Question about Pioneer SD-533HD5 53" Rear Projection HDTV
I have a 533hd5
The fuses people are talkin about are they glass or soldierd in
  • 68 Answers
Soldied
Posted on Nov 19, 2008
My sd-533hd5 53in.the colors will divide into the blue green and red. then blow a fuse ?
from what i have had in the past was with this problem was convergence problems but it seems to be something originating from your main board.
Nov 06, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
My sd-533hd5 keeps blowing the 5 amp 125v fuses
Yes! it sounds like a power supply problem! or the flyback in the main board needs replaced ( part is in the $70.00 range
Dec 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Help
HELLO ok the first thing to do is unplug the set.!!!!#2 then take off the back of the set.!!! #3 then look for the fuse holder's there will be 3 to 4 of them. and check them to see if there good.!!! # 4 ok if all the fuse's are good .then it still could be a couple of thing's a clod solder joint.!!! or dry socket.!!! or a bad fly back transformer.!!! & horz.out put transtior.!! are bad and need to be replaced. well hope this help's you "GOOD LUCK"
Aug 11, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Sd-533hd5 53
aj6404: what you described is what I understand to be referred to as an overload protection fault circuit kicking in. Sounds like you might have a fuse blown. Check the fuses on the PCB's. Unplug the power cable from the wall and allow it to sit for about 30 minutes before removing the back cover - till will allow the circuits to discharge before you go poking around - don't want to get shocked or popped by an arch.
Jul 02, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Power problem (switches to standby)
its the problem of the ics on the main power supply board
Do the IC heat sinks get warm??
If they do not, check fuses F852 - 2AMP, F853 - 1.25AMP, F850 & F851 - ALL 5AMP on the power deflection pcb. THESE ARE NOT GLASS FUSES. They are usually about the size of a 1 watt resistor and either green or orange in color. They are soldered in. The nomenclature is printed on the component side of the board. They are all about centered on the opposite edge of the PCB as the high voltage transformer.
If you have cleaned up the mess you describe you most likely have one of these fuses blown.
if dont have any technical knowledge its advisable to call a technician as it is worth getting it fixed.
thanks.
May 19, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
ICS
i'm guessing your talkin about convergance ic's. if so they are located on the biggest heat sync in the set. should be two ic's on it, enless it is one huge ic's.
The fuses are usually located at the back of the set usually next to a small transformer. they are usually not glass fuses but solid green small and they are soldered in the board. you can check them with any ohm meter and they should check shorted. your meter should read 0 when you test them.
you may have to hold your meter on the fuse for up to 10 seconds to make sure it stays on 0.
the ic's are flat and sit up vertically on the heat sync.
if your confused and dont want to try it, then i would recomend you get a local service center to do it for you.
Apr 24, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Vertical lines on screen
this is the convergence gone bad. that is what was blowing the fuse. this is the board on the far left. there are two stk`s on this board. stk392-110.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 05, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Not turning on
Power supply board pull,then remove original solder on 5 volt
regulator pins then resolder + replace 4 amp fuse........T.
Oct 25, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer sd-533hd5 not turn on
Theres 3 boards on the bottom inside of tv. The middle circuit board has 3 small fuses toward the center of the board. Just pop those fuses out and look for the 1 that is broken or burnt. Taken the bad fuse to radio shack and get replacement. Very easy repair.
Sep 24, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
