Question about Cameras
Mi camara T-200
Sarie, thank you very much...
"the flash board of the camera gets one fire ic damaged u remove the flash board jack ur camera will work ok without flash" mints that have not solution?.... please let me know...I save money by almost 1 year to get one of this and know i have this problem....thank you for yours Patience.
Best regards.
Helena
otacon
  • 1944 Answers
SOURCE: MEMORY CARD ERROR
To recover the data on your card. I suggest using a memory card reader and not through the camera.
Posted on Dec 16, 2007
  • 50 Answers
SOURCE: What does MF mean ?
MF means Manual Focus, to change it to auto mode go to focusing menu and change it to continues or single mode
Posted on Nov 04, 2008
  • 54 Answers
SOURCE: HP Photosmart M407
Go search for this ebay item 350138808473 and purchase the flash assembly for the m407. Other options is to search broken m305, m307, or m407 cameras (the components are interchangeable) that have working flashes. The batteries I suggest purchasing new rechargeables batteries and try a fresh charged pack. It may not be a bad idea to also purchase a AA battery recharger. You will need precision screw-driver set and electrical tape.
There are six screws on the outside of the case. Remove the six screws and gently pry the case open and remove the camera from the case. I found that placing my thumbs around the Tripod stand and opening as if it were a **** works.
The next step is to remove the LCD and the button board. What holds them in place are two small screws next to the bottom of the LCD. Remove the screws and small aluminum frame around the LCD. Using a small flat-head precision screw driver, gently pry the LCD loose from the base that is soldered to camera main circuit board. The LCD should be hanging by the ribbon cable. Using the precision screw driver, gently loosen the prongs that hold the LCD in place. After the LCD has been remove, remove the button board, which should be loose (it snaps into the main circuit board and it is taped to the flash assembly. Try to have as much of the tape on the button board after removal. You can use packaging tape to replace the tape.
WARNING: The flash assembly contains a 330 V capacitor. The flash assembly is covered with black electrical tape to prevent accidental contact to any expose metal. Contacting the metal will give you a good size shock.
The next step is to loosen the flash assembly from the camera. In the back of the camera, underneath the LCD and button board, there are three black screws that holds the battery chamber in place. Remove these screws, but the chamber is also screwed the flash assembly. Turn the camera around. You will see that there are three items attached to wires that you will have to either pry or snap off. The first is the switch by the battery door. The next is the speaker that is snapped into the assembly. The last is a disk that is sticked to the batter chamber (via an adhesive) Gently pry each of these loose (using a small flat-head precision screw-driver) and leave each component hanging from the wires.
There are two screws that attach the battery chamber to the flash assembly. You will need to look for theses screws underneath the black tape. The first one is easy because it the edge of the assembly. The second one is located in the middle of assembly and you will have to lift the tape to expose the screw. There is a third screw that holds the small valance of the flash bulb. This can stay on. Once the screws have been removed, the battery chamber should dangle out. (PS. This exposes the SD card slot if you need to straighten out bent copper prongs that prevents your card from being read.)
The assembly is plugged in to the main circuit board. This is located behind the capacitor (which looks like a battery.) Special care is require to wiggle or pry the open the plug to avoid damaging the plug from the flash assembly or from the main circuit board. I usually sit the camera on the table and stick the precision screw-driver in that area behind the capacitor and carefully pull the screw driver up. Once the flash assembly is loose, it should plob over to the overside, being held together by a copper foil that has been soldered to both the flash assembly and main circuit board. Try to leave as much of the copper foil behind with main circuit board as you tear the foil to fully remove the flash assembly.
Plug the good flash assembly into the slot on the main circuit board. Tuck the copper foil back underneath the tape. Screw the battery chamber back into place. Tuck back the battery door switch, speaker and disk back into proper location. Replace any black tape with electrical tape. Assemble the button board and LCD back into the main circuit board. Screw back in the alumnimum frame. Put the main camera inside the back half of the camera plastic case. Put the battery door in place (this may fallen off when removing the case. Snap in the front case and screw the case shut. Test the camera for functionality.
Posted on Jan 05, 2009
sandy_s
  • 111 Answers
SOURCE: kodak easyshare z650 flash not working
does you flash even open anymore? you might can find repair at.
www.kodak.com/eknec/PageQuerier.jhtml?pq-path=10&pq-locale=en_US
Hope this helps
Posted on Apr 25, 2009
  • 919 Answers
SOURCE: flash Does not work. Can only take pictures in flash-off mode
The problem you are describing is a problem with the flash charging indicator switch inside the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $83 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Posted on Jun 03, 2009
Mi camara canon powershot A3100 IS se apaga automaticamente y aparece en la pantalla se ha detectado un error. debe reiniciar la camara y yo no se como solucionar eso porque no he podido reiniciarla. como...
TENGO UN PROBLEMA CON MI CAMARA POWER SHOT A 3100 IS LA MISMA PONE EN LA PANTALLA SE HA DETECTADO UN ERROR DEBE REINICIAR LA CAMARA DIGAME COMO SOLUCIONAR ESTE PROBLEMA MI CORREO ES josemm22@yaho.com
Aug 28, 2011 | Canon PowerShot A3100 IS Digital Camera
A mi camara ya no le funciona el flash
Hola, si no esta desactivada desde el panel de control, posiblemente la lampara o su circuito de alto voltaje se ha daniado, lo recomendable es que lleves la camara a un centro de servicio autorizado para ver si es necesario reemplazar las unidades mencionadas anteriormente.
Mar 07, 2011 | Sony Cyber-shot DSC-S750 Digital Camera
The flash wont work when i take a picture. should it work on auto mode?
Hello
Thank you for using FixYa for your problem
The flash will only fire if it is required on Auto mode, flash on mode means it will fire all the time
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 03, 2009 | Samsung S760 Digital Camera
Perdi el cd de instalacion de mi camara largan chameleon xp
donde puedo encontrar este cd para poder bajar las fotos a la computadora de mi camara
May 29, 2009 | Largan Chameleon XP Digital Camera
NECESITO CONFIGURAR MI CAMARA EN LA COMPUTADORA Y NO PUEDO....
pero tienes el cd?, de todas maneras yo estaba de vacaciones y deje el cd en mi casa, pero conecte la camara al computador de un amigo y las vaje de una vez, sin habere instalado el software(CD), luego cuando llegue aqui a mi casa instale el cd y el programa se llama arcsfot photoimpresion 6, despues tuve problemas para ver el video que habia hecho, pero tuve instalar quicktime, bueno si alguien puede dar mas informacion, a mi me gustaria saber mucho mas de la camara, porque me aparecen iconos como un avioncito, una rueda, tambien tome una foto y tiene sonido, si alguien sabe todas las funciones que no estan en el manual mi correo es indytu@hotmail.com clocas ref.camara
gracias
indira
Jan 12, 2009 | General Electric A835 Digital Camera
E.91:01
Nov 19, 2008 | Sony Cybershot DSC-T200 Digital Camera
WHERE DOWNLOAD
my AC power Adepter for the Benq DC 3400 is damaged...
Jun 29, 2008 | BenQ DC3400 Digital Camera
Pc camera web cam philips
The wires came loose out of the camera.....where do they go on the circuit board red, white, green, blue and black. Can I solder them back on, I have it open - where do they go?
Thank you!
Mar 24, 2008 | Philips J44414
Cameras Logo
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
