Question about Aiwa XR-M88 Shelf System
My AIWA XR M88 Remote control unit power swich ceased functioning
I bought this excellent system about 10+ years ago
  • 29 Answers
SOURCE: aiwa xr-ms5 cd recognition problem
If your player won't recognize a disc, make sure the CD is properly loaded and not scratched, and that the lens is clean. Clean the lens. Use only a special CD lens cleaner and follow the instructions carefully. Check the traverse assembly (the metal rod that the laser travels along and the gear that drives it) if CDs aren't recognized or won't play, frequent skipping occurs at random, CDs randomly get stuck in one spot, the player can't find tracks correctly, or cleaning the lens doesn't work. Dust and lint may be interrupting its function. good luck :-)
Posted on Jan 11, 2006
  • 1894 Answers
SOURCE: Aiwa XR-M800 - can you help with this model?
use the power off button
Posted on Jun 06, 2008
mnelsonix
  • 58 Answers
SOURCE: Aiwa z-l700 won't switch on?
1. Verify you really have power at the outlet. If so...
2. You will need to open up the main boby of the device (amp portion).
3. On the circuit board where the power plug comes in, you need to look for a fuse or fuses. Do you know how to check these? This is most likely the problem. Good Luck!
Posted on Apr 07, 2009
SOURCE: Which Aiwa remote control unit to buy.
Went to manufacturer's website.
Posted on Dec 12, 2009
  • 19 Answers
SOURCE: how do i open the speakers on Aiwa XR-EM50 CD
on most speakers like this you will Pry the Grille Off and the actual speaker drivers can be removed by loosening screws holding them in the enclosure.
Posted on Oct 26, 2010
Where can I get an FM aerial for a radio
Make one. Take speaker wire, split the pairs apart so you have about 4 feet separated, twist the ends together, make a T shape and hook up the other end to the Stereo. Hang it on a wall maintaining a T shape.
Jun 04, 2014 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Tip
Aiwa XR-DV370KN Region Free Fix
Aiwa XR-DV370KN DVD Player Region Free Fix
Would you like to unlock your Aiwa XR-DV370KN DVD Player to Region Free?
Follow these steps to unlock your Aiwa XR-DV370KN DVD Player:
  1. Press the Pause button on your remote control.
  2. Using your remote control enter the numbers 3, 1, 4, 1, 5 and 9.
  3. Press the 0 button on your remote control for Region Free, 1 for Region 1 or 2 for Region 2.
  4. Press the Pause button on your remote control.
  5. Power off your player and wait a few seconds.
  6. Power on your player.
Your Aiwa XR-DV370KN DVD Player is now Region Free.
I hope that helps.
on Apr 25, 2010 | Televison & Video
Aiwa XR-EM50
This was easy.. download the manual here:
http://www.nodevice.com/download/user_manual/aiwa+xr-em50.html
From the manual:
Clock Adjustment: (Page 7)
Setting the clock
1 Hold down SHIFT and press CLOCK on the remote
control.
When the unit is turned off, you can also press SET.
2 Within 6 seconds, press "< <" (rewind icon) or > > (fast forward icon) to set thetime.
Each press changes the time in 1-minute steps.
Holding these buttons down will vary the time in 10-minute
units.
3 Press SET.
The time display stops flashing and the clock starts from
00 seconds.
When setting the clock on the unit in stop mode, hold down
"square" (stop icon) and press "> >" in step 1. After setting the time in step 2,
press TONE in step 3.
To display the time while the power is on
Hold down SHIFT and press CLOCK on the remote control.
The time will be displayed for 6 seconds.
To switch to the 24-hour standard
Display the time and press s within 6 seconds.
With each press, the clock alternates between 12- and 24-
hour standard time.
Tip:
In the 12-hour standard, "AM12:00" indicates midnight and
"PM12:00" noon.
If the clock display flashes when the unit is turned
off
There has been a power interruption. Reset the clock.
Bass / Treb Adjustment: (Page 11)
1) Press BAS or TRE
2) Within 6 seconds, turn VOLUME (press VOLUME +,- on the remote control).
Each level can be adjusted from "-2" to "+5".
Good Luck!
Apr 07, 2014 | Audio Players & Recorders
Being 120 v0lt was pluged into a 220 volts does it have a fuse or braker? it does not work
if you plugged it in without putting a step-down transformer in between the two, you have likely killed your 120 system.
Apr 16, 2012 | Aiwa XR-M88 Shelf System
AIWA XR-EM20 CD player
dude, u dont have the instructions?
Usually with the c button u can do everything..with the b one u shoose and the a one u save.
Aug 20, 2008 | Aiwa XR-M88 Shelf System
Aiwa XR-M88 Shelf System Logo
224 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
