Question about MXL 990s Professional Microphone
Pls help just bought a mxl 990's mic and have it running through a yamaha model mg10-2 mixer and cant seem to get sound out of the mxl, however i have an older mic that if plugged in to the same in put works fine...i have this running through my desktop computer with sound forge and acid pro 6.0...my mixer runs through rca speakers
The MXL 990s requires 48 volts to operate. If your mixer does not have a phantom power option, you will need to purchase a microphone pre-amplifier with phantom power to interface the microphone to your mixer.
Posted on Jan 30, 2009
Anybody knows mxl 990 works with behinger usb 302 mixer??
The user manual says Phantom Powered Mic input which means you should be able to use a condenser microphone requireing Phantom Power.
Mar 24, 2013 | MXL 990 Professional Microphone
No sound from mxl 990 condenser mic
From the Micropower PS400 product description it states:
"routes the microphone signal to a mixer or a microphone preamplifier."
• these is just a phantom power supply.
One reason your former setup is OK , is that
tascam m-50 is a mixer preamplifier.
• phantom power supply is just a part of the mic preamp of the mixer
to power up your mxl 990 condenser mic
• What you may need is something like these:
X2u XLR to USB Signal Adapter
Sep 29, 2012 | MXL 990 Professional Microphone
I am trying to record with my mxl 990 micrphone onto my laptop but when i try to record no sound is heard
you can't just plug and play with these high end mics. You require a +48v phantom power source from something such as a mixer. Then plug the mic into the mixer and the mixer into the LINE IN on the PC
Jan 07, 2011 | MXL 990s Professional Microphone
I've tried several mics: mxl 990, Sure sm58/57, an AKG mic, and I get very low input signal or no signal at all from the mxl 990. The problem is the same regardless of phantom power. Cranking the input...
1. maybe the impedance of you mic did not match to your sound card..
2. sound card did not support you dynamic mic...try to use FET or condenser mic..
May 24, 2010 | Tascam US-1641 Sound Card
I have a MXL 990 studio mic which I recorded one no longerworks
Are you using the original cable for the mike? In order to use phantom power the XLR connectors have to be wired in balanced configuration. Pins 1,2 and 3 must be wired separately. If you use a cable with 1and 3 connected you could damage the phantom power supply and in some cases the microphone.
Aug 19, 2009 | Marshall MXL990 Professional Microphone
Adobe Audition 3 Not Sensing Mic
Check the input and output settings. Look in the preferences or settings menu for "i/o settings" or "i/o setup." You're going to set it from the default internal mic input to this one. It sounds like it may be that simple.
Jul 29, 2009 | Behringer B-1 Professional Microphone
I bought a MXL 990 USB, and I cannot connect it to my PC. I followed all the instructions, but couldn't get a sound from it. Can somebody help me? I have Windows Vista
Make sure you've switched your sound input from the default (internal mic/input) to the MXL 990. This should be somewhere in the sound options.
If you're sure it's not getting power, you need to send it back.
Jul 23, 2009 | Portacom Porta-Com COM-60FC 6 Headset...
Can't operate my MXL 990
If it is an MXL 990 Condenser that comes in the grey case with a shockmount and a black hard mount I can solve your problem. (If it is USB I know nothing about that unit).
This MXL 990 microphone MUST have 48v phantom power in order to operate. If you aren't familiar with the term phantom power read the first link:
Phantom power - http://en.wikipedia.org/wiki/Phantom_power
MXL User Guide - http://www.mxlmics.com/support/guides.html
If yours is one of the older MXL 990's it should have an XLR connector on the bottom -
XLR Defined - http://en.wikipedia.org/wiki/XLR_connector
Your mixer (I am guessing its a Peavey, Tascam, Mackie) or something entry level like that may or may not have phantom power. I am guessing not. But if it does, it will have a switch that says 48v phantom power and most likely a green or red LED next to it to show you when its on. This mic will NOT work without phantom power.
Best suggestion: Verify that your mic is the MXL 990 Condenser, if it is it needs 48v phantom power. Check your mixer and see if it has 48v phantom power. The only computer soundcard that I know of that is used by a lot of folks is the M-Audio Delta 1010LT. It has XLR inputs but NO phantom power on it.
There's your answer.
Ray
Feb 09, 2009 | MXL 990s Professional Microphone
MXL 990 doesn't work
Your other preamp does not have phantom power to supply power to the microphone. All condensor mics like this need phantom power. The Audio Buddy provides phantom power, which is why it was shipped with those condensor mics
Jan 16, 2009 | M-Audio MXL 990/991 Recording Mic Duo and...
MXL 990s Professional Microphone Logo
208 people viewed this question
Top MXL Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
drivealot
Are you a MXL Audio Player and Recorder Expert? Answer questions, earn points and help others
