Question about LG WM-2277HW Front Load Washer
Too much vibration
From almost day one our washer has excessive vibration. We had Sears out and they couldn't do much about it. They are on the pedestals, not sure if that is causing the problem? All we ever hear is how great this washer is, but the vibration is driving us crazy. HELP!
  • 3 more comments
  • Anonymous Nov 21, 2008
    mine vibrates so bad it knocks everything off the top and hits the walls and dug a hole in the floor. It is on a pedestal also. What did Sears say?
  • jonhaggstrom May 03, 2009
    I have the same problem - the washer beats our house to death. I have had the service tech out 2 times and have had numerous discussions with the distributor. They told me after I bought it and after they delivered and set up the pair that they really are only made for rooms with concrete floors. I have watched all the adds and information and none of the commercials I have seen show the items sitting on a concrete floor. I have even gone to places that sell the washers as if I wanted to buy one and asked about vibration - they assured me there were no issues and the washers were fantastic. I would not recommend anyone buy one of these washers unless they are going to sit it on a concrete slab.
  • cwilson88 May 19, 2009
    I have the same issue. Brand-new install - on level concrete slab with all feet firm - in my basement. Machine was checked with a level - both front-back and side-side. I had a wash running and went up to the second floor to get more clothes. I heard what sounded like automatic weapons fire. Ran down to the basement and found the washer/pedestal combo turned practically sideways from the violent shaking during high-speed spin.
  • Jackiemorgan May 22, 2009
    My LG washer shakes as well. It already beat up the dryer! Its so annoying! Please help!!!!
  • lhendrix May 23, 2009
    We have the same issue. The machine will walk out of the laundry room if you don't keep an eye on it. The machine is on the second floor, leveled with a laser and is sitting on concrete backer board. I have given up and have donated it to my son's apartment which is on the ground floor. I hope he has better luck! We went back to Maytag appliances because the last set lasted 20 years while this LG fell from grace after 3 years.
I have had my LG washer since Feb 09 from day one it has been a problem it is not on a pedestal it is on concrete floor all legs are leveled and it still vibrates out of control I have tried placing it on slates, bricks, boards, etc. it still does not help it moves across the floor so rapidly that it has almost pulled the hose out of the wall this is this is exceptable and the store that I purchased from is telling me to call LG whom will not do anything about it. Please help I don't know what else to do but contact the BBB but I'm not sure if it should be on the store that I purchased or the LG company
Posted on Jun 08, 2009
    Problem Solver:
  • 16 Answers
First make sure the floor is leveled and sturdy enough to handle the machine.
Posted on Nov 23, 2008
Can the washer be adjusted for excessive vibration?
All washers have to be level if you have excessive vibration then adjust from the bottom. i usually take a level and check from the top. If that dosent work let me know. You might have a different problem Hope it helps
Jan 17, 2011 | Kenmore Front Load Washer
How do you get the top of the cabinet off of a Sears heavy duty washer series 80, model #11092283800? It vibrates excessively w/o a load.
should be 2 screws in the control panel ,some panels you need to remove the end caps to remove them,then just flip the control panel back it has plastic hinges so be careful,then you unplug the lid switch,pop off the 2 gold clips holding the back panel to the housing.then just reach inside the lid tilt slightly towards you and lift off the frame.
Aug 01, 2010 | Kenmore 23822 Top Load Washer
LG WM0642H washer "excessive" vibration
sounds like damper rods are getting worn. they support bowl underneath.i think if u change them it should fix problem. is it noisy during spin?if u need more help please reply. please turn power off b4 working on it do not want any accidents.
Apr 08, 2010 | LG WM0642H Front Load
I need to know where the balance spring to tub connects on a Kenmore washer model 110.27721600?
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.27721600
If you look at the section on "Machine Base Parts" you'll see a number of springs and vibration pads.
It's possible that one or more of the springs or pads has come loose or broken.
In order to get to them you have to remove the cabinet.
Here is a description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=90fdc122f6335c7c64f46f2ea1b1c887
Also see the Whirlpool Service Manual for top load washers. It has a troubleshooting section that describes the reasons for excessive walking or vibration.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Following is also a Whirlpool PDF that has some diagrams of where the springs fit.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Jan 15, 2010 | Kenmore Washing Machines
Tub spins and wobbles real bad what is this problem
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Jan 09, 2010 | Kenmore 23822 Top Load Washer
Excessive drum vibration
Yes, look into trading in the Kenmore for one of only two manufacturers that employ a dynamic balance system built into the washer drum. Samsung and LG both use this dynamic balance system that balances the load while it is in motion. They also use a vibration sensing system to modify the time and speed of the spin cycles to minimize any vibration that might still be present. LG has this available on only their upper level models while Samsung's VRT is available on most all models. I believe that both of these manufacturer's are available from Sears.
Oct 03, 2009 | Kenmore 43142 Front Load Washer
Excessive vibration
check for bearings fault,ie open door and lift inner chrome drum up and down if you feel a knocking feeling or you ear this then its the bearings
Jul 06, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washer has excessive vibration in spin cycle
A unstable floor will cause the problem, glad you figured it out.
Mar 27, 2009 | Admiral AW22 Top Load Washer
Excessive vibration during spin cycle
Chck to see that all (6) suspension springs are still attached. Check the plastic snubber ring below the mechanism and above the base plate for cracks or contamination.
Mar 07, 2009 | Maytag Performa PAV2200
Machine vibrates excessively during spin cycle
Open washer's cover and look for a released or a malfunction shock absorber. Good luck!
Nov 08, 2006 | Maytag MAV4755A Top Load Washer
LG WM-2277HW Front Load Washer Logo
428 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
