Question about HP Photosmart D7360 All-In-One InkJet Printer
My HP Photosmart D7360 will not print black, despite changing cartridge and performing print-head cleans WILL NOT PRINT BLACK OR WHITE FROM COMPUTER
    Master:
  • 763 Answers
Sir, try reinstalling your printer from your computer and install it again. try also the calibrating utility color from you printer cd driver and install it on your computer. this calibration will correct the color of your printer when you are printing.
thank you for using fixya
CHARCOIS
Posted on Nov 19, 2008
  • HP Master
  • 1,879 Answers
If the printer still does not print black after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s), your printer will require service.
    Genius:
  • 3,422 Answers
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and the turn it back on. You will have to turn the printer off twice and then it will recalibrate. Make sure you have new cartiges in the printer so that it can reset.
if this doesn't work the only way to clear it is to disassemble it and soak the bottom of the printhead in hot water then reassemble and clean the head
  • Priya darshan Nov 19, 2008
    I have mentioned the wrong model no. it is D7360
    Also check the setting
    file> Print> check black & white
    You also need to run a test page/nozzle check pattern to verify if the black
    ink is getting through the printhead. If you do not see any black on
    the paper, you have a clogged printhead and need to run 2-3 printhead
    cleanings, then run another test page/nozzle check to see if the
    cleanings are working. It may take several cleanings and a lot of ink
    before the printhead is clean.
    Also make sure that you have a genuine HP black cartridge.
    If you still face the same problem then you will have to get it repaired.
    Thank You.
Black ink will not show up on paper
It seems print head clogged,this issue not related with cartridge, perform clean print heads 3-4 times & chk, if no result replace the print head (CN642A).. I won't suggest for manual cleaning for this print head unit.. Thanks for listening me..
Jun 20, 2013 | HP Photosmart Premium C309A All-In-One...
We purchased a HP Photosmart C4400 series last December 2009. I have just put in a new black ink cartridge and the printer is not printing the black properly, it still very faded. I have put in the correct...
Black printer ink in HP Photosmart may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
Oct 04, 2010 | HP Photosmart C4400 series
Photosmart D7360 - message says "ink cartridge empty. To print in color, install the following cartridges: yellow. To print in black ink only, press o.k." I have replaced the cartridge (yellow) and the...
go to hp support>d 7360 >software and drivers. Download (run) latest diagnostic utility 2010-11-09. run test and print test page (only one sentence). worked for me. Took about one minute.
Sep 10, 2010 | HP Photosmart D7360 All-In-One InkJet...
Photo black ink runs out b4 black on HP Photosmart C6380 printer
The black ink cartridge is larger than the photo black cartridge and black is used in photos to make the darker colors. Black text takes much less ink per page.
Jul 17, 2010 | HP Photosmart C6380 All-In-One InkJet...
My HP Photosmart 8250 Inkjet printer is not printing black ink. If I let it sit for a while and only print 1 copy it will print a pretty good copy. Additional copies are almost blank but will have color...
try to reinstall the printer driver software. you can download the latest printer driver software from yout printer manufacturer's web site then restart the computer and printer.
Jun 11, 2010 | HP Photosmart 8250 InkJet Printer
Hp 6150 won't print clearly --new cartridges are in
Clean the print head if you suspect that the nozzles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
Hope this initial info/idea helps.
May 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP D7360 prints in magenta instead of black. Both cartridges are
Check your other colours. Anything other than a True Type Font is printed in colour shaded with black, so it sounds like you have a problem with yellow and cyan. Either the ink cartridges are out or the print heads have a blockage.
If the cartridges are not empty or v low, try sitting the print head over a folded paper kitchen towel damped with hot water for 10 minutes. Remove it and try your diagnostic again.
Dec 11, 2017 | HP Photosmart D7160 InkJet Printer
HP Photosmart D7360
try to align the print cartridge. go to settings -> tools then choose align printer. you may also try to clean the print head.
Nov 01, 2008 | HP Photosmart C3180 All-In-One InkJet...
My HP Photosmart D7360 will not print black, despite changing cartridge and performing print-head cleans My printer shows there is ink in the cartridges according to the monitor, plus the black and yellow...
Hi rfillmore, I would suggest you update your printer drivers, try this, follow instructions exactly as written:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop(watch for the light yellow bar at the top of window viewing pane, click on this and choose – download file - . Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Oct 21, 2008 | HP Photosmart D7360 All-In-One InkJet...
I have the same problem. I just re-installed all ink cartridges into my printer from the first actual cartridges given to me with the printer and the black ink doesn't work. I contacted HP and they told me that I needed to change my black ink, after I already told them that I have tried 2 new ink cartridges in the system. I went out and bought another one thinking that this would fix the problem, and it didn't. I contacted HP again and I was told that it was the printer that was broken. The actual black ink section was faulty. Since it was a year and a month since I bought the product it was not under warranty, so nothing could be done but to buy another faulty piece of merchandise from HP. I could also service it, but that was never given a price tag. If you want my opinion don't purchase anything from HP again, I know I won't.
Apr 22, 2008 | Office Equipment & Supplies
HP Photosmart D7360 All-In-One InkJet Printer Logo
109 people viewed this question
Ben Johnson
