Question about Samsung WE356A5W Washer/Dryer Laundry Pedestal
Samsung WA13G7Q1 not draining
I emptied the machine via hose using gravity and hose not blocked, but still not draining. Pump making a noise and it sounds blocked. How can I clear it?
Jahn27
  • 1554 Answers
SOURCE: During the wash cycles, the
Stop using the machine unless you have checked the pump and make sure it is not leaking. The leak is likely coming from the pump and it may result it to short out as may be indicated by the burning smell and its failure to pump out water. Short circuit in the pump will eventually lead to a much much bigger problem which is the burning out of the motor controller module.
Drain water manually by gravity into a bucket or shallow basin but enough to hold the water from the machine. Once completely drained, lay the machine on its front on a cushioned floor to access and check the pump. Replace the pump if leaking or if there's any sign of electrical failure.
Please make sure to accept the solution should you find it helpful and informative. Failure to do so will automatically give credit to the first solution no matter how non-informative or not helpful it is. But accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Sep 11, 2010
the dr
  • 447 Answers
SOURCE: water not draining during cycle
Did you check the lid switch?? Is it spinning???
Posted on Oct 05, 2007
  • 136 Answers
SOURCE: samsung wa13g7q1 gives se error
Please check the following :
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
Posted on Jan 20, 2010
SOURCE: Tricity bendix aw 1001 w is not draining,pump and
If you have checked all of these then the only other explanation is that the pump motor is faulty and needs replacing or there is a fault with the wiring or Programmer.
Posted on May 03, 2010
SOURCE: while the machine was spinning
There is a switch under the rim which the lid actuates -- when the lid is up the switch is opened to prevent the machine from spinning -- there is a "post" on the lid which pushes this switch when the lid closes -- sounds like this lid switch is malfunctioning -- perhaps loose, or broken, or maybe burned contacts -- more info, let me know.
Charlie
Posted on Jan 29, 2011
Samsung wa13g7q1 top loader
UNPLUG and lean forwards. sounds like a blocked pump. look underneath for the pump and remove it, check out inside and remove any blockages.
Nov 18, 2013 | Samsung WE356A5W Washer/Dryer Laundry...
My samsung top loader will only drain
Very easy repair. By dropping the hose gravity takes over allowing the water to run out. The buzzing noise is the propeller on your pump jammed.(Brawires,coins,hairpins) < common causes.. STEP 1:Drop hose down to remove water from machine STEP 2:Lean machine forward on a 45,rest machine on a chair. STEP 3:Bottom left of machine is a round black cap,remove the cap(turn anti clockwise) STEP 4: Put your fingers in the pump and pull out the coins,hairpins etc from pump. STEP 5:Turn propeller to make sure it turns freely,put the round cap back on then your done. Thanks
Jun 20, 2012 | Washing Machines
Hotpoint WD61 - I have taken back off, emptied blocked filter but having reasssembled the water does not drain and therefore does not spin. If I empty water via a bucket from drain hose the machine does...
hello, is sound like the pump not energizing the pump needs testing with a multimeter. fill it up again then empty it you should hear the pump kick in also check the hoses make sure there not kinked good luck
regards
shaun
Dec 05, 2010 | Washing Machines
Hi there i am using lg wf-f712pc a top load washing machine and today i realised that the water did not drained out and the machine refused to spin after washing.... when i forcefully tried to turn the...
Your machine won't spin because it can't drain.
You probably have a blocked drain hose or a faulty/blocked pump.
If you put the drain hose below the water level in the machine it may run by gravity. If it does flow this way it would show that the hose is not blocked (completely).
Make sure the machine is empty before continuing.
NOTE! Unplug machine from power supply!!
There is probably a small cover near where the drain comes out of the machine. Unscrew this cover and you will expose the pump filter, which may be (partially) blocked. Check for coins or similar which may be jamming the impeller blades..
NOTE! Any water in the machine will flow from here!!
TIP! Lean the machine forward to help contain the last of the water in the tub.
If the drain hose is clear and the pump is still not draining the machine you may have a failed pump motor.
Pump motor replacement is not a big job for an experienced tech.
Good luck....Nomess
Oct 06, 2010 | Washing Machines
Lgwm2032hw does not drain once tub gets full. how
The first thing to do is to empty the washer by allowing the water to flow out of the drain hose by gravity...If it won't flow you have a blockage and you'll have to check the pump filter which is accessed via the small door at floor level (or behind the kick plate) Unscrew the pump cover and check the filter..Water can and will flow out if you haven't emptied the washer. There may be a small hose which next to pump cover which allows controlled draining....Good luck....Nomess
May 13, 2010 | LG WM-2277HW Front Load Washer
After wash cycle machine does not drain water and spin
could be your pump has stopped working, or a blockage first check that your stanpipe is clear, get a bucket and put outlet hose end in if it drains into bucket then it is a plumbing problem not the machine.
Mar 30, 2010 | Washing Machines
Samsung wa13g7q1 gives se error
Jan 20, 2010 | Samsung WE356A5W Washer/Dryer Laundry...
Washer does spin and it makes a weird noise
Not familiar with model but must cases its the drain pump blocked. water needs lowered before spin cycle works. Lay drain hose out the door to empty. Drain pump is down bottom beside where this hose comes out. Undo the filter bung there and clean out
Dec 13, 2009 | Kenmore 24032\24036 Top Load Washer
Front load waher will not drain
Hi, your washer water pump, could be burnt out, or clogged up, but first check drain hose for kink, remove back of machine, locate water pump, device that your drain hose are connected to, remove all hoses, pump from washer, and clean, sometimes foreign objects get into it, and prevent pump impeller from spinning, also check water pump winding (coil) with ohm tester, place tester lead, one on each terminal on pump (motor) if you hear beep sound, pump motor o/k, if not, pump burnt out, replace it, but first remove pump, and clean it. after cleaning replace pump, try machine. you could put drain hose, close to floor, into buck, and water will empty by gravity, if water is not emptying, that's evidence your water pump is block, small object (handkerchief, coins etc.) gets into them, from time to time, first clean your water pump, `and check for kink, in drain hoses. . always disconnect power, before attempting any repairs. good luck.
Aug 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Samsung washing machine WA71N2
can you hear the pump making any noises,if you can (humming sound)then it may be blocked with lint,coins etc.if the pump isnt making any noises then it may be faulty or a broken wire to the pump or you have a no drain button pressed in . hope this helps
Mar 07, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Samsung WE356A5W Washer/Dryer Laundry Pedestal Logo
211 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
