Question about Samsung SyncMaster 913V 19" Flat Panel LCD Monitor
Samsung Monitor Syncmaster 913V Montior Screen shows patches of screen on desktop and playing videos
My monitor keeps showing patches of green making the desktop look like out of focus..the green patches shows up on video and pictures...lines of green.
  • 89 Answers
Try to reset the monitor to its default settings.
Posted on Aug 24, 2008
SOURCE:
Samsung Syncmaster913v Monitor. The screen is totally black, but when I remove lead from computer it shows "Check Signal Cable" in colour. Also when I press Menu, in top left hand corner...
If the color still works, and it works on other computers, there is something wrong with the computer in question. But this is not the case, so logically, something is wrong with the monitor. Check the cable for broken pins.
Feb 11, 2011 | Samsung SyncMaster 913V 19" LCD Monitor
Samsung lcd television the screen goes blank after 20 mins of watching there is still sound though
right click on your desktop.go to properties.then go to the screen saver tab.click on screen saver tab.then you will see call monitor power.click on the power icon.go to the settings forr home/office desk power scheme.there you will see a setting called (turn off monitor)change that.let me know if it did work hay.
Sep 07, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Half of the screen is black - Samsung SynchMaster 710N
hello
I am a technician-informatic. I have repaired about 80 Lcd Samsung monitors with theese problems. I offer the repair manual.
Manual has been done with the experience of the repairing Samsung Lcd monitors. Manual was made by me and shows how to open monitor, how
to solve dark screen problem, how to check and replace capacitors, how to solve the problem non-optimal mode (without reprogramming MCU or
changing the main board) photo are included. 100% functional. The repair process is very simple 30-40min. (does not need a lot of
experience in electronics and expensive instruments) and is not expensive. With this manual you can solve problems by yourself and save
money.
"Not Optimum Mode 1280x1024 60Hz"
- The monitor turns on but turns off by itself, the LED blinks green.
- If you detach from the PC points to "control cable" the picture runs continuously in the vertical direction or presents while line , and
as soon as it is reconnected, the monitor goes off.
- The monitor does not turns on and dont dispaly anything, the LED blinks green-lit, if you detach from pc points to "control cable".
- The monitor turns on, works well some time, but after a window apiers "Not optimum mode. Mode recommended 1280X1024 60Hz"
- The monitor turns on, works well only with low resolution 800x600, when try to change a window that reads "Not optimum mode. Mode
the manual you can find on ebay (my ebay name is asnerejas123):
Samsung monitor repair manual guide 710n,913v,510n more
220498646211
Riparazione - repair Lcd Samsung monitor 710n,913v,510n
220498645860
Reparaturhandbuch für Samsung 710n,913v,510n und andere
220499443698
Sep 05, 2009 | Samsung SyncMaster 710N 17" LCD Monitor
Cannot set my SAMSUNG SYNCMASTER 710V MONITOR RESOLUTION
When you can't change the screen resolution then most likely only the default VGA driver has been installed. You need to install the graphics driver of the video card that is installed in your computer.
To check which graphics driver is installed, click on Control Panel - Display - Settings - Advance - Adapter tab. If the graphics adapter is set for Standard VGA then the graphics driver was not installed.
Aug 22, 2009 | AOpen Black 17" CRT Monitor
Samsung 913V LCD Monitor--No display when vga plug plugged in
1. please check by pressing num lock or caps lock key to verify that your machine is booting up, if yes then check the cable and if after changing the display cable it doesnt show up anything, it means you have a faulty unit
2. if numlock/caps lock key doesnt work, then your machine is not booting up, please check for loose ram etc.
Apr 04, 2009 | Samsung SyncMaster 913V 19" LCD Monitor
New Samsung monitor returns only a blank screen when turned on. what can I do?
hello
money.
220498646211
220498645860
220499443698
Feb 04, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Syncmaster 913v
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very easy and simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it.
or just enter number in search field: 220409788372
thank you
Oct 26, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Image not displaying properly
Before assuming it's the monitor, try it on another display card.
It is possible that there is a problem in the configuration of the display card, or a defect in the display card.
Is there a computer service place, or a monitor sevice center near to where you live. You can then take the monitor to have it properly checked for you.
Jerry G.
Jun 03, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung Syncmaster 710n monitor - screen goes black for no reason. All cords connected properly. Computer works with other monitors. Switch on front of computer is on - green light on. Get floating...
in safe mode adjust the resolution lower than 1280x1024
then restart and then install the driver again the driver is crrupted than install the right driver problem could be solved
May 16, 2008 | Computers & Internet
Sounds like your LCD panel has gone bad.
If the unit is under warranty, take it to a Samsung repair shop. If it is not under warranty, go buy a new one. LCD panels are usually more expensive then buying a whole new monitor.
Mar 21, 2008 | Westinghouse L1975NW Monitor
Samsung SyncMaster 913V 19" Flat Panel LCD Monitor Logo
490 people viewed this question
Top Samsung Computers & Internet Experts
asber
Stormi  Paulk
Stormi Paulk
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
