How to change auger parts in ducocolor 2045 , jacob 3104783055 I have to open it to change developer
  • 62 Answers
What auger parts are you changing?
Posted on Nov 19, 2008
Richo aficio 2045 out of focuse problum
could be developer powder is bad i would start there
Aug 13, 2014 | Ricoh Aficio 2045e 2035e Copier...
Xerox 2060 developer changing
error 010-314 and 010-315 for my xerox docucolor 2060-2045
Feb 25, 2013 | Xerox DocuColor 2045 2060 5252 6060 Cyan...
Jacob jensen 842 battery
Mine is a 750, but essentially, when you search long enough (pref with a magnifying glass) you can find a tiny little slit. If you carefully wedge a pen knife or similar underneath, you can get it open. Quite a tight fit though!
Jan 19, 2013 | Jacob Jensen Watches Jacob Jensen - Watch...
I have an sc 326 error code in my ricoh aficio 2045 copier
kindly change the developer unit and clear the error.
the machine will respond
thank you and all the best
May 20, 2012 | Ricoh Aficio 2045e 2035e Copier...
How can i make td sensor initial setting for my ricoh aficio 2045
I want to help you but read this with careful. If you have any dought reply to me befour you make anything.
My question is: did you change the Developer?
If so you just need to execute the SP 2-801.
If you did not change the developer do not execute this SP because you will give incorrect data to the TD sensor.
So, the important question is why do you want to do it?
Jun 21, 2011 | Ricoh Aficio 1035 Copier
Error code sc 390 code richo aficio 2045
That error is related to a bed reading in a sensor of the Development Unit, called "TD sensor".
You can try to take out the development unit and see if there is dust of toner or even if the plug is broken.
The development unit is placed under the PCU.
Open the front door and you will see it.
If you can not see anything abnormal like dust or broken plug i advise you to call your provider to change the TD sensor or the development unit.
Jun 02, 2011 | Computers & Internet
Af 2045-SC390
You can try to take of the development unit and see if there is dust of toner or even if the plug is broken (i saw that happens sametimes).
Open the front door and you will se it.
If you can not see nothing abnormal like dust or broken plug i advise you to call your provider to change the TD sensor or the development unit.
any doubt reply to me ok?
Mar 05, 2011 | Ricoh Aficio 2035 Copier
Im using ricoh 2045..Paper jam occurs at point A1 (the lever the drops to remove the paper) . I have noticed roller A1 and registration roller doesn't rotate. When i remove the paper and close the covers...
this is not a thought I am 100% sure and give you the correct solution:
problem with the paper feeding section is dusty or due to developer drooping
1. Open the developer unit and check the rear side developer unit bush one or two bush are faulty
and drop the developer.
2. remove all paper trays with remove the four each screws
3. Remove the toner collection bottle
4. Remove the right side cover.
5. Remove paper left roller plate.(show in the picture)
6. Now remove the first tray paper feeding section(is a complete unit included paper feed rollers motor and clutch and gear section)
7. Clean the drooped developer from all gears and roller and motor section
8. remove the second and third tray paper feeding section and doing the same.
9. now fix it all
10. replace developer unit bush witch are faulty or if you don't have yet cut a plastic sheet and past the upper side of first paper feeding unit gears witch are don't disturb the paper path and stop the developer drooping on the gear good_help.pnggood_help_0.png
Jan 27, 2011 | Ricoh Aficio 450 Copier
Add toner ricoh aficio 2045
Toner supply is controlled with readings from TD sensor on the developing unit and the I.D sensor above the drum by default.
These are low cost parts and easy to change.
(The TD sensor on this model have been known to fluctuate back and forth by a fair margin so is a good place to start).
You could also try stripping down and cleaning out the toner hopper.
Check the four mylars are present and the grabber is opening wide enough to grab the toner bottle nozzle successfully.
Check the toner hopper exit slider is opening fully when the PCU is inserted.
I had one of these 'add toner' faults today and it was the toner hopper all clogged up inside.
The side bit where the toner drops down had hardened clumps of toner stuck around the side entrance mylar and the exit hole.
Check also the toner motor. I have seen these fail. Run simulation output check for toner motor. I would remove the toner supply unit and hold the motor when you run this simulation. Sometimes the motor turns but does not have enough torgue to turn the toner supply unit.
Mar 05, 2010 | Ricoh Aficio 2035 Copier
RIcoh MP-4500
It's probably happening because the cleaning blade on the drum needs to be changed or replaced.
Oct 25, 2008 | Office Equipment & Supplies
75 people viewed this question
jasbo
jasbo
