Marantz VP8600 DLP Projector Logo
Posted on May 04, 2012
Dmd error blinking blue light. projector will not turn on.
NEC WT610 Projector powers up and acts like normal, but will not project an image or the usual blue screen with menu functions. Bulb is fine and lights up, no error lights showing. It's as if it's stuck on...
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
DMD error code
the DMD is good ,
the Projector will still start up,even if the DMD is defective.
the lamp ballast or the mother board is defective
Brookstone pocket projector wont turn off
i'm having the same issue. it 1st started with a No Signal error. then this started...ugh!
Sony projector xga indicate lamp cover
there is an conductor under the cover,
pls push it down ,
and turn on the projector
Have a nice day!
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: [email protected]
http://www.lampdeng.com
2helpful
NEC M420x blinking and no light, can help me /
1,Check the fans ,whether the fan is running,when you turn on the projector
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Hello I have a M400 IBM Projector. It stopped working. I've had a lamp die on it already and I'd bought a new one. So the same problem happened again except this time after I exchanged the lamp for a new...
the lamp is ok ,is work
1,Pls check the color wheel
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD, motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: [email protected]
Skype: lampdeng.com
YM: [email protected]
http://facebook.com/lampdeng
Sharp xvz-10000 projector.\r\nI replaced the lamp and RESET the timer and projector worked fine. Now about 2 months later I have to unplug to reset the unit and when turning on the first blue light stays...
Have a nice day!
Jerry
Lampdeng Limited
Projector is brand new out of the box. Powers up displays Sim2 logo then lamp goes out power light starts to flash and turns off about 3 minutes later. Same thing every time it's turned on. Anyone had the...
the number of blinks determine the problem:
Environment Over Temperature- 1 long blink / 1 short blink
DMD Over Temperature- 1 long blink / 2 short blinks
Lamp Over Temperature- 1 long blink / 3 short blinks
Fan1 Locked- 1 long blink / 4 short blinks
Fan2 Locked- 2 long blinks / 2 short blinks
Fan3 Locked- 2 long blinks / 3 short blinks
Fan4 Locked- 2 long blinks / 4 short blinks
DMD Initial Fail- 3 long blinks / 1 short blink
Lamp Initial Fail- 3 long blinks / 2 short blinks
Ballast UART Error- 3 long blinks / 3 short blinks
Temperature Sensor Fail- 3 long blinks / 4 short blinks
Inter Lock Open- 4 long blinks / 1 short blink
any of these will result in lamp off and shutdown.
1helpful
Projector lamp shows blue on white screen
the red is cutting out. white=blue+green+red. without red, you get blu+green, or cyan. if this was an lcd projector, i'd say it's a burnt light filter, the red lcd, or the lcd has come unplugged. but since this is a dlp projector, you have either a dmd board issue or a main board issue. either way, it'll be pricey.
Acer projector
A DMD has no inherent colour capability - it's just a configurable mirror array. If you want to do full-colour projection, then, you'd expect that you'd have to use three DMDs and three coloured filters - red, green and blue.
But if a single DMD's switched in synchrony with a rotating "colour wheel" - a spinning tri-colour filter that lets through red, green and blue light in turn - then the very rapid switching speed of the DMD lets it lay down red, green and blue images in such fast succession that the result is a perfect colour image.
You can do the same trick with a single LCD panel, but it's not a good idea; LCDs are transmissive, rather than reflective, devices, and block something like half of the light that tries to get through them. To maximise brightness in LCD projectors, a three-panel design works better. If you try to pump the entire output of a super-bright lamp through one LCD, keeping it cool becomes rather challenging.
The extreme smallness of the moving parts on a DMD mean that it behaves like a solid state device, not a mechanical one. For all their complexity, DMDs have very high Mean Time Between Failures (MTBF), and well-made projectors based on DMDs can be expected to last easily as long as LCD units, and probably longer. If a DLP projector fails, it's not at all likely to be because there's something wrong with the DMD.
Top Marantz Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Marantz Office Equipment and Supply Expert? Answer questions, earn points and help others
