I have a Likom HD19A monitor. Its about 1 1/2 years old. I usually leave my computer and monitor powered on all the time. The monitor started failing to come on when I would press a key on my keyboard. If I turned the monitor off then back on and it would come on and work just fine until the computer went to standby, then I would have to turn monitor off and on again to get it to come on. Note: green led woud always be ON. Recently when I would turn it off and turn it back on it started showing a blank, "cream" colored screen. Then maybe it will work and maybe not. Could this be a "back-light inverter board problem, or something else that is repairable? Or, has the monitor finally gone bad? I have a second identical monitor and it works fine, so it is not problem within the computer itself. Thanks.
when machine is rebooted, the monitor has to be unplugged and then replugged before it will come on. i must have to press down on power to keep led light on while machine is rebooting.
Solution #1
posted on Jun 19, 2008
Guest
Rank: Apprentice Rating: 0%, 0 votes
I have had similar problems. It would appear that the power supply is at fault, not the monitor.
Was this solution helpful? Show your Appreciation by rating it:
