Question about Kyocera Mita KM-3035 All-In-One Laser Printer
Stapling from the print mode
I know you can sort and staple from the copier, but can you send a job to the printer from your PC and have it sorted and stapled? Or is this possible? Our company has the KM-3035 printer/copier/scanner/fax.
    Genius:
  • 2,120 Answers
Yes, look in the printer properties in control panel to set this option before you print.
Posted on Jan 02, 2009
Why is my staple gun shooting 2 staples at a time instead of 1? How do I fix that?
Morning Sherri,
Usually, if a tool is sending two staples out at a time, the wrong staple series is being used. Please check if the pack of staples you're using is suitable for the machine. If they are compatable, then make sure that the magazine (Where the staples go in) closes properly.
My usual analogy is: Tyres may look the same and do the same job but, you try and put a bus tyre on a bicycle - just can't do it.....
If this doesn't sort the issue out come back to me.
Regards
Alex
Leigh Co Limited
Apr 03, 2015 | Staples Tools & Hardware - Others
Bizhub not collating when stapling
did you select collate in the print driver, try reloading the driver check the web site
Self Help Product Support Konica Minolta Business Solutions Inc
Apr 01, 2014 | Konica Minolta Bizhub 222 Black and White...
How can i print multiple copies of the same document with 3 pages and have the printer staple the copies in the correct groups?
In the print driver you should have the option to collate, you need to make sure that that option is on, and when you go to send the print job, you need to make sure that you adjust the finishing options in the driver to tell it to staple.
May 11, 2011 | HP LaserJet 4250 Printer
Why do multiple copies sometimes staple together as one set instead of multiple sets?
I don't know how/why, but if you set the Print settings (main print screen) to non-collate and the Printer Properties (clicking in to get to the staple option) to collate, it works correctly, stapling each set individually.
Oct 28, 2010 | Konica Minolta bizhub C450P Laser Printer
Need help with using the staple feature on my cannon imagerunner 2870. The staple button is not highlighted to be used, but the copier is full of Staples
Do you have on display message like: " limited mode" or similar?
If yes there is some problem with staple finisher. In most case with up and down movement sensor, or copies dont come out sorted, instead goes everywheare on delivery deck...If Im not mistakaen error is E 542 or 724.
You can try under user mode - copy sett.- there must be an option to turn off limited mode. Then restart machine, if something is wrong you will get error code message.
Jun 24, 2010 | Canon Office Equipment & Supplies
Biz c 650 photocopier does not sort and staples all the sets together when print frm pc
When printing multiple stapled sets from Microsoft® Word all the sets are stapled together.
Solution:
CAUSE: The Collate option in the Microsoft® Word dialog box is selected.
SOLUTION: When printing and stapling multiple sets, the Collate option in the Microsoft® Word dialog box must be deselected. Please
Feb 23, 2010 | Konica Minolta Office Equipment & Supplies
I have a Ricoh Aficio and I cannot find how to use the stapling feature.
Are you sure it has stapling?
Some machine may show it on the control panel but it is an option that may or may not be installed.
Is there a stapler in the sorter?
If it does, then the stapling should come up as a finishing option when making copies.
On your control panel, there will be a Sort, Group and a Sort/Staple option.
Select this feature and it should staple your copies.
If you select this and it doesn't staple then it may be out of staples or the copy is not the correct size or orientation to allow stapling.
Apr 15, 2009 | Ricoh Office Equipment & Supplies
KONICA MINOLTA C450 VXL Printer - When stapling multiple copies it staples all the copies together rather than each one separately as required. I use vista operating system.
There is an issue with the Konica Print Driver and the MS Print Driver. If Collate is turned on in both the drivers, you will get this problem.
The solution is to turn off Collate on one of the Drivers. Usually you will have an initial Print Dialog window that pops up when you can select your printer, how many copies and if to collate or not. De-select Collate. Then you should also see Preferences Tab. If you select that tab, select Collate and Staple, your print jobs should now Collate and Staple correctly.
Jul 23, 2008 | Office Equipment & Supplies
Printing doesn't come through on the paper
dear lclaw
it is very nice for the two information.
try using another cartridge form staples because as u said your cartridge might be dried out.
Plz post your findings
Apr 09, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
Need to know were to reload the staples
you check the staple unit and staple pin and staple contro pwb
May 07, 2007 | Sharp SF 2020 Copier
Kyocera Mita KM-3035 All-In-One Laser Printer Logo
174 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
