Question about Medion (40010998)
Laptop crashes shortly after boot, power light rapidly blinks red.
I'm having trouble booting my laptop. It's a Medion Akoya EX. I'm sure that the problem is my battery. Is this repairable or do I need to buy a new one? All my symptoms are below. If I pull my battery, all symptoms below disappear. I can sucessfully boot and use my system. The left light below the screen on my laptop describes whether the laptop is running from the battery. (Green = laptop is running on battery, off = laptop is not running on battery) The middle light below my screen describes the battery state. (Green = fully charged, off = running on battery power, amber = charging, slowly blinking red = 10% battery power or less remains.) The right light below my screen describes whether the laptop is running on AC power. (Green = laptop is on and plugged in. Off = laptop is either on and powered by battery, or laptop is off.) If the power is off, and the power cord is unplugged, the middle light is off. This is normal. However, if I plug in the adapter, but keep the laptop power off, the middle light starts rapidly blinking red, two times per second. This is far faster than the "Low battery" blink that I've seen before. If I unplug the adapter, then turn on the laptop, the left light turns green as normal. The laptop starts to boot. After 20 seconds, the laptop shuts down. The leftmost LED turns off, the screen turns off, the fan turns off. After this, the middle LED blinks red 12 times rapidly. If I plug the adapter back in, then turn on the laptop, the middle light and the right light both light to solid green. This would generally mean that my laptop is on, powered by AC, and fully charged. However, I experience the same shutdown as above. The laptop stays on for 20 seconds. I can go to my BIOS or start booting from either my linux or windows partition. I don't experience any problems or error messages. Everything works normally, for 20 seconds.
  • 624 Answers
Its late, so just to make sure I'm not brain-dead basically your laptop runs fine as long as its powered by the AC adaptor but dies fairly quickly while running via battery. This is very typical of a battery that will no longer hold a charge, not normally a user repairable item. It could also be that the charging electronics (in the laptop) isn't charging the battery, again not a typical user repair job. About your only option short of taking it to the repair shop is buying or borrowing a battery as a test.
Posted on Dec 13, 2006
What is boot media
Boot Media is a Hard drive or a flash drive (memory stick) or a Cd rom drive.It only askes this when there is no Hardrive or .......... pluged in to the device
Dec 30, 2013 | Medion Akoya Ex Notebook Computer
Hi, I m havin Medion Akoya md 97860 laptop It shows blank screen and ni response, only led lights turns on and while starts feel like accessing ram and fan run but system can't be able to start.
Does the HDD LED blink? when you reboot do you get anything on the screen at boot? Can you do a system restore/recovery? Reseat the Memory Mods and the HDD. Maybe the HDD is gone or the Memory? The MBR is corrupt? Hard to say without troubleshooting issues.
Jan 02, 2013 | Computers & Internet
My medion desktop model pc mt 14 wont switch on from the mains
Whenyou plug in the power cord is there any lights whatsoever on the laptop, wherethe plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Pressand Hold the power button for 30 seconds. After 30 seconds plug the powercord back in and hit the power button to see if it boots.
Maybeyour memory is bad or the memory slot is bad.Removethe Power Cord, Open the Case and remove one of the memory chips. Set thechip aside then try rebooting the computer. If it boots, then you knowthe memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and tryrebooting. If it fails take the chip out and set it aside, then put theother chip in and try booting it in both slots. If it boots, just toverify that the chip set aside is bad, mark an x on it and put it into the openmemory chip slot and try booting.
Maybeyour power supply is bad. Sometimes there is enough power to make thepower light come on but not enough power to make the fan turn on or harddrive spin.
May 27, 2012 | Medion Computers & Internet
Medion akoya e1210 notebook. failure to boot pxe
Failure to boot PXE 061 is a BIOS message that indicates 2 things:
  1. System failed to boot to the hard drive
  2. System failed to boot to a network connection
The apparent problem is failure to boot to the hard disk. If the system was running yesterday and there have been no hardware changes to the system, then most likely failures are:
  1. HDD failure (Replace the HDD, reinstall OS and applications) I hope you have information backed up.
  2. HDD not being detected by the motherboard due to connection issue (Remove HDD and reseat it, then see if seen in BIOS) If no change replace hard drive, if new drive not seen, replace motherboard
Jan 11, 2010 | Computers & Internet
I have a HP laptop and it's trying to boot using the 'Attempting to Boot Network' status. I went into the BIOS and my HD is set first. Reboot, same status message. I went into the BIOS again, disabled the...
Sounds like the laptop is not detecting the hard drive. Remove the hard drive ad plug it back in again. It usually solves that problem UNLESS the hard drive has crashed and cannot be picked up again.
Jul 06, 2009 | Computers & Internet
My Medion Akoya will not boot
reinstall the operating system
May 02, 2009 | Computers & Internet
Compaq C502US Laptop Won't Boot LEDs flash
turn it off, pull the battery from the bottom, and try it again... chances are, the power adapter is not rated properly for the notebook, or the battery is dead and won't hold a charge anymore, in which case, recycle the battery.
Sep 23, 2008 | Computers & Internet
Medion Akoya Multimedia notebook - wireless capability
I believe on the medion you have there may be a switch on the front or side to turn on the wireless. That or FN key and F1.
Mar 19, 2008 | Computers & Internet
Medion Akoya EX Laptop computer
It sounds to me like some of the cells in the battery has collapsed.
A 12 volt light doesn't use as much juice on the battery as when you boot up. When Mobo, Monitor, Harddrive etc etc. start up they all use a large start-up-current and if the battery cant sustain the amount of amp. they all need together, nothing happens.
This is called shadow-charge, the battery seems fine, but when it really needs to put out some power it collapses.
I think you should try to sniff up another battery and see if this one has the same problem.
Or perhaps investigate wether or not you still have some warranty left on the battery, to try to get a free replacement.
Oct 11, 2007 | Medion (40010998)
Computers & Internet Logo
858 people viewed this question
Top Medion Computers & Internet Experts
Hollyecho Montgomery
Robert Karst
Robert Karst
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
