Question about Xerox DocuColor 12 Printer
Problem loading 2 birds after factory refresh-- lost some chanels
Picture freezing on a regular basis
  • ricardoaquas Nov 19, 2008
    Viewsat ultra 2000 is not loading all satellite channels echostar 7 & 10/11 Factory refresh seems ok The downloading is not correctly being stored. I have lost several channels that do not respond to the scan. Bin # may not be correct in my USB.
    Sergeant:
    Champion:
  • 435 Answers
Hi, Do you mean the picture is freezing on TV or are you trying to print the picture?
I am little confused, since you have posted this question in Xerox and Printer section.
Could you please be explicit about your problem.
Thanks,
Posted on Nov 19, 2008
    Sergeant:
    Champion:
  • 200 Answers
Hi
Give me the model no and company so that we can help u clearly...
Try to reinstall the software and then try....
Download the driver software from the company website itself...
Thank you
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
try to locate the reset setting
reset to its original function
try to read the manual
    President:
  • 2,267 Answers
Could you please elaborate more on your problem, so we can assist you better.
Are you taking about 2 satellites and a STB is freezing after after factory refresh?
  • Xerox Master
  • 19,396 Answers
Reinstall printer software on computer.
Also give more details on the problem
  • Ginko
    Ginko Nov 19, 2008
    Check the sat cable, you posted in the printer sections.
    Si necesita se habla espanol.
Trying to print a picture from the web on XP-810 epson on regular 8x11paper, printer tells me load paper on cassette 1 but cassette 1 only takes picture size not 8 x11. Cassette 2 is where the 8 x11 i
I Just right click on picture select save as. I now have a copy in my pictures. right click on picture select print, on the drop down window select paper size A 4 is 8X11 if it asks print to paper size click ok.
Oct 02, 2014 | Office Equipment & Supplies
How do i download he program if i lost my cd? my hard drive was refreshed and they erased my epson program.
here the drivers for epson
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp?BV_UseBVCookie=yes&oid=-10222&infoType=Overview
May 07, 2009 | Office Equipment & Supplies
The 3eBK head stopped printing.
Try below some steps which might help you resolve the problem.
Print Head Cleaning / Head Refreshing If the printed Nozzle Check Pattern is broken, missing, or a specific color is not printed, clean the print head.
  1. Press the <Menu> button on the printers operation panel repeatedly until [MAINTENANCE] appears in the LCD.
  2. Press the left [<] or right [>] arrow buttons to select the cleaning setting you want. Select [HEAD CLEANING] or [HEAD REFRESHING] for deep print head cleaning.
    Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
  3. Press the <OK> button.
  4. Print a Nozzle Check Pattern and perform at least two Head Refreshings if the pattern is not correct.
If this does not help, try removing the print head and then install it again. Once place, dont forget to aligh the head. Following are the steps:
Reseat Print Head Reseating the print head is seldomly needed to be done.
  1. Press the Open Button (1) to open the Paper Output Tray (2).
  2. Raise the Scanning Unit until it stops.
    1. Pull and hold the Scanning Unit Lever towards you, then raise the Scanning Unit.
    2. The Print Head Holder moves to the middle.
  3. Open the Inner Cover 1.
  4. Open the Inner Cover 2.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  5. Press the ink tank's tab (1), then remove it from the slot (2).
    IMPORTANT:
    Handle ink tanks carefully to avoid staining clothing or the surrounding area.
  6. Lift up the lock lever and take out the print head.
  7. Again, place the print head back in position and press down the lock lever.
  8. Insert the ink tank into the empty slot on the print head. Press down gently on the ink tank until an audible click is heard. Make sure the ink tank is in the correct slot.
    IMPORTANT:
    a. Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
    b. If the ink tank is inserted in the wrong slot, perform two head refreshings.
  9. Close the Inner Cover 2.
  10. Close the Inner Cover 1.
  11. Pull the Scanning Unit Lever towards you to close the Scanning Unit.
  12. Align the print head position after the print head is installed. You can align the print head position either automatically or manually. When automatic alignment does not work well, align the print head position manually.
Automatically Aligning The Print Head Position:
  1. Load A4-or letter-size plain paper in the paper support tray. Auto alignment cannot be performed when the Feed Switch is set to [CASSETTE].
  2. Press <Menu> repeatedly until [MAINTENANCE] appears.
  3. Press left or right arrow to select [AUTO HEAD ALIGN].
  4. Press <OK>. The print head position alignment pattern prints.
  5. Check the printed pattern. If the printed pattern matches the illustration, the print head position alignment is complete.
Manually Aligning The Print Head Position:
  1. Load A4- or letter-size plain paper in the paper support or cassette.
  2. Select the paper source with <Feed Switch> button.
  3. Press <Menu> repeatedly until [MAINTENANCE] appears.
  4. Use left or right arrow to select [ALIGN PRINT HEAD].
  5. Press <OK>. A horizontal pattern is printed.
  6. Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.
    (1): Bad example (Least solid box)
    (2): Good example (Most solid box)
  7. Press left or right arrow to select the pattern number that you checked in column A on the printout in step 6.
    (A): Column
    (0): Select pattern number with most solid image
  8. Press <OK>.
  9. Repeat steps 7 and 8 to adjust columns B to L. When all the horizontal patterns are adjusted, you will be prompted to print a vertical pattern [PRINT VERT. PATTERN].
  10. Press left arrow. A vertical pattern is printed.
  11. Beginning from column M on the printout, enter checkmarks in the patterns that have the most solid image.
  12. Press left or right arrow to select the pattern number that you checked in column M on the printout in step 11.
  13. Press <OK>.
  14. Repeat steps 12 and 13 to adjust column N.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Aficio Copier 1013 light on to load paper ( paper is loaded)
Check the paper end sensor, remove the tray, look inside of opening, at the top toward the right side, make sure there is an arm sticking down, wires are connected and the sensor is in place. Most common problem is the arm is dislocated or sensor out of position, See graphic 91009d0.jpg
Apr 15, 2009 | Ricoh Aficio 1013F Copier
Pixma MP830 is printing things green that should be red
when you change all new cartridges (make sure all cartridge ok, and the cartridge pins connection ok) still red color lost, it is the trouble at print head ink chanel some of that is too dry for longer time less using , most CANON printer head is separated from the ink cartridge, two way you may try:
1) take out the ink cartridge, drop down a little the special cleaner (best clean tools buy from dealer), to the head ink chanel hole, then set back the ink cartridge and waiting minutes
2) try put the print head bottom surface touch a little cleaner or water 1-2 hrs, if you can take out the print head unit. still not fixed for some case that should change the print head unit.
Feb 06, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Won't finish loading software
goto reset button refresh and check the control panel add printer, may be you more number of qued copies of file.
Oct 14, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Paper is not feeding through. Keeping getting message that "load paper". But when loaded paper is not being picked up. The meachine is only 2 years old. Olready the roller has been changed. Please advise...
The paper’s weight may be expressed on a different basis than the paper used to rate the printer’s capabilities. For example, a 20-pound bond paper equates to 28 pounds cover and 42 pounds index papers in thickness. The differences among bases stem from the sizes of the large sheets from which the paper was cut. For example, Sharp says, bond paper’s weight is determined by 500 sheets of 17- x 22-inch stock (later sectioned into 8.5- x 11-inch reams), whereas index paper’s weight stems from 500 sheets of 25.5- x 30.5-inch paper.
Match the basis for the weight of the paper to the basis of the printer’s maximum paper weight rating. If the printer was rated on only one basis, such as cover or index, and your paper ****’s wrapper only lists the paper’s weight by another basis, such as bond,
Mar 17, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Flashing lights
Hi, I work on these on a regular basis and have seen the problem many times. Almost every single time it's caused by a faulty fuser (fixing) unit. They are fairly easy to replace but they run in the 2-300$ range in cost. Good luck.
Aug 29, 2007 | Brother HL 5250DN Laser Printer
Xerox DocuColor 12 Printer Logo
44 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
