it for 24 hours plugged in then you can unplug the Tv for 30 mins then plug back in and try to use the remote or press the buttons if it still don't work then the power board might be the problem but get back to me afthe 2 days ok to see how you got on
Jul 10, 2017 | Sony Televison & Video
TV won't come back after pushing wrong button on remote.
Try unplugging the TV.. After you plug it back in it may be OK. I had a similar problem were I could not turn on the TV (JVC). The owners manual specified in the troubleshooting section to unplug for 1/2 hour. I left it unplugged overnight and the next day plugged it in and it was fine.
May 21, 2013 | Televison & Video
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
TV says lost signal and turns itself off
Unplug the TV from Wall, wait a bit and plug back in. Should be reset.
Feb 09, 2010 | Vizio L42HDTV 42 in. LCD Television
After short warmup period remote control will not change channels or display TV Programme guide. Unit must be switched off and then back on for remote control to operate properly. Problem repeats after a...
Easiest things to check first:
Are your remote controls working: check batteries; check infrared on remotes by viewing with camera phone/camcorder; make sure your remotes are programmed properly for the device.
Another option: do a hard reset of your TV-unplug it and let it sit as indicated in the manual; then turn it back on.
Another option: unplug the TV and use an air-can and thoroughly dust ALL the component input/output access points on the TV. Turn the TV on and see if this works.
Another option: unplug the TV and connect standard 1/8" headphones in the output of the remote OR headphone jack on the TV [try both]. Turn the TV on and see if this helps.
Finally, if these steps do not work: unplug the TV and let it sit for a good hour. Open up the back panel carefully and air dust the remote control sensor. If this does not work, change the remote control sensor.
Hope this helps.
Jan 23, 2010 | LG 42LC2D 42 in. LCD HDTV
TV won't turn on
read from other forum. wouldn't hurt to try, unplug the power for 2 days and plug back in again to see if it will turn on.
Mar 10, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Tv wont turn on
stephster, check to see if you have a reset button on the back of tv good luck-hope this works for you
Nov 05, 2007 | Panasonic CT-36HL43 36" TV
Toshiba TZ50V51
Small dog or large==coincidental/unrelated to problem!General service includes some very precise soldering==requires chassis pull. One or more micro-fuses will be bad and STK IC's should be replaced.Alignment in servicer menu may be needed after repair completed.
Oct 03, 2007 | Mitsubishi WS-55807 TV
TV won't come on!
your system control section has failed due to sudden power failure. 1please check power to system cotrol. 2check tunning &aft ckt in system. 3check memory ic & its section 4check system ic & its section regards
Sep 12, 2007 | RCA F32650 32" TV
RCA T19060GY 19 in. Combo Logo
37 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
