Question about Equator EZ 3612 CEE Front Load Washer/Dryer
Dryer isn't working
After 2 years of use the dryer in the EZ 3612CEE is not working any longer. Thanks, Anatoly
  • dovermarc Apr 24, 2008
    I think I'm possibly having the same problem. Washer works by dryer doesn't. Is there a way to troubleshoot this to narrow down the thermostat as the cause ? What could some of the other possible causes be, and how would I know ?
    Cheers.
You have a burnt out thermostat. Order one from Equatoronline.com (or whatever it's called, and order the thermostat element for it. It worked for me the first time.
Posted on Aug 23, 2007
Where is the thermostat located so I can replace it?
Posted on Jan 18, 2008
Life span of a dryer
the first thing you should do is clean out any lint in the exhaust side of the venting area. it could be overheating from that and shutting the heat off too soon.. on an electric dryer the heater part either works or it doesnt. element should be fine in this case i suspect..
Apr 01, 2017 | Maytag Dryers
Whirlpool gas dryer takes longer to dry though it heats up and turns, yet it has a humming/buzzing noise. What could be the problem?
Had the same problem. There was a bit of a kink in the vent duct which caused lint to build up in duct and also inside the dryer itself over years. I replaced the duct and took dryer apart and cleaned out the air passages.It works great now. As for the humming, mine started about 2 1/2 years ago and I still don't know why.
Jun 04, 2012 | Whirlpool Dryers
Lint all over clothes
when was the last time you cleaned out the dryer and the vent line?next time send the brand name and model number off of the machine,just cleaning off the lint filter isn't good enough,you should have the dryer taken apart,clean the duct that the filter slides into,vac out the cabinet where the motor is and if the vent line is a long run from the back of the dryer to the outside you can remove the vent line from the back of the dryer and blow it out with a leaf blower,as long as there isn't a cage or anything on the outside hood stick the leaf blower in the vent line and blow the lint outside,also while you have the vent line off the back start the dryer and make sure you feel air blowing out the back of the dryer,if it doesn't you could have a problem with the blower wheel the dryer should be cleaned out at least once a year if it's gas and once every 1 1/2 to 2 years if it's electric.hope this helps and good luck with your dryer.
Jan 05, 2012 | Dryers
Have a Kenmore elite electric dryer model 11062952100 that heats but stops midcycle on both timed and auto. It does start right back up. Does seem to take a little longer to dry clothes. Have checked the...
Check behind the dryer to make sure the tube running to the exit vent isn't clogged or blocked. Then go out side where the vent runs to and make sure it isn't clogged.
Aug 29, 2011 | Kenmore Elite Oasis 6808 Electric Dryer
Ez 3710cee
Mine seems to take almost an hour to wash, I don't use the dryer part too often. I posted a question regarding which additives to pour into where in the drawer, (used unit) could you possibly let me know what goes into 1 - 2 a, b etc. thanks russgeo@juno.com
Oct 10, 2008 | Equator EZ 3710 CEE / W Ventless...
EQUATOR 3612CEE WASHER DRYER/NOT DRYING
First of all you may want to reset the unit, let me know if you need the procedure and after reseting if the unit the washer knob may go round and round all by itself, if this happens the door mode light will flicker in a particular sequence which once once counted we can understand exactly which part in the machine has malfunctioned which once replaced the unit should start to work properly.
Jun 08, 2008 | Equator EZ 3612 CEE Front Load...
DRYER NOT DRYING
First of all you may want to reset the unit, let me know if you need the procedure and after reseting the unit the washer knob may go round and round all by itself, if this happens the door mode light will flicker in a particular sequence which once once counted we can understand exactly which part in the machine has malfunctioned which once replaced the unit should start to work properly.
Apr 22, 2008 | Equator EZ 3612 CEE Front Load...
Dryer doesnt work in my combo washer /dryer
this will be the heater at the top of the drum open cuircuit. or the thermostat o/c. or if you can no longer hear the cuirculation fan spining , then this is your problem. appliance doctor
Jan 29, 2007 | Equator EZ 1500 Front Load Washer / Dryer
Equator EZ 3612 CEE Front Load Washer/Dryer Logo
150 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Dan Webster
Dan Webster
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
