Question about Toshiba Office Equipment & Supplies
TOSHIBA e-Studio-281C photocopier/fax machine Error code CF40 keeps appearing. Service people have been out several times. They clean the machine and it works for a few weeks, then the same error code shows up again.
SOURCE: Error Code for Fax Canon L220
You need to service machine and may be your fixing unit is problem
> If that replace Fixing Unit
Posted on Aug 15, 2008
  • 31 Answers
SOURCE: Toshiba e-Studio 350 FAX Communication error
Are you still receiving faxes although you are unable to send? Or is it no send & no receive? When you hook a phone up are you able to connect with a # dialed from that phone. It's possible that the problem is the copiers NCU board- but it's rare that they fail & even more rare that it loses just the send portion. You'll want to be absolutly sure that it's not the phone line. If you are positive that the problem is not the phone line - try turning the machine off & unplugging the power cord for 30 minutes. Occasionally the NCU card will lock up & not function properly. Unplugging the machine for 30 minutes has worked for me in the past.
Posted on Mar 29, 2007
jaylex
  • 417 Answers
SOURCE: Ricoh Aficio fax 5000L (error code & Factory Settings?)
HI there below is the reason for your error message and it is to do with the laser unit and will normally need to be replaced when this message comes up.
Hexagonal mirror motor startup error 3-31
You could try resetting it by the following
· Try to clear the service call condition (for failures which are not related to the
fusing unit): switch the power off, wait 10 seconds, then switch back on.
I take it you have already tried this but if this doesn't work then the unit will need replacing
Thanks J
Posted on Jan 06, 2008
  • 20 Answers
SOURCE: toshiba e-studio error code
It is abnormal temperature in the fuser*, thermistor error.
Maybe replacing fuser would help. But better contact service person.
*fuser, the part of a laser printer that melts the toner onto the medium. It consists of a hot roller and a back-up roller.
Posted on Feb 13, 2008
  • 990 Answers
SOURCE: How to Solve Error code SC496 for Aficio 551
hello Sir; You have to empty the waste toner bottle it located right hand side bottom, open the doorlook at "A" area you will see a big narrow plastic bottle pull out a black buckle slide out the bottle, dump the toner,the code will be disappear!
Posted on Jan 06, 2009
What can i do for toshiba 281c is giving me error code c010?
I don't think that's a valid code. Perhaps CD010? In which case there's a problem with the cleaning brushes.
Apr 06, 2015 | Toshiba E-studio 281c Copier
Check the color toner cartridge error message appears. I have changed all the color cartridges. Still same problem. Toshiba e- studio 281c
If changed new toner still showing replace toner cartridge, then probably the toner not able to go inside developer or the developer material is worn out.
Mar 12, 2015 | Toshiba E-studio 281c Copier
What is error c440 of toshiba photocopier
Toshiba e-studio Error code c440 is just problem with Fuser Unit after warm up time . 200L/ 202L/ 230/ 232/ 280/ 282/ 283/ 233
PROBLEM:
Fuser unit problem,
SOLUTION:
Try to reset it:
1. Hold down "0" and "8" keys while turn on the power.
2. Enter 400 press Start.
3. Enter 0 press Set or Enter.
Hope this helps
you can find more info at this link
Apr 28, 2014 | Toshiba E-studio 352 Digital...
Driver download
Go to
Toshiba Photocopiers printers and fax
and select which Windows or other Operating System you are using, and download.
Feb 02, 2014 | Toshiba E-studio 281c Copier
Toshiba 281 c fax
How do time for periodi mantenance?
Nov 12, 2011 | Toshiba E-studio 281c Copier
Toshiba colour photocopier jamming when copying or printing in colour. error code cee0. O k in black
"CEEO" indicates Transfer belt position detection abnormality.
U need to service the transfer belt unit, especially the reflection tape and sensors.
Apr 01, 2011 | Toshiba E-studio 281c Copier
Toshiba e-studio 45call for service 254292
Press "clear/stop" and "8". While holding this combination of keys down, an error code will be displayed....what code are you getting?
Sep 15, 2009 | Toshiba e-Studio 45 Black and White Copier
Toner was changed, m/c powered,and instead to ready it was showing ERROR 021
Function 7 press monitor slowly 4 times * 6 scroll down to SHIPMENT SET set 2 wait for the fax machine to reboot
Jun 03, 2009 | Toshiba e-STUDIO 50F Plain Paper Laser Fax
678 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
