Question about Sharp AR-M450N Copier
Print Black Page
When making copies from the top scanner on the Sharp AR-M450 the copies come out black. It's as if the copies are printing on black paper.
What do i do?
  • Anonymous Mar 17, 2014
    won't copy paper comes out all black
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
Is the scanning lamp coming on ? No, replace lamp
is there a print in the background? Yes, check Seperation unit ( inside under the drum, usually three thin wires)
Posted on Nov 19, 2008
Service manual manuals
http://www.smpcshop.com/Sharp-AR-M280N-Sharp-AR-M280U-Sharp-AR-M350-Sharp-AR-M450-U-N-Service-Manual.html
Nov 23, 2013 | Sharp AR-M450N Black & White Copier
1 black line at the end of paper
if u take copy from adf scanner then clean the scanner glass. if the line is coming on print & copy both then check drum is there any line
Dec 19, 2012 | Sharp AR-5316 Advanced Digital Imager...
My Sharp AR-M160 will print but not copy. No problem buttons are lit up but just dont work.
have you got the machine on print mode
if you find the button that says print copy fax on it press it until the light is on copy...
hope this helps
Jun 18, 2010 | Sharp AR-M160 Black and White Copier
Sharp Photocopier 2114 makes all black copies
OPEN top cover make a copy see if copy exposure lamp turns on or not
May 25, 2010 | Sharp AR-5320 Black and White Copier
Black lines running down the prints
it seems that your print head is the problem you can try to clean it first..
but if you already try to do this no other choice is to have a service center o change it for you.
thanks,
Mar 20, 2009 | Sharp AR-M450N Copier
When copy a document, it will scan but the print out page is blank. I tried replacing the toner but got the same problem. The unit is still 3 months old so i think the drum is still ok.
I know it sounds simple, but do you notice the scanner light on? Open the cover and try a "sky shot." The copier should print out a black page. You'll also see whether or not the light is on and the scanner is moving.
Mar 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
Copies and prints in color are black procesed, but in black are ok
Using CMY Color produces a Processed Black.
Using only K will produce a Black.
In the print driver on a PC change your default setting to Black, from the machine you can set it to use only black as well.
That Patch is on the transfer belt. which it will alwyas do, that is what color machines do.
Install the print driver twice and set one driver s Color Mode to color and one to greyscale. This setting can be accessed by right clicking on the print driver and selecting Printing Preferences, click on the Color tab and set the Color Mode appropriately.
Oct 23, 2008 | Sharp AR-BC260 Color Copier
Sharp AR-5320 B & W Copier giving L 4 error msg alternatly
L4 is main motor drive overload. It could be a power problem going on with the copier. Are these copiers plugged into surge protectors?
If you can have a Sharp technician look at it, it would be a good idea to determine if the motor, power supply, or main board is the culprit.
Sep 21, 2008 | Sharp AR-5320 Black and White Copier
My Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
NO PROBLAME JUST A QUESTION
That all depends on the amount of toner coverage on the copies you make? The companies gauge the number of copies per toner on only 6% coverage on each page. About one small paragraph, any more the less the yield. On average about 2k -2.5k per toner give or take.
Apr 29, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-M450N Copier Logo
178 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
