Question about Goodman GMS90703BXA Heater
Water in pressure switch line
I have an amana model number (according to tech) gdc070x30b and every year on startup the pressure switch has water in it and I pay a guy to blow the water out. Is there a fix for this? Cost me $75bucks again this yr! It is a horizontal unit in the atlanta area and is located in a crawlspace. Thanks for any help or steer to somone who can help
  • jgeraldg Nov 20, 2008
    Thanks for the suggestion, will give it a shot. The repairman claims he has one just like it and he has to do the same thing every year! How much should I charge him for the fix? LOL
    Problem Solver:
  • 5 Answers
Relocate the pressure switch so ir is higher than the original location. If the installer knew what he/she was doing they would have done this already!!!!!
Posted on Nov 19, 2008
  • ricks hvac Nov 20, 2008
    Charge him double because now it should be fixed
Amana AFI2538AES The refrigerator portion keeps freezing the fruits and vegetables. The chiller control is on the warmest setting and the refrigerator temp is set at 43. I have been raising every once...
Our Amana afi2538aes is doing the same thing. Had a repairman out. He called tech support at Amana. They had him adjust the "thermistors" but it is colder than ever running at 28-30degrees in the fresh food compartment despite being set at 46 degrees. Tech support also recommended installing some sort of "ice bin seal kit to take care of the problem" according to our invoice from repairman. Repairman was told that the ice bin in the fresh food compartment puts cold air out (to keep the ice frozen) which freezes the food in the fresh food compartment. I called Amana and the rep I spoke to said he couldn't find record of this being a problem with the model but tech support told our repairman "we've had a lot of problems with this happening."
Mar 31, 2011 | Amana AFI2538AES Stainless Steel (256 cu...
Where is the water filter on the amana #scd25tw
The Amana with model number SCD25TW does not have a water filter. You would have to install an in-line filter on the water supply line if you want to filter the water. If your talking about the model number ARS266ZBS, then open the refrigerator door and look at the top right hand side. You should see a filter housing with a tab to release. Once released you have to remove the filter from the housing to replace it. When finished be sure to run about a gallon through the dispenser, to flush any air out of the system.
Mar 23, 2011 | Amana ARS266ZBS Side by Side Refrigerator
My Kärcher K2.080 pressure cleaner (1450psi /
According to my search, Karcher has a 2 year warranty on this product. If you can get the serial number and model number off of it. They should be able to identify when it was made and then can honor that warranty. Otherwise the pump seals appear to be damaged by your description of the problem. Hope I've helped.
Best, Mark
Dec 28, 2010 | Karcher Electric Cold Water Pressure...
My Amana side by side has a serial number of 36278. Very little water from the door, and hollow cubes.
Sounds like the screen filter in your water line is stopped up. It's behind the fridge where the water supply comes in. Take the line off and flush it out and see how much pressure you have. The filter is just before the water goes into the water inlet valve.
Nov 03, 2010 | Amana Refrigerators
I have a laars lx 250000 btu pool heater that keeps going off on the water flow switch. When the pool was opened this year they said that they had changed the filters and backwashed the system. Would it be...
Check the Filters and Skimmer FIRST even though they said they backwashed and checked the system. I am not sure how you determined it is the water pressure switch? If you do have sufficent flow of water in and out of the heater, the pressure switch could need replaced or the small copper feed line from the heat exchanger to the pressure switch could be obstructed. You really need a Heater Tech that can check the pressure switch for proper functioning and any obstructions in the feeder line, Normally you will find the Skimmer and or Filters are the cause of low water pressure.
Jun 24, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
I need a part number for a pressure switch for an Amana Furnace GUCA070BX40
Check this out. You ave to apply negative pressure to make the reed switch click, that means you have to apply suction to the switch to check it. most of these switchs ain't the problem. Blocked tubing yes bad switch naw.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 20, 2010 | Heating & Cooling
I have 15 year old Amana horisontal furnace model gsc075a30a. it was working fine till the exhaust fan cracked and needed replacing. I have done that and the fan works good but I had to bypass the...
If there are markings on the pressure switch as to what pressure it closes at, you may be able to substitute another brand pressure switch. Amana is made by Goodman. Maybe you can cross reference the switch with a Goodman distributor. Try Amana parts at 1-407-699-5411.
Nov 25, 2008 | Amana Heating & Cooling
Amana fridge water filter squealing
I would suggest that you put the new water filter back in and try dispensing water for about ten minutes. If there is still a high pitched noise then you could try bleeding the water line at different points along the water circuit (with control over the incoming supply). The fact that you are forcing water through the tank should normally resolve any air locks. The water filter could also be bled of air. Hope this is of some help.
Sep 05, 2007 | Amana ASD2326HE Side by Side Refrigerator
Goodman GMS90703BXA Heater Logo
59 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
