Question about OKI MICROLINE 395 Matrix Printer
Oki ML395 printer, paper continues to feed
When form feed is pressed, the paper will not stop feeding
  • Anonymous Mar 14, 2014
    Continues Paper Feed
  • Anonymous Mar 20, 2014
    I have a brand new OKI Microline ML395 dot matrix printer. I installed it on a Unix system and it works well except for the page tear off. Because the page stops printing at the position ready for the next print which is below the top cover, I need press form feed to to be able to tear it off, thereby wasting a page.
    Habit-Forming:
  • 40 Answers
Your paper feed sensor maybe stuck or a piece of paper could be stuck in the sensor.Hope this helps ?
Dezzi
Posted on Nov 29, 2008
Oki microline 320 form feed
Am afraid the Power Surge (when the power came back on) has damaged the unit and there is no "Reset" to these printers. You would need to replace the control board but as its a power surge there is a reasonable chance that the power supply will have been damaged/weakened and this will lead to a shortened life span of the printer. I would throw it away and replace with new. sorry, ( I am not a salesman either)
Jul 18, 2017 | OKI MICROLINE 321 Turbo Matrix Printer
Problems with Printing Special Size Forms
you have to chk the setting on the print setup.
Jul 04, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
HOT TO ADJUST THE TEAR HEIGHT ON A MICROLINE 490 WITHOUT USING THE SETUP DISC
If you are using regular letter size continuous printer paper, load the paper normally with the machine turned off. You can even turn the knob to feed the paper through, it doesn't matter how far. Turn the printer back on and press "PARK" button. Then press the "FF/LOAD" button and when you begin printing it will automatically print at the top of form (TOF). If the TOF ever gets thrown off you can press "LINE FEED" until the tear is where you want it and press "SHIFT" > "TOF" to back back to the previous page (or top of form).
Simply put, pressing "PARK" then "LOAD" should set the tear where you need it.
May 20, 2011 | OKI MICROLINE 490 Matrix Printer
How to install paper in oki microline 320 turbo printer
Paper Loading
Rear Feed, Continuous Forms
Use the rear-feed path for printing on single-thickness,
continuous-form paper.
Use the single-sheet path (top feed) for graphics or charts.
! If you have paper in the paper path, be sure to remove it
before installing rear-feed paper.
1 Lock Lever
2 Upper Tractor Cover
3 Pins
4 Lower Tractor Cover
32T-26.eps
1 Move the paper lever to the position marked "REAR."
32T-11.eps
2 Grasp the tabs lift off the paper separator.
3 Pull up on the lock levers and open the tractor covers.
Then, move the right tractor to fit the width of the paper.
32T-27.eps
4 Place the first two holes in the paper over the tractor pins
on either side. Close the tractor covers.
32T-29.eps
5 Move the left tractor to align the edge of the paper with
the appropriate reference mark (1). Then, push back the
lock lever.
32T-29A.eps
6 Adjust the position of the right tractor to center the holes
in the paper on the pins. Then, push back the right lock
lever.
32T-29.eps
7 Install the paper separator. Place the wire guide (1) on the
pull-up roller assembly (2).
32T-31.eps
8 Press FF/LOAD. The paper feeds into the printer.
! The factory default setting for the Top of Form (where
the printing should begin) is one inch down from the top
of the page. To change the setting, see "Using Your
Printer, Top of Form (TOF)."
Top Feed (Single Sheets)
Use the single-sheet path for letterhead stationery, memos,
and individual envelopes.
! If you have continuous-form paper in the path, press
PARK to remove it before loading single sheets.
1 Make sure the printer is on and deselected (SEL light off).
2 Place the paper lever in the position marked "TOP."
32T-12.eps
3 Open the carriage cover. Raise the paper separator to the
single-sheet position.
4 Make sure the wire feed guide (1) is secured in the sheet
guide.
5 Adjust the paper feed guides (1) for the width of the paper.
Place a sheet of paper in the separator. The paper will feed
into the printer.
32T-15.eps
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 04, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
Oki 321 turbo in PPR emulation mode, does a form
Generally the form feed character is sent by your software. Try setting the page length in the printer setup to be the length of one label.
Sep 28, 2009 | OKI MICROLINE 321 Turbo Matrix Printer
I cannot get the printer to form feed, it only manual feeds, how
I take it what you're saying is that you have to feed paper via flipping out the front tray and then pressing "online" or "continue", and that it will not feed paper from the actual paper tray?
You can try to take the beast apart and see why the control panel is not functioning, but I'd sit it on the curb, as it was probably manufactured sometime between 1993 and 1997. time to let the old girl die.
Mar 05, 2009 | HP LaserJet 4 plus Printer
I need to test several OKI 3410's
Procedure
To perform the Font Sample Test, follow this procedure.
1. Verify that continuous feed paper is installed.
2. Verify that the ribbon is correctly installed.
3. Verify that the width of the installed paper matches the paper width menu setting.
4. Power OFF the printer.
5. Press LINE FEED as you power ON the printer.
6. The test will print.
7. To stop the test (at any time), press SELECT.
8. When the two page test is complete, the SELECT lamp will turn OFF.
9. Press SELECT to place the printer ON-LINE.
Good Luck
Feb 04, 2009 | OKI Pacemark 3410 Matrix Printer
Oki microline 280 feeds paper continiously after a file print, and won't stop till i pull power cable
First, reinstall the driver and be sure it's the correct driver for this printer. If you drive a word document does it do the same? If not, chanses are the db application is constantly sending form feeds to the printer and the printer will do whatever it's told to do. Try a different printer setup in the db application.
Aug 27, 2008 | OKI MICROLINE 280 Elite Matrix Printer
Okidata ML320 feeding blank sheets
Which IBM driver are you using ? try using a IBM proprinter driver.
Hope this helps.
Dezzi
Mar 25, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Form feed length for 280
change in your computer driver setting
if you using windows xp
click to
start
settings
control panel
printer and fax
select your printer and right click
properties
in general menu
printing preferances
change here paper size
select letter 8.5" 11"
Feb 28, 2008 | OKI MICROLINE 280 Elite Matrix Printer
OKI MICROLINE 395 Matrix Printer Logo
342 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
