Question about Bosch 30 in. NET7452UC Electric Cooktop
NET7452UC Electric Cooktop shows errors 26 and 42. What do they mean?
What do error codes Er 26 and Er 42 mean?
    New Friend:
  • 17 Answers
The capacitor is 470uF, 25 volt. Replace it with 470uF 35volt and remember to observe polarity. You will need a good soldering iron to be able to flow the solder thru the eyelets on the PCB.
Posted on Nov 16, 2012
  • John Hanna Jan 28, 2014
    My two 470 uF cacitors looked and measured good with a analog ohmmeter but I changed them anyway and the error code problem is now fixed;
Problem: Error codes 26 or 42 after turning on too many heating elements.
Potential issue: Damaged main electronic board
Specific case: Error code 42 after turning on more than 3 elements, then already after 2, 1 until none of the cooking element could be turned on, over a period of a few weeks.
Root cause: Dying/blown electrolytic capacitor on the main electronics board.
Solution:
1) Turn off power (circuit breaker) - caution high voltage inside the cooktop
2) Lift the cooktop out of the hole in the countertop and slide it on a flat surface
3) Remove all screws around the metal housing using a torx screwdriver
4) Carefully tilt the glass top out of the housing on the front, noting that there are electrical connections in the rear, and place the rear end of the glass on a stable surface. You may need someone's assistance here.
5) After double-checking that there is no power, record the color coding of the four wires connected to the glass assembly (green for ground, white, black, red from left to right)
6) Next open the black plastic cover by removing four Torx screws.
7) Carefully remove from the connector on the left the the plastic strip connecting to the display board.
8) Carefully remove the circuit board with relays and capacitors that is held in place by plastic tabs.
9) If one of the capacitors is bulging out or showing sings of damage on top, replacing it may fix the appliance. De-soldering a bad capacitor requires some tools and skill. Replace the capacitor with at least the same capacity, voltage and use high-temp. 105C version) Alternatively, instead of replacing a $2 component you will have to replace the entire board.
10) Reassemble and done.
Posted on Oct 07, 2012
Testimonial: "Absolutely correct solution of the problem!!!"
  • vlassovy
    vlassovy Oct 07, 2012
    I fixed it two months ago. When inspecting the circuit board I indeed found slightly "inflated" electrolytic capacitor. After replacing it the cooktop worked again like a charm. Total repair cost: $0.00 (I got the same capacitor as a gift). Thank you anyway.
SOURCE:
PIC645F17E (Bosch) electric cooktop show error code er22. What does it mean ? How to repair ? Please help me ! Thank you !
The error code you posted is not listed anywhere. There is the error code "Error" for the oven which means oven overheating. If that's true then the problem is a bad oven power relay board.
This part has been discontinued. Bosch probably replaced it with a different part but I was not able to find the correct part number. You can talk to APP CSR and they will help you to locate the correct part.
Sep 05, 2016 | Cooktops
Prestige induction cooktop showing error E4
Good Afternoon friend, I appreciate your inquiry!
Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
Oct 18, 2014 | Electrolux 36" Electric Hybrid Induction...
How do you clear er
Hi friend, thank you for your inquiry!
I understand that you are receiving an "ER" error code on your Frigidaire range and you want to clear the code. "ER" stands for error, I would recommend performing a reset which can be done by flipping the household circuit breaker for roughly ten minutes. That should clear any false error codes. If you continue to receive an "ER" or any different codes please provide that feedback. I hope this helps. -Matt
Aug 23, 2014 | Frigidaire Stove / Oven / Range Cooktop...
GE Monogram f160 error code?
When an "F" and a number appear in the display and the cooktop beeps you have a function error code.
Touch the CONTROL LOCK pad.
Disconnect power to the cooktop and then reconnect.
If an F-code appears again, call for service.
May 03, 2014 | GE Monogram ZEU30R Electric Cooktop
Bosch NET9652UC STOVE TOP shows Er 42
Er42 constantly slashing on my stove top, sometimes lasted for hours. When that happened you can't use the stove top until it stops. What should I do to stop the slashing?
Feb 20, 2013 | Bosch 30 in. NET7452UC Electric Cooktop
Error code
Same thing happened to me. Reset your stove top by flipping your fuse off. The stove top will reset and the error code will go away.
Jan 21, 2008 | GE 30 in.JP950 Electric Cooktop
Bosch 30 in. NET7452UC Electric Cooktop Logo
3,037 people viewed this question
Top Bosch Cooktops Experts
Paul Carew
Jay Finke
Jay Finke
ray gallant
ray gallant
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
