Question about Frigidaire PLEF398AC Electric Kitchen Range
Oven get hot just not real hot to cook in it - Frigidaire PLEF398AC Electric Kitchen Range
  • syreetadanie Nov 19, 2008
    what r the broil element where r they at
    its gas
  • 370 Answers
Check to make sure the broil element works. If not replace and your fixed.
Posted on Nov 19, 2008
  • Justin Duby
    Justin Duby Nov 19, 2008
    Is it gas or electric? If its electric its your top oven element.
  • Justin Duby
    replace your oven sensor.
Oven turns off without warning
I had to replace the thermo coupler in mine. Would heat up then go out.
Aug 17, 2014 | Dacor Epicure ERD30 Dual Fuel (Electric...
I need instructions for 10in. microwave browner
Only place I've found is here: CorningWare Browner Instructions
As these dishes were designed by Corning for a 650 watt over, you can recalculate preheat and cooking times for your oven with the following formula:
650/(your oven's wattage) x (listed preheat time or cook time)
For example, for a Corning MW-9 dish, they list 4 minutes maximum preheat time. I have a 1,580 watt oven. So 650/1580 = .41 x 4 minutes = 1.64 minutes and about a minute and a half preheat. (MAX).
Mar 09, 2014 | CorningWare Microwave Ovens
I have a tappan gas stove. the stove top works but the oven doesn't heat up enough to cook and i can smell gas. I checked the gas line and it is tight with no leaks. i am wondering what could it be and...
You could do the repair yourself. Much more information is needed. Is your oven spark ignition or hot surface ignition ? A valve may be opening only partially. This can happen on a hot surface ignition system when the glow bar is starting to malfunction. Need to know more details to be of real help.
Tom
Aug 10, 2010 | Tappan TGFS26C Gas Kitchen Range
My oven takes ages to cook things am i missing
We had this problem; Your thermostat is probably broken. To test this theory, buy an oven thermometer and test how accurate the oven is. My bet is you will find this to be off. Fix it now, otherwise, it might lead to other issues.
Mar 31, 2010 | New World G90m Gas Double Oven
Simpson Evolution 904 wall oven cooks very unevenly
I agree, the heating is very uneven in our oven, however, when I calibrated the temperature with a thermocouple, I discovered that the temperature gauge was 25C too hot! That is, if I set the oven temperature gauge to 155C, it was actually 180C inside the oven! Taking this in to account, it is now much easier to cook things without them burning.
Sep 26, 2009 | Ovens
Stopped Working!
check the switch or thermal fuse, if it has.
Aug 29, 2009 | Black & Decker TRO603 Toast-R-Oven Toaster...
Gets hot too quickly food cooks too quickly
no oven heats to what the dial says, all are to hot or to cold. try reducing the cooking temperature by 50 *, so instead of cooking a roast at 350, set at 300. i have never seen a stove that is heating to the temperature of the setting.
Jul 05, 2009 | Zanussi ZBF260 Electric Single Oven
Maytag cook top too hot!
Remove cooktop and check to see how much insulation is below the top, on top of the oven cavity, You may want to install some more insulation. The specs for this range probably allows this to happen. you should not put anything on the top after cooking in the oven, as glass breakage may occur.
Dec 04, 2008 | Maytag MER5775Q Electric Kitchen Range
Frigidaire PLEF398AC Electric Kitchen Range Logo
53 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
