Question about ASUS P5PE-VM Motherboard
Windows XP not starting after power outage
We have a HP Pavilion a1106n computer with a startup problem. The problem began after a momentary power outage (they happen regularly here). When the unit is powered up, it begins normally with the (1) HP INVENT screen, with options of ESC, F1 setup, or F10 system recovery. Then (2) a blank screen with cursor for a few seconds. Then (3) a screen to select the Operating System: XP Home Edition or Windows Recovery console, with XP Home Edition selected. Then (4) a screen with a message that Windows did not start successfully with options: SAFE mode, SAFE mode with networking, SAFE mode with command prompt, Last known good configuration, and Start Windows normally.
Starting Windows normally will bring up (5) the Windows XP logo for a few seconds then flashes a blue screen with a message (too quick for me too read), power blinks off then back on and goes through the same routine, starting with the HP screen.
When the screen (3) asks which O/S, and Windows Recovery Console is selected, after a few seconds a blue screen with the message: Windows shut down to prevent damage UNMOUNTABLE_BOOT_VOLUME. Technical information: ***STOP 0x000000ED (0x826BBAD8, 0xC0000006, 0x00000000,0x00000000). After rechecking recently,the first group in paretheseees is now 0x826BB9E8.
If SAFE mode is selected, the screen goes to (3) choose O/S. If home edition is selected, the screen shows lines that begins with: multi(0)disk(0)rdisk(0)partition(2)WINDOWSsystem32DRIVERS toskrnl.exe. About 32 lines in all. after a few seconds, the computer powers off for a split second and back on to the HP screen (1) and cycles through again.
If Windows Recovery Console is selected in SAFE mode, then a blue screen with the message that windows has shut down to prevent damage UNMOUNTABLE_BOOT_VOLUME Technical information same as before.
After contacting HP Help, they informed me that the hard drive needed replacing. I hope they're wrong because of all the data and programs we have on there. I searched the internet and came up with the idea of trying to boot up with a CD rom UBCD4winV322. No difference.
This appears to be a reset problem but I'd need schematics to find out myself. Any suggestions?
  • 8 more comments
  • Rick Bilodeau Nov 19, 2008
    rickyostrom,
    Neither the ultimate boot CD nor an old copy of Windows XP appear to be recognized. No "Welcome" screen. The CD/DVD drive's light comes on, the turntable spins and the laser appears to be operating but the computer is not trying to boot from CD. It just keeps cycling as explained. I have selected the DVD/CD as the boot device from the HP screen (ESC Boot Menu) and the order of devices (F10 Setup).
    rick
    Tech Jenkins,
    I've gone into the boot menu and selected DVD/CD as the boot device. Same cycling symptom. In the Bios setup, I've changed the order of devices to make the DVD/CD first. Same. It's like it's ignoring everything but continues to try the HDD.
    Tech Jenkins,
    I suppose that the CD drive could be faulty. Anything is possible after a power outtage. But that would be different problem.
    I have attempted hooking up an external floppy drive and attempted to boot from that. It detects the presence and identifies it as USB mass storage device #01, but A: DRIVE ERROR comes up.
    Toasted BIOS? Is there anyway to confirm or eliminate?
    I've selected the boot up device in the HP screen by pressing ESC. In the BIOS setup (F10 at HP screen) I change the order of boot up devices. Can't find any option to allow USB boot up. F12 has no effect at any screen that comes up.
  • Rick Bilodeau Dec 05, 2008
    Thanks folks,
    Replacing the hard drive got me going. Now I've got to transfer some files and folders. I'm going to try hooking up the old drive and transferring to the new one. I've never done this before, any tips?
    Rick
    Seagate SATA
  • nitinbhosale Jan 29, 2009
    what should now please tell me computer is pentium iii
    I think so it has virus problem sometimes it start by clicking on start windows normally
  • Ricky Ostrom
    Ricky Ostrom May 11, 2010
    Did the UBCD4winV322 Disk do what Microsoft is saying below? ...
    1.Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
    2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
    3.If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
    4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
    5.At the command prompt, type chkdsk /r , and then press ENTER.
    6.At the command prompt, type exit , and then press ENTER to restart your computer.
    This takes a bit longer, but the system should boot back into Windows.
    Sergeant:
    Champion:
  • 274 Answers
You might check on the internet about making a boot USB Thumb Drive. This might be a work around a bad CD Drive.
Posted on Nov 19, 2008
  • Ricky Ostrom
    Ricky Ostrom Nov 19, 2008
    Did you do the F12 boot routine, where you can choose the boot device?
    Sergeant:
  • 359 Answers
I have just in fact a few days ago came across a similar issue. As to whether or not your hdd needs to be replaced is uncertain. What I can tell you is it seems as though the MBR or master boot record has become corrupt or one of the reader arms inside the hdd has failed.
Refering to the corrupted theory, may be simply fixed by booting off of a win xp cd and reformatting your drive and reinstalling windows after the format.
HOWEVER
In my case even booting off of a xp cd did not resolve the issue, every time anything would attempt to read from the hdd the computer would reboot. I suspected hdd failure at first, but this was not the case. It turns out it was a virus that infected the ntfs.sys and the MBR and put a binary code into those 2 files to reboot the machine.
Luckily at work (IT industry) I have a norton ghost server and was successfull at reimageing the hdd, doing so erases the MBR and everything else for that matter and rewrites it. However in doing so I lost all data that was on the hdd to begin with.
If you are not very tech savvy I would probably recommend hdd replacement however since you do have a HP which was prebuilt with xp, you don't have a xp install cd and thus unable to reload windows. I recommend finding a friend that has the xp install cd or you will have to go to the store and buy XP.
  • 3 more comments
  • Daniel Jenkins
    Daniel Jenkins Nov 19, 2008
    go into the bios of the computer and make sure boot other device or cd rom is in the bios. poke around in there for a few minutes.
  • Daniel Jenkins
    perhaps your cd drive is fualty??
  • Daniel Jenkins
    I'm curios if your bios is toast....
  • Daniel Jenkins
    Daniel Jenkins Dec 05, 2008
    What type is the hdd, is it sata or pata? Pata = IDE Ide is the real wide cable, sata is real skinny.
  • Daniel Jenkins
    You have 2 options.
    Most computers have more than 1 sata port on the motherboard.
    1. Keep the HDD in the computer and put the old HDD on SATA2 port. You will of course need an extra sata cable, hopefully your new sata hd came with a cable so you should have 2 cables. Unlike the older IDE drives, there is no Master/Slave jumper you have to set on SATA drives, the different sata ports on the mb already have this preset.
    Hopefully your power suply has more than 1 sata power connector.
    2. You can get a sata hdd enclosure which is basically a "house" you put a hdd in and it converts the data output to a usb cable and turns it into an external hdd that you just hook up to your computer on the outside via a usb cable.
    This enclosure is found HERE
    There are no guarantees that either option will work in your case due to hdd failure, but it is worth a shot.
After I power on HP Hewlett packard laptop what keys can I use to access startup menu
If you mean BIOS startup menu, DEL or F1
if it's windows startup menu
for XP your computer restarts but before Windows launches, press F8
For Windows 7, follow this tutorial
Need to Start Windows 7 in Safe Mode Here How
For window 8 follow this tutorrial
5 Ways to Boot into Safe Mode in Windows 8 Windows 8 1
If you means something else by startup menu, please be more specific
May 12, 2015 | HP Computers & Internet
Bios passord til hp pavilion dv 4000
i checked the HP support website and according to HP's policies on bios passwords, they offer a paid service for the password removal
A Password is Required Causing the Computer to not Startup or Boot in Windows XP HP Pavilion dv4000 CTO Notebook PC - HP Customer Care (United States - English)
**see the section of "Power On"
i read in some discussions that the service costs ~$35.
Apr 28, 2014 | Maxdata Pro 650T Notebook
System take about 10 minutes to get past the HP log page
when you start it up i would try to use disk defragmenter and disk clean up i should make it faster if those dont work its because you have to many programs that open up when your computer starts type msconfig then wait for the window to pop up then go to startup and uncheck the ones u dont want to startup when u tune ur cumputer on
Apr 21, 2012 | HP Pavilion a1514n (EX269AAR) PC Desktop
When i turn on my hp pavilion a1220 n . in about 45sec's a pop up comes up and reads EZ Dock int easy uistring config xml failed . what is it and how do i fix it please?
if you have xp computer follow this step: start/run/msconfig and hit enter. system configuration window will open then click on startup/disable all/apply/ok
restart te computer and issue will be fixed//
if you have vista computer- start/start search/type msconfig and hit enter.
if you have windows 7 computer- start/search programme and files type msconfig and hit enter.
May 12, 2011 | Computers & Internet
Need HP Pavilion startup disk
Just do a Google search for windows xp disc and you'll get results similar to this
http://www.google.co.uk/products/catalog?q=windows+xp+disc&oe=utf-8&rls=org.mozilla:en-GB:official&client=firefox-a&um=1&ie=UTF-8&cid=11969216369837725015&ei=VE5LTMLoMZn40wSCr6CFCw&sa=X&oi=product_catalog_result&ct=result&resnum=3&ved=0CDgQ8wIwAg#
Jul 24, 2010 | HP Pavilion d4100y (PX181AV) PC Desktop
I have a hp pavilion 2120tx with windows 7 and i want to dual boot windows 7 and windows xp [windows 7 first]
You can create a Dual Boot in ur machine....
C: XP
D: or E: or F: as Win7
You need to re-format your disk, back up all critical data in your disk....
once done...boot with XP disk in CD drive....
after format, create multiple partitions....C: , D: , E: etc as per your preference
install XP in C:
once done...start PC and let the machine boot from C: XP...once you get Desktop in XP
install Win7 in D: or E: as prefered....once done..
in the startup screen you will get these 2 options
1 load earlier version of Windows
2 Windows 7
to make Win7 as default, right click on My computer (Win7), Properties / Advancd System Settings / Advanced Tab / Startup and Recovery / Under System Startup - Chose the Default OS by the down arrow and the time to it must be displayed in the startup to chose the OS....by this method you can chose Win7 or Xp to load...make your choice as prefered...
reg
for more info on formating and loading OS visit my site
www.sureshayyar.110mb.com
May 08, 2010 | Computers & Internet
Sleep mode does not work properly
go to control panel power ption thern clik on hibernate
and enabvle check box of hibernation so it start from where u end
May 24, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Laptop will not boot after vrus warning.
try booting into safe mode? on a pc hit F8 repeatedly while you boot until you get a boot screen with the safe mode option. Some laptops have differant keys, eg F2, <Del>, F10, but ussualy they state this when it boots up.
when you get into safe mode, go to your run prompt and type "msconfig" hit enter. got to startup, disable all.Go to services, disable all. reboot. if this works, try running an pdated antivirus scan. I recommend using Avast! which is like AVG. It can do a start up scan. also try running something like 'trojan remover' which is free to download.
Good luck! :)
Jan 05, 2009 | HP Pavilion dv6000z Notebook
For solving blue screen error
HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
Description
Windows XP may not start and the following error message may appear on a blue screen:
This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
Solution
If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
use the link to know how to use recovery option with hp laptop
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&dlc=en&product=18703&docname=c00608578#
_____________________________________________________
Thanks and Regard
dilipbagdi
Technical Associate
May 18, 2008 | HP Pavilion dv9000z Notebook
ASUS P5PE-VM Motherboard Logo
1,300 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
