Printer cuts ribbon
The till printer cuts the printing ribbon, the type of printer is olliveti pr 45 till printer
  • 57 Answers
Hi all of you
this problem occures from bad head, replace it.
hope this helpful for you,
thanks
Hamedo
Posted on Nov 19, 2008
Evolis Pebble 3 cannot set ribbon type to other than black k - Expert assistance required
Make sure the primary ribbon setting in the driver is on the appropriate setting (graphics tab when accessing via Windows' "Printing preferences". Also, when checking/changing this setting via Windows, be sure your logon ID has Windows Admin rights - standard users are blocked from making driver adjustments.
The only other things I can think of, and that we've seen, is that the main logic board on these printers can begin to exhibit erratic behavior with age. The Pebble3 is a VERY old printer, and is fully out of support now by the manufacturer. If it's a failing/failed logic board, it may be time to consider a replacement.
May 22, 2017 | Evolis Pebble Office Equipment & Supplies
I got a color print ribbon and it won't install
Please post the configuration for the printer which is on the left side under the cover (white sticker) and your ribbon part number. If you are sure both are correct you may have a defective print ribbon or your printer will need service.
Feb 24, 2014 | Datacard SP35 Plus Printer
Olliveti dcopia 2200 printing blank after i put new toner
Put the old cartridge in if it prints ok you have a bad cartridge
John
Nov 06, 2013 | Office Equipment & Supplies
Ribbon leaves marks
i need the solutuion of this problem
( out of print ribbon. (pr-01726) Replace the K print ribbon, replace the cleaning sleeve, and click OK when ready
Aug 14, 2013 | Datacard SP35 Printer
Datacard CP40 Plus printer with an error. Put a new ribbon in it and it does give us a error message: Error: PR-01739 Ribbon Error Please Help!
Sounds like you are using an incompatible ribbon. Please post the configuration for the printer which is on the left side under the cover (white sticker) and your ribbon part number. If you are sure both are correct you may have a defective print ribbon or your printer will need service.
Contact TulsaBiz.net for more info
Jul 22, 2011 | Datacard SP55 Plus Printer
Good afternoon, I am having problems getting my printer to print a complete card without telling me that the ribbon is broken. The error code I am receiving is PR-01724 The Printer I am using is the...
PR-01724 Ribbon Break
The print ribbon is broken.
Possible Cause 1: The print ribbon has broken or is not installed.
Solution 1: Trim the broken ribbon evenly and tape the cut end of the ribbon to the ribbon on the take-up spool. Install the ribbon cartridge.
NOTE: Do not switch take-up spools when fixing.
Possible Cause 2: If the ribbon type is K or KT, the print ribbon is at the end of the roll.
Solution 2: Load a new roll of monochrome print ribbon.
Technical issues:
•If you have recently changed edge-to-edge settings using the SmartDriver, printing might be too close to the edge of the card. Change edge to edge settings.
•You might have moved the print ribbon while the printer power was off. The next card will print correctly. The printer is designed to allow you to fix problems while the printer power is on.
•If the print ribbon is stuck to the card, the Intensity setting might be so high that printing causes the ribbon to stick to the card. Lower the Intensity or power setting.
•The card design might be longer than the card size. Change the card design to be less than or equal to the card size in the long direction (3.37 inches or 85.60 mm).
•Printing might not be positioned properly on the card. Change the "Left/Right" position of printing (using the SmartDriver) so the printing begins and ends on the card.
Jun 20, 2011 | Datacard SP55 Plus Printer
The SP35 red light is on
please give me the solution as fast as possible.
( out of print ribbon.(pr-01726) replace the K print ribbon, replace the cleaning sleeve, and click ok when ready
Mar 17, 2010 | Datacard SP35 Printer
Datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Nov 23, 2009 | Datacard Group SP55 Card Printer
Datacard SP35 + giving broken ribbon error
You have to clean the roller under the printerhead.
The big black one..
I suggest you install Diagnostics.
Go to motor test, and take the transport fast reverse. 300 sec.
Now you can clean the roller easy.
Nov 25, 2008 | Datacard SP35 Printer
Evolis pebble 3 ribbon problem
Hi, did you change the ribbon type at the printer properties? You must choose the black ribbon or monochrome in old drivers.
Jul 04, 2008 | Evolis Pebble 3 ID Card Printer Package...
78 people viewed this question
jasbo
jasbo
