Question about KitchenAid 24 in. KUDI02FRSS Stainless Steel Built-in Dishwasher
Leaking Dishwasher Help!
I have a Kitchenaid KUDI01FLSS2 dishwasher. My husband bought it at Lowes on sale two years ago and it has been waiting patiently in our basement to be installed until now. I finally hired someone to install it only to find that it leaks terribly from underneath. Closer inspection shows that the circular "mount" that holds the motor in place is only loosely attached to the unit with three flimsy plastic clips. They cannot possibly provide a seal like this. Is this a known design problem or am I missing some part of the seal/mount assembly? any thoughts/suggestions welcome! Thanks!
  • 734 Answers
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Posted on Dec 12, 2008
SOURCE:
The start button on my KItchen Aid Built in Dishwasher KUDI01FLSS2 will not start, there is power and the control lock is not on. It just will not start
I had the same problem although my dishwasher quit working in mid cycle. Once it quit, there was no power to the unit. I replaced the thermal coupling fuse and that solved the problem.
Dec 27, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
The clean light will not stop blinking so the normal cycle will not run
From another link, clean light flashes 7 times. Turn off breaker for dishwasher, wait 5 minutes, turn back on. with dishwasher door open, push high temp, energy save dry, high temp, energy save dry, then close door, open door, press cancel and then Normal wash cycle. Dishwasher Starts!!!!!! Save myself several hundred $. Was about to buy new one from Lowes!!!!!! Thanks everyone!
Feb 01, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
My KitchenAid dishwasher is not getting my dishes clean.
Sounds as though the heating/drying element or the controller has gone kaput... You will probably need it serviced.
Jan 31, 2010 | Dishwashers
The new dishwasher kitchen aid we bought is leaking
If it is leaking from the front, then there is a problem with the seal that runs around the front of the dishwasher. It is usually located behind the main door on the edges of the unit itself, it will look similar to weather stripping. A cheap way of fixing this is to get real good weather stripping from Wal-Mart, Home Depot, Lowes, etc. It will have a sticky surface on one side, you peel off the paper, then apply the weather stripping to the actaul door, first try to mark where the old one sits against it.If its leaking from underneath, than it can be a number of things, but most are easy to repair, you just have to pull the dishwasher completely out to get a better look. Sometimes one of the components will be leaking, but for the most part, it might just need a new hose clamp or tightened up. Hope this helps.
Dec 27, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
38 year old kitchenaid KDI-16 imperial dishwasher
yep you can just get springs from lowes or home dept or your local hardware store; they're often in with the hardware (i.e., screws) and not plumbing. remember that the springs need to stretch out a bit, too; so you may end up buying springs that look shorter than they should, but they eventually habituate.
Jul 07, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid Dishwasher door wont latch
I have a brand new whisper quiet dishwasher model kudk02crbs4 I hook everthing up but the door does not lock what is worng I have no clue what wrong
Apr 14, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
KitchenAid 24 in. KUDI02FRSS Stainless Steel Built-in Dishwasher Logo
392 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
