Question about GE Profile Harmony DPGT750EC Electric Dryer
GE Profile dryer Model# DPSQ475ET4WW
I have this dryer and it is squeeking badly and as it heats up it seems to start fading away, but starting it up at first up it squeeks real bad. I have no owner manual on the dryer which I would like to obtain one, and need how to instructions to fix this dryers problem and obtain parts so I can fix it.
Thanks,
Elaine Mohr
  • 1,543 Answers
You posted under a DPGT705EC and then a DPSQ475ET4WW, so I am going to guess you have the later one. If it has not been squeaking for an extended time you can get by with just changing the rear drum sleeve bearing (WE3X75). To do this, use a putty knife to push in on the 2 clips about two inches in from the sides at the seam where the front panel meet the dryer top, allowing top to swing up and back. Remove screw holding front panel to side panel near top just under where the top was. Tilt front panel forward and lift off bottom pegs. Swing to side (you don't have to remove wires). Pull drum forward about 6 inches. (you don't even have to remove the belt.) Change sleeve at center back of drum. Make sure to inspect the front drum support slides WE1M481dark ones and WE1M333 white ones (about 1/2 inch x 2.5 inch strips at the top of the front panel which support the front of the drum), as about the time the rear bearing goes, these may be wearing also, especially the one on the left side. You may have to contact GE to obtain an owner's manual (but there is nothing in them about how to service the dryer, just installation and settings, etc.) Parts can be obtained from just about any appliance service company or appliance retailer which does service in your area.
Posted on Nov 19, 2008
GE profile dryer,Runs fine but no heat
need to have the heat element checked with a multimeter and visually if u can and look for burns and corrosion and breaking of the wire connections. Also have the thermostats checked, Im assuming its electric and not gas? the thermal cut off may be bad and the hi-lo thermostat, these can shut heat off from the dryer. Ive replaced the element on my G.E profile and it wasn't all that hard rather simple.
Sep 13, 2014 | GE Profile Gas Dryer Model Dpsb513gb0ww
Kenmore whirlpool dryer won't start and has a bad burning smell
You may have an overheat sensor that is burning up. The dryer won't start because the heat would be uncontrollably high otherwise
Jan 29, 2013 | GE Profile DPSF495EW Dryer
My Ge Harmony Dryer sometimes will not spend. It heats up but will not spend at times.
Try manually start the dryer. Take a piece of tape and tape the switch on the door. Then take one hand turn the drum and press the start button at the same time. If is starts then then you have bad motor.
May 18, 2011 | GE Profile Harmony DPGT750EC Electric...
GE Profile gas dryer won't ignite
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 01, 2010 | GE Profile DPXH46EAWW Gas Dryer
Runs but no heat
May 29, 2010 | GE Profile Harmony DPGT750EC Electric...
Ge profile harmony electric dryer doesn't always heat.
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 16, 2009 | GE Profile Harmony DPGT750EC Electric...
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
Constant squeeking while drying clothes
It's most likely the roller bushigs/axles which need lubricating -- they've probably not failed yet, but will if ignored.
They squeak more when clothes are wet because of more weight.
I'd also lubricate the motor while your in there.
May 08, 2009 | Dryers
My GE Profile Squeeks
Yes it still squeeks and it still drys and it kinda stops being so loud after the dryer has been drying for some time. Need help on solving this iissue and how to fix it.
Thanks,
Elaine Mohr
Nov 09, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
316 people viewed this question
Top GE Dryers Experts
Richard Roth
Richard Roth
Melissa Martin
Melissa Martin
ancel1961
Level 1 Expert
Are you a GE Dryer Expert? Answer questions, earn points and help others
