Question about Dell E197FP LCD Monitor
Dell LCD monitor quickly goes sleep, on, off over and over
Last week I after my computer was "asleep" for awhile I went to "wake" it up. My computer woke up fine but the monitor went off, sleep, on (the power button shows no color (off), orange, then green, then off again) over and over very quickly and didn't stop. I unplugged the monitor for a little while and tried again. Same thing. I left it unplugged over night and it worked the next day.
A week later this happened again. Only this time after leaving it unplugged for the night it still is doing this when I plug it in.
    Problem Solver:
  • 9 Answers
I would recommend that you try it on another computer to see if you are able to reproduce the results. If that is the case you should look at any new drivers, software or updates that have been installed. If the issue continues with another PC, it sounds as though the monitor's power supply is possibly failing. in that case I would suggest you simply replace the whole monitor. Unless you are not shy with a soldering iron. ;) good luck!
Posted on Jul 08, 2009
I just added a LCD monitor to my eMachines ET1331G desktop computer. Everything worked fine until I left it on for a day. The computer went into sleep mode and now I can't get it to wake up. I've trie
You should be able to just press the main system unit power button to wake up your 'sleeping' computer which will then resume your Windows desktop and bring you back to the Login panel if you have a password set for your account.
Dec 29, 2011 | eMachines D Computers & Internet
Moved my computer and now my monitor won't wake up. unplugging the cord to the computer comes up with a no connection signal but the blue light stops flashing. Plugging the cord to the computer back in...
Be sure computer is actually starting. Power off then on computer you should see the boot sequence and then windows screen on monitor. If you do not see startup sequence monitor is not sleeping either the monitor has failed or the video card has failed. Try another monitor first.
Oct 16, 2017 | Samsung SyncMaster 940N 19 inch LCD...
F2105 hp monitor went to sleep and cannot wake.
i cannot help you its either your moniter or the vga port at the back of you tower there the only things i can figue out
Jun 01, 2010 | HP f2105 21" LCD Monitor
Monitor goes to sleep after not being in use and then won't wake
Check the "power options" settingsin your control panel.
Nov 16, 2009 | HP W2007 LCD Monitor
Dell monitor - when I put it in sleep mode (press the on/off button)it doesn't want to 'wake up' again when I return. I press the on/off button and briefly see the screen, then it goes black again. What's...
Computer is asleep or the controller board inside is failing to pick up the signal from the computer or you got a loose connection ether or here you need to check the computer and rule out the possiabilites.. From there if that does not wrok the monitor is going to need to be fixed.
Sep 17, 2009 | Dell Dimension 3000 PC Desktop
Hii iam pankaj i have dell SE178WFP LCD monitor. My problem is whenever i start my pc monitor shows that it is on power save and monitor starts blinking.. what can be the problem and how it can be...
Try holding down the fn and f8 keys or if your problem is you cannot wake from power saving mode (after your PC goes to sleep, then its probably just the driver for your video card). VISTA has some issues with certain drivers that the PC cannot wake from sleep
Jul 30, 2009 | Dell E176FP 17" LCD Monitor
Monitor displays slowly after the computer starts.
try to turn off you screen saver just turn off power monitor to see monitor easy wake up after long time.if ok means windows screen saver have problem if still same look like is you monitor something wrong need to check
Jan 03, 2009 | Dell Dimension 2400 PC Desktop
Works when it wants to then turns whie with grey line in it
Hi
If only the monitor is going to sleep, then it could be a problem with the connection from the monitor to the computer or with the cable.
If the computer goes to sleep and if you are not able to wake it from sleep then check the sleep mode settings and also the power management settings for the keyboard and mouse.
You may also do a system restore if you are not able to wake the computer from sleep.
Feb 24, 2008 | Sony SDM-HS73P 17" LCD Monitor
Dell E197FP LCD Monitor Logo
205 people viewed this question
Alun Cox
