Question about Samsung SSC DVR Digital Video Recorder with 80 Gb Removable Hard Drive
SAMSUNG SSCDVR ALARM + REC STAY ON
THE ALARM AND REC STAY ON EVEN WITH NO CAMERA'S HOOKED UP. IF I PUSH THE STOP BUTTON THEY GO OFF FOR A FEW SECONDS BUT THEN COME BACK ON.
    Problem Solver:
  • 7 Answers
Theres a setting in the menu that makes it do that. I think it might be the scheduled record times that you set in it. to get back to the menu ( the smaller button next to the large round multi button), push stop and when the record light goes out (real fast)!!! push the menu button, then you should be able to change the setting in the menu...
Posted on Apr 03, 2009
  • guitarzan4 Apr 03, 2009
    p.s. If its the vcr record light thats on, then your harddrives not working right...
I have a westclox 70034 and I need to know how to set the alarms
Push the alm1 alm2 button until your desired alarm number shows. Then hold the alm1 alm2 button for approx 3 seconds. The alarm time will flash. push the ADJ button until you reach the time hour you want. Then push the alm1 alm2 button to set the minutes. push ADL until you find the desired minutes. The push alm1 alm2 button and alrm will stop flashing. Your alarm is now set...... I to lost the manual and had to figure it out myself.
Dec 14, 2010 | Vacuums
Watch Problems
PROVIDE US HERE THE WATCH MODEL..
AND ALSO PROVIDE A DETAILED PICTURE IF POSSIBLE...
Sep 17, 2008 | Watches
Forgot password to Samsung SMT-190DN
Hold the remote control's STOP ( ) button for
longer than 5 seconds. “INITIAL” appears on the display and
all settings will return to the default values.
• Press the POWER button.
Using the RESET function will erase all stored settings.
Do not use this unless necessary.
Oct 06, 2009 | Samsung SMT-190 19" Flat Panel TFT LCD...
My samsung L830 camera has jammed with the lens open and
Just had this happen to my L100. First, take out the battery and wait a couple hours for everything to cool down and discharge. Then place the battery back in. Then plug the USB cord into the camera and PC. Then turn the camera on and it should be okay. Just worked for mine.
Jul 15, 2009 | Samsung Digimax L830 Digital Camera
Start button not working standby light staying
The switch is for 'REC' 'Standby' and "PLAY".
If you leave it switched to "Play" and pull the plug and push it in to the wall receptacle (mains) it should start playing after a few seconds delay. The same for "REC". You use a timer unit on the power cord for those.
If you have the switch in the middle position and plugged-in, you should have a tiny Red LED illuminated. Push "Power" and it should start-up and be ready to use in a matter of a few seconds.
Feb 22, 2009 | Sony MDS-JE520 Mini Disc Player
How to clean Heads of DVX100B
Hello there! This kind of tape is abrasive and so when it starts to rotate the S-post is not rotating one and the tension gets higher than it use to be with a normal tape.The best solution for this problem is to rotate upper drum slowly by hand carefully and spray towards it a head cleaning spray.Then wait for 15 min.and blow hot air from a hair dryer inside mechanism for 10 seconds ,and by this action no more droplets will stay on the drum surface.Attention when you put the first tape wait for 15 seconds in pause or stop mode and after push REC or PLAY button.
Jan 05, 2009 | Panasonic AG-DVX100B DV Digital Camcorder
Camera shuts off after a few seconds
i had that problem with another camera i toggled with the lens it went in and works like a charm. Dont be to gentile it will go in
Oct 08, 2008 | Samsung S630 Digital Camera
Samsung Media Player
You can reset the mp3 player by holding down the "menu" button and the "a/b" button together for a few seconds then push the power button and it should turn on. Mine was doing the same thing and this worked.
Mar 02, 2008 | Samsung Yepp YP-T9 Digital Media Player
Not Able to Record/Playback
can't record on the my Olympus VN-1000
+ I press rec button and it just shows rec in display (no recording time is shown ONLY rec)
+ there is no play back  or stop function
+ i can only stop  rec by removing batteries (stop or play will stop rec only ONCE - but there is no  useful function - such as play or stop or rec.)
+ I tried all trouble shooting tips in manual  with no effect
+  i cleaned the spring contacts inside battery compartment that interface with the  batteries
+ it was barely used - and has not been used for a 1 year ( no batteries were inside it )     it was inside a drawer
THANK YOU
Jun 16, 2007 | Olympus VN-1000 Digital Voice Recorder
Samsung SSC DVR Digital Video Recorder with 80 Gb Removable Hard Drive Logo
139 people viewed this question
Top Samsung Home Security Experts
Gary Banta
Level 1 Expert
Cesar Quant
Cesar Quant
Colin Stickland
Colin Stickland
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
